Показано с 1 по 6 из 6
Тема: ZEsarUX Beta 8.1
    Member
    Madrid, Spain
    По умолчанию ZEsarUX Beta 8.1
    Hi!
    I have uploaded a new ZEsarUX 8.1 BETA version. You can download compiled versions for Windows, Mac, and the source code from:
    https://github.com/chernandezba/zesa...g/8.1-07112019
    Changelog is:
    Added ZEsarUX Network Gaming protocol (ZENG), which allows you to play to any emulated game, using two ZEsarUX instances,
    located each one on any part of the world or in a local network. Games doesn't have to be modified, you can use any existing game
    Added Pentagon 16C colour mode emulation
    Added 1024 KB RAM emulation for Spectrum & Pentagon
    Added support for .scl files: can be converted from file selector menu pressing space
    Added SNA saving support
    Added PZX tape file support
    Added ZX81 online game browser
    Added Spectrum online game browser
    Added total run time statistics
    Added checking for updates
    Added sending anonymous statistics use
    Added setting --disablemenuandexit: it closes the emulator when the menu is going to be opened.
    It's the same behaviour as previous --disablemenu. Now --disablemenu only disables the menu but does not close the emulator
    Added Borland Gui Style
    Added ZRCP commands:
    -cpu-code-coverage: working with code coverage
    -cpu-history: working with cpu history
    -get-ui-io-ports: to get keyboard state and joystick
    -get-snapshot: get a ZSF snapshot from ZRCP
    -print-footer: print message on footer
    -put-snapshot: put a ZSF snapshot from ZRCP
    -send-keys-event: simulates key press/release
    -set-ui-io-ports: to change keyboard state and joystick
    -write-port: write value to a port
    Added internal zip decompressor: no more need to use external unzip program
    Added setting to reset configuration file to default values
    Improved Debugging:
    -added setting to dump .zsf snapshot when a cpu panic is fired
    -debug CPU window: can now resize height and have more debug lines
    -cpu transaction log: faster when opening transaction log file
    -added key 'n' for "run" on debug cpu. Does the same as closing all menus and returning back to emulation
    Improved TBBlue emulation:
    -added scroll x,y on ula layer
    -optimized ula,lores render routines: 2% less cpu on my computer
    -added 1-bit tile mode
    Improved Hex editor: can now copy to a different memory zone
    Improved menu:
    -can now use PgUp,PgDn to jump menu pages
    -added setting to disable File Utilities menu
    Improved assembler: added defs command
    Improved AY Sheet: now you can select which AY Chip to show
    Improved file selector: when asking for a directory, only shows directories, not files
    Improved curses driver: symbol @ simulates ESC on menu
    Improved snapshot loading: now setting "--sna-no-change-machine" becomes "--snap-no-change-machine" and applies to .sna and .z80
    Improved curses driver: now can use utf "blocky" characters and have 64x48 resolution
    Improved accurate Z80 timing: IM mode 0 is 1 t-state shorter than IM mode 1
    Improved real tape loading: acceleration is disabled by default, added setting to save configuration
    Fixed Pentagon border: now ukflag demo is perfect
    Fixed Spectrum 128k machines border: now ula128, scroll2017 demos are perfect
    Fixed f_seek call on esxdos handler
    Fixed segfault error when using breakpoints like peek/opcode in config file
    Fixed bug on zxuno changing video ram 5/7 when paging was disabled by bit DI7FFD
    Fixed average cpu statistics when footer is not enabled
    Fixed kempston mouse emulation on Next machine: wheel bits always return 0
    Fixed bug extracting PAWS words when a word is a pronoun
    Fixed undocumented opcode ED76: I had IM0 but it's IM1
    Fixed loading and saving +3 .z80 snapshots
    Fixed placing menu windows when using zx desktop and machines TSConf, TBBlue, CPC and QL
    Fixed bug loading .sna files when rom 1 paged in
    Fixed very-old bug when loading Rocman game. This bug existed even on ZXSpectr. It fixes return flags when using tape traps.
    Rocman loading screen was shown wrong (having the "any flag loading setting" disabled), but loaded. Enabling that setting crashed the game
  2. Эти 2 пользователя(ей) поблагодарили chernandezba за это полезное сообщение:
    Lethargeek (09.11.2019), Rusazar (08.11.2019)
  3. #1
  4. #2
    Veteran Аватар для ZXMAK
    Could you please share screenshots?
  5. #3
    Veteran
    Павлоград, Днепропетровская обл., Украина
    18
    14 сообщений
    Master Аватар для Bedazzle
    г. Таллин, Эстония
    14 сообщений
    What about win binary?
    Arrgh, newer mind, found it at the end of page.
    Seems, I'm little sleepy now.
    But anyway...
    Последний раз редактировалось Bedazzle; 09.11.2019 в 14:24.
    Heavy on the disasm
    Eric and the disasm
    Mask 3: Venom strikes disasm
  7. #5
    Member
    Madrid, Spain
    But anyway...
    Thanks. Seems some windows need this dll. I will include it in the next release
  8. #6
    г. Таллин, Эстония
    14 сообщений
    Mine is Win7 Home Premium.
    Heavy on the disasm
    Eric and the disasm
  1. ZEsarUX 8.0 stable
    от chernandezba в разделе Эмуляторы
    Последнее: 12.09.2019, 23:28
  2. ZEsarUX Beta 8.0 Release Candidate
    Последнее: 10.07.2019, 10:07
  3. ZEsarUX stable 7.2
    Последнее: 18.04.2019, 15:06
  4. ZEsarUX-7.0
    Последнее: 26.10.2018, 19:27
  5. ZEsarUX 6.1 BETA March 2018
    Ответов: 23
    Последнее: 16.03.2018, 14:50
