Показано с 1 по 9 из 9
Тема: PeterPlus Sprinter - BIOS 3.04 & TITD
    Berlin, Germany
    47
    31 сообщений
    По умолчанию PeterPlus Sprinter - BIOS 3.04 & TITD
    Hi guys,
    I just recently had to update my sprinter to BIOS 3.04 due to upgrading the VRAM to AS7C1024B-12 SRAMs.
    Previously I had run BIOS 3.03.251 due to it being the version with a legit signature for the copy of the game "thunder in the deep". With the new SRAMs I get massive junk pixels with BIOS 3.03, previously I had IDT71024 SRAMs which worked "ok" (ZX software usually worked fine, I occasionally got junk pixels in FN and high amounts in the DOOM demo or TITD). Since upgrading to 3.04 and the AS7C1024B-12 SRAMs everything seems to work fine, but I can't play TITD anymore due to a different BIOS ID.
    Is there a hacked version of the 3.04 BIOS around that works with the TITD version spread by velesoft or a version of the game without the copy protection?
    - - - Updated - - -
    Nevermind ... using sp304.bin from https://www.dropbox.com/s/9vqb7v5ww3...asher.zip?dl=0 TITD now works as well.
    I'm still occasionally getting glitches with attributes in ZX mode and TITD actually now seems worse than before. Hmpf.
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
    253
    227 сообщений
    8 Post(s)
    Sorry for my offtop. Unfortunately, I do not have information to help you. But since the Berliner is here, I’ll try to ask you. Do you know if it is possible to buy online U808D chip ( made in DDR)? Nobody offers them in eBay.But perhaps in Germany there is a site for offers of microelectronics of the times DDR?
    91
    54 сообщений
    Shockwav3, you must read this about TITD: https://zx-pk.ru/threads/12686-sprin...=1#post1044569
    shortly - TITD cracked and no need BIOS ID. download and play.
    about VRAM - if you want to use Sprinter without artefacts, you must use Winbond (W24010AJ-35) instead Alliance SRAM chips.
    Последний раз редактировалось Sayman; 24.03.2020 в 06:27.
    0A заповедей:
    I. Не удаляй каталог свой.
    III. Не кради файлы.
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    Этот пользователь поблагодарил Sayman за это полезное сообщение:
    Shockwav3(24.03.2020)
    Berlin, Germany
    47
    31 сообщений
    Thanks for linking the cracked version of TITD ... this help a lot
    W24010AJ-35 seem to be basically unobtainable :/
    I just ordered some AS7C1024-12 without the A/B which was hotfixed in BIOS 3.03 ... let's hope those work better.
    Москва 128 + AY
    Sprinter 2016S
    91
    54 сообщений
    Shockwav3, the problem with artifacts is in "12" in chips id. need 25 - 35ns. less work unstable.
    0A заповедей:
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    Berlin, Germany
    47
    31 сообщений
    So the problem is solely the timing and not possibly due to different adressing schemes of the clock cycles?
    Would this mean IS62C1024AL-35QL would be suitable? If that's the case I can easily get those at a fair price.
    Последний раз редактировалось Shockwav3; 24.03.2020 в 22:26.
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    Short followup: AS7C1024-12 with BIOS 3.03 works acceptable, little glitches with everything (occasional junk pixels, TITD intro screens quite broken), but TITD is quite playable. With AS7C1024B-12 + BIOS 3.04 TITD had severe glitches ingame and spectrum demos often had broken attributes.
    I'll see if I can obtain some W24010AJ-35 and report back then.
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    Just got my W24010AJ-35, downgraded the BIOS to 3.00, still get occasional stray pixels. TITD works mostly error free tho.
    ZX mode often has junk pixels. Oh well, I guess the Sprinter 2002S with SOJ VRAMs never worked too great either.
    Москва 128 + AY
    Sprinter 2016S
    Berlin, Germany
    47
    31 сообщений
    As another part of the saga I've ordered CY7C109-35VC ... curious if they will work any better than the Winbond/IDT ones I've tried.
    Москва 128 + AY
    Sprinter 2016S
  1. Kempston mouse & Black Raven & Unreal Specyy
    от Willy в разделе Игры
    Последнее: 27.03.2012, 16:24
  2. Ответов: 130
    Последнее: 23.08.2011, 14:32
  3. Twin worlds 2 by exodus (speccy) & illusion [spexxy] & NOP
    от Kurles в разделе Демо
    Последнее: 04.11.2008, 23:15
  4. как слить BIOS
    от Wicked в разделе Память
    Последнее: 05.07.2008, 10:23
