Страница 16 из 25 ПерваяПервая ... 121314151617181920 ... ПоследняяПоследняя
Показано с 151 по 160 из 242
Тема: Мультиинтерфейсная плата контроллеров (МИПК)
  1. #151
    г. Самара
    714
    596 сообщений
    Как оно выглядит:
        signal Display0          : typeBus;
        signal CF_A              : typeBus;
      DisplayInst0: Display
        port map
            baseAddr     => DisplayBase(12 downto 0)
          , busClock     => extClock
          , FromBus      => Display0.FromBus
          , ToBus        => Display0.ToBus
          , displayClock => intEighthExtClock
          , D_OUT        => D_OUT
          , SHIFT        => SHIFT
          , STORE        => STORE
    -- --- синий -------------------------------------------------------------------
      CFInstA : CF
        generic map
          miniversion    => "no"
        port map
            baseAddr     => CF_A_BaseAddr(12 downto 0)
          , baseVec      => CF_A_Vector
          , FromBus      => CF_A.FromBus
          , ToBus        => CF_A.ToBus
          , isWriting    => intIsCF_A_Writing
          , devCS0_L     => devCF_AA_CS0_L
          , devCS1_L     => devCF_AA_CS1_L
          , devReady     => devCF_AA_Ready
    --    , devReset_L   =>
          , devIORead_L  => intCF_A_IORead_L
          , devIOWrite_L => intCF_A_IOWrite_L
          , devInData    => intCF_AC_Data
          , devOutData   => intOutCF_A_Data
          , devIRQ       => devCF_AA_IRQ
          , devDMAAck_L  => devCF_AA_DMAAck_L
      Chasis0: Chasis
        generic map
            SlotsCount => 8
        port map
            FromBus      => slaveFromBus
          , slotsTo(0)   => Display0.FromBus
          , slotsFrom(0) => Display0.ToBus
          , slotsTo(1)   => CF_A.FromBus
          , slotsFrom(1) => CF_A.ToBus
          , slotsTo(2)   => CF_B.FromBus
          , slotsFrom(2) => CF_B.ToBus
          , slotsTo(3)   => CF_C.FromBus
          , slotsFrom(3) => CF_C.ToBus
          , slotsTo(4)   => CF_D.FromBus
          , slotsFrom(4) => CF_D.ToBus
          , slotsTo(5)   => Uart0.FromBus
          , slotsFrom(5) => Uart0.ToBus
          , slotsTo(6)   => Uart1.FromBus
          , slotsFrom(6) => Uart1.ToBus
          , slotsTo(7)   => RK0.FromBus
          , slotsFrom(7) => RK0.ToBus
          , ToBus        => slaveToBus
    Малость переименовал
    На очереди - unibus mapping регистры
    Было
    .sho conf
    RT-11XM (S) V05.07
    Booted from RK0:RT11XM
    22 bit addressing is on
    USR     is set NOSWAP
    EXIT    is set SWAP
    KMON    is set NOIND
    RUN     is set NOVBGEXE
    MODE    is set NOSJ
    TT      is set NOQUIET
    ERROR   is set ERROR
    SL      is set OFF
    EDIT    is set KEX
    FORTRAN is set FORTRA
    KMON nesting depth is 3
    Global .SCCA flag is disabled
    CLI is set DCL, CCL, UCL, NO UCF
    PDP 11/34 Processor
    3840KB of memory
    Extended Instruction Set (EIS)
    Memory Management Unit
    50 Hertz System Clock
    Device I/O time-out support
    Global .SCCA support
    Extended unit support
    UNIBUS mapping unavailable
    Стало
    .sho conf
    RT-11XM (S) V05.07
    USR     is set NOSWAP
    EXIT    is set SWAP
    KMON    is set NOIND
    RUN     is set NOVBGEXE
    MODE    is set NOSJ
    TT      is set NOQUIET
    ERROR   is set ERROR
    SL      is set OFF
    EDIT    is set KEX
    PDP 11/34 Processor
    3840KB of memory
    UNIBUS mapping disabled
    Теперь собственно трансляция.
    Уф.. Как хорошо с корзинкой то
    Хе хе, в RSX тоже:
    >con display attributes for sys
    SYS
                    PDP-11/34, EIS,UNIBUS_Map,
                    Clock=KW11-L, $TKPS=50., $TTPRM=000002
    Последний раз редактировалось Hunta; 19.04.2020 в 10:08.
  2. #151
  3. #152
    г. Самара
    714
    596 сообщений
    Когда рассматривал результат синтеза, показалось, что Квартус для регистров UM правильно выделил блоки памяти, а не собрал регистры (на триггерах).
    Оказалось - показалось.
    Поправил.
    Логика работы UMR описана, теперь проверка.
  4. #153
    г. Самара
    714
    596 сообщений
    Я крут! Я МЕГАкрут! Э... То есть хотел сказать - первая пристрелка
    .booza
    @ 002146
    @P
    XDT: 87
    ##T>g
      RSX-11M-PLUS V4.6   BL87
    BE:120204
    XDT>120204/000003 240
    XDT>p
    >con onl all
    >dev dk:
    DK0:     Loaded Type=RK05
    DK1:     Loaded Type=RK05
    DK2:     Loaded Type=RK05
    DK3:     Loaded Type=RK05
    DK4:     Loaded Type=RK05
    DK5:     Loaded Type=RK05
    DK6:     Loaded Type=RK05
    DK7:     Loaded Type=RK05
    >mou za1:/ovr
    >ins $bad
    >mou dk:/for
    >bad dk:/li
    >ins $flx
     BAD -- DK0: Total bad blocks= 0.
    >mou dk1:/for
    >flx dk1:/rt/di
    Directory        DK1:
    30-MAR-1982
    SWAP  .SYS   28. 31-OCT-1998
    RT11SB.SYS   99. 09-JAN-2020
    RT11FB.SYS  107. 09-JAN-2020
    NL    .SYS    2. 10-JAN-2020
    VM    .SYS    3. 10-JAN-2020
    LD    .SYS   11. 10-JAN-2020
    RT11XB.SYS  114. 10-JAN-2020
    RT11XM.SYS  123. 09-JAN-2020
    NLX   .SYS    2. 10-JAN-2020
    VMX   .SYS    3. 10-JAN-2020
    LDX   .SYS   11. 10-JAN-2020
    SANS04.CND    4. 09-JAN-2020
    SANS04.ANS    8. 09-JAN-2020
    SANS04.BLD    3. 09-JAN-2020
    SANS04.MON    8. 09-JAN-2020
    SANS04.DEV    4. 09-JAN-2020
    SANS04.TBL    5. 09-JAN-2020
    RT11XB.MAP   36. 10-JAN-2020
    RT11SB.MAP   34. 09-JAN-2020
    RT11FB.MAP   35. 09-JAN-2020
    RT11XM.MAP   38. 09-JAN-2020
    SL    .SYS   17. 31-OCT-1998
    SLX   .SYS   20. 31-OCT-1998
    ZA    .SYS    4. 21-JAN-2020
    ZB    .SYS    4. 21-JAN-2020
    ZC    .SYS    4. 21-JAN-2020
    ZD    .SYS    4. 21-JAN-2020
    ZE    .SYS    4. 21-JAN-2020
    ZF    .SYS    4. 21-JAN-2020
    ZAX   .SYS    4. 21-JAN-2020
    ZBX   .SYS    4. 21-JAN-2020
    ZCX   .SYS    4. 21-JAN-2020
    ZDX   .SYS    4. 21-JAN-2020
    ZEX   .SYS    4. 21-JAN-2020
    ZFX   .SYS    4. 21-JAN-2020
    SYSMAC.SML   92. 31-OCT-1998
    SYSLIB.OBJ   84. 31-OCT-1998
    ODT   .OBJ    8. 31-OCT-1998
    VDT   .OBJ    8. 31-OCT-1998
    SYSTEM.MLB  148. 31-OCT-1998
    EDTL  .MLB   11. 31-OCT-1998
    PIP   .SAV   30. 31-OCT-1998
    DUP   .SAV   52. 31-OCT-1998
    DIR   .SAV   20. 31-OCT-1998
    IND   .SAV   58. 31-OCT-1998
    RESORC.SAV   35. 31-OCT-1998
    EDIT  .SAV   19. 31-OCT-1998
    KED   .SAV   85. 31-OCT-1998
    KEX   .SAV   72. 31-OCT-1998
    MACRO .SAV   63. 31-OCT-1998
    CREF  .SAV    6. 31-OCT-1998
    LINK  .SAV   59. 31-OCT-1998
    LIBR  .SAV   24. 31-OCT-1998
    SRCCOM.SAV   26. 31-OCT-1998
    BINCOM.SAV   25. 31-OCT-1998
    SLP   .SAV   13. 31-OCT-1998
    SIPP  .SAV   21. 31-OCT-1998
    PAT   .SAV   11. 31-OCT-1998
    HELP  .SAV  161. 31-OCT-1998
    FILEX .SAV   22. 31-OCT-1998
    DUMP  .SAV   10. 31-OCT-1998
    BUP   .SAV   68. 31-OCT-1998
    LET   .SAV    6. 31-OCT-1998
    UCL   .SAV   16. 31-OCT-1998
    SETUP .SAV   43. 31-OCT-1998
    VTCOM .SAV   24. 31-OCT-1998
    DATIME.SAV    4. 31-OCT-1998
    DATIME.MAC   23. 31-OCT-1998
    DATIME.COM    3. 31-OCT-1998
    SPLIT .SAV    3. 31-OCT-1998
    VBGEXE.SAV   18. 31-OCT-1998
    TERMID.SAV    4. 31-OCT-1998
    TRANSF.SAV   16. 31-OCT-1998
    TRANSF.TSK   76. 31-OCT-1998
    TRANSF.EXE   45. 31-OCT-1998
    MDUP  .SAV   22. 31-OCT-1998
    MBOOT .BOT    1. 31-OCT-1998
    MBOT16.BOT    1. 31-OCT-1998
    MSBOOT.BOT    4. 31-OCT-1998
    MDUP  .AI    72. 31-OCT-1998
    MDUP  .MM    72. 31-OCT-1998
    MDUP  .MS    72. 31-OCT-1998
    MDUP  .MT    72. 31-OCT-1998
    MDUP  .MU    72. 31-OCT-1998
    MSCPCK.SAV    4. 31-OCT-1998
    DBGSYM.SAV   10. 31-OCT-1998
    MONMRG.SAV   14. 31-OCT-1998
    T0007 .COM    1. 31-JAN-2020
    STRTSB.COM    1. 02-FEB-2020
    STRTFB.COM    1. 02-FEB-2020
    STRTXB.COM    1. 02-FEB-2020
    STRTXM.COM    1. 02-FEB-2020
    TD3E  .SAV    3. 15-JUL-2012
    CPALL .COM    1. 02-FEB-2020
    TD    .SAV    3. 15-JUL-2012
    WQ    .SYS    4. 01-APR-2020
    WS    .SYS    4. 01-APR-2020
    WQX   .SYS    4. 01-APR-2020
    TSY02 .COM    1. 23-FEB-2001
    TRK   .COM    1. 03-MAR-2020
    TRK2  .COM    1. 05-MAR-2020
    TEST  .COM    1. 05-MAR-2020
    TRK01 .COM    1. 15-MAR-2020
    TRK01B.COM    1. 15-MAR-2020
    RK    .SYS    3. 20-MAR-2020
    RK    .OBJ    3. 20-MAR-2020
    RKX   .OBJ    4. 20-MAR-2020
    RKX   .SYS    3. 20-MAR-2020
    TRK3  .COM    1. 21-MAR-2020
    WSX   .SYS    4. 01-APR-2020
    A0007 .COM    1. 01-APR-2020
    DD    .COM    1. 01-APR-2020
    BOOZA2.SAV    2. 08-APR-2020
    BOOZF .SAV    3. 07-FEB-2020
    T     .SAV    2. 12-APR-2020
    DESS  .SAV   20. 04-NOV-1993
    BOOZA .SAV    3. 08-APR-2020
    T     .MAC    1. 12-APR-2020
    T     .OBJ    1. 12-APR-2020
    T00NL .COM    1. 12-APR-2020
    TEST  .SAV   18. 12-APR-2020
    TEST  .MAC    1. 12-APR-2020
    TEST  .OBJ   18. 12-APR-2020
    DRK   .COM    1. 13-APR-2020
    < Unused > 1950.
     1950. Free blocks
     Total of 2812. blocks in 124. files
    >ins $ini
    INS -- Task name already in use
    >dmo dk:
    00:04:51  *** DK0:  -- Dismount complete
    DMO -- TT0:    dismounted from DK0:    *** Final dismount initiated ***
    >all dk:
    >mou dk:/for
    >ini dk:test
    >dmo dk:
    00:05:04  *** DK0:  -- Dismount complete
    >mou dk:/ovr/vi
    Volume Information
    Class:       Files-11
    Device:      DK00
    Volume label:TEST
    Owner:       [1,1]
    Protection:  [RWCD,RWCD,RWCD,RWCD]
    Default:     [RWED,RWED,RWED,R]
    Processor:   F11ACP
    >ins $bru
    >bru/noini/mou/ver/ufd za1:[1,54] dk:
    BRU - Starting verify pass
    BRU - Completed
  5. #154
    г. Самара
    714
    596 сообщений
    Где то в (новом) варианте загрузчика с карт для RSX посадил ошибку. На М8 система сохраняется-загружается, на .2018 уходит в себя при загрузке. Бум посмотреть
    Собственно, на ВМ3 я вроде и не проверял, только на М8. Ну, ситуация привычная
    Хм.. Занимательно. Опять дурит запись. После сохранения на M8 на ВМ3 грузанулась вполне себе... Круг сузился
    Проверил работу RK-2011, когда буфер программы (BAD в данном случае) лежит выше 248 кб (18-ти бит для адресации не хватает). Пока замечаний нет. Ни со стороны BAD, ни со стороны меня
    По правильному, конечно, надо сигнал UMAP с процессора заводить на блок UMR, но пока этого нет. И предположение, что раз уж система начала писать в UMR, то она, скорее всего, включила UMAP - вроде как оправданно
    DOS, блин, так и не грузится.. Уже даже задевает Кстати, надо RSTS попробовать, но вот там я сильный нуль...
  6. #155
    г. Киев, Украина
    95
    82 сообщений
    а можно в двух словах обьяснить как оно вообще работает и зачем ВМ3 у которого 22bit адресов этот самый сигнал UMAP? как я понимаю он был нужен для 18bit-ной unibus чтоб контроллеры в ней могли каким-то хреном видеть 22bit?
  7. #156
    г. Караганда, Казахстан
    225
    177 сообщений
    17 Post(s)
    Именно. И решение подобно тому, как 16-разрядной машинке сделали 18- и 22-разрядные адреса. То есть, своего рода, диспетчер памяти. Специальный, для обеспечения возможности работы 18-разрядной UNIBUS с 22-разрядными адресами машинок поновее.
  8. #157
    г. Самара
    714
    596 сообщений
    Если в двух словах, то это своеобразный ДП для устройств, работающих по ПДП.
    И нужен он (именно устройствам, а не процу - у него свой ДП на этот случай) когда а) контроллер с ПДП - unibus-овский (а они умеет адресовать максимум 18 бит - ограничение Unibus, насколько я знаю) б) память 22-ух битная
    Как правило, этот сценарий возникает только на unibus системах, но потом появился сценарий, когда в qbus системах ставили конвертер шины qbus-unibus и появилась возможность к qbus системах подключать unibus контроллеры (PDP-11/83 - PDP-11/84 - кто то из этой пары с таким конвертером).
    И поскольку у проца свой ДП, ему это всё не нужно, поэтому - насколько я знаю - в QBus процах всего этого в ДП нет. Но исторически (с unibus система) сложилось, что включение этого механизма - бит в регистре ДП. Поэтому на ВМ3 он и выходит наружу. И реализовывать его надо снаружи. Например - в том самом конвертере qbus-unibus.
    Ну и поскольку я собрался подключать ethernet контроллер (один из стандартных DEC) к QBus, а он ПДП и вроде как 18-ти битный - вот и понадобилось. А отработать решил на чём попроще - и тут под руку попался RK-11
  9. #158
    г. Самара
    714
    596 сообщений
    А, да, пардон, глаза скользнули, мозг не среагировал
    Работает просто. Есть 32 Unibus Mapping регистра (правда, последний из них фактически не работает). Их длина - 22 бита. На шине каждый из них видится как пара 16-ти битных регистров. Младший (с меньшим адресом) используется целиком, в старшем - только шесть младших бит. Я не знаю (в доках не попадалось, а проверить не на чем), что будет, если попытаться записать в старший биты 15:6 - сохранятся ли они или нет. Но использоваться должны (если и сохранятся) только младшие шесть бит. Ещё одна тонкость. В доках говорится, что в младшем - 16 бит, но логика работы такова, что работают только 15 бит.
    Предположим, что механизм включен.
    - от 18-битного ПДП контроллера для шины Unibus прилетает (в запросе ПДП) 18-ти битный адрес.
    - это адрес проходит через модуль UMR
    - старшие пять бит адреса (17:13) определяют номер UM регистра (помним - он 22-ух битный и только проц его видит как пару)
    - 22-ух битное значение из него (бит 0 - прилетает нулевым) складывается с младшими 13-ю (12:0) битами исходного адреса
    - получаем 22-ух битный адрес, которые и улетают в запросе к памяти
    А теперь некоторые непонятки, с которыми я пока не разобрался. В доках говорится, что для этого механизма выделено окно 256 кб в конце оперативки (то есть это блок - (3840 кб) - (4088 кбайт - 1 байт). По сути, регистрами UM он разбит на 32 окна по 8 кб. И последнее, 31-ое окно попадает на страницу в/в (именно поэтому последний регистра фактически не работает - насколько я понимаю - на неё ПДП не распространяется). И как будто от устройства адрес летит не 18-ти битный, а 22-ух битный, причём старшие 4 бита - единицы. Ибо только тогда адрес может начинаться на 1 111 111 11x xxx xxx xxx
  10. #159
    г. Переславль-Залесский
    45
    41 сообщений
    По поводу - unibus mapping регистров. Дай бог памяти, нечто подобное было на первых VAX... Наши это всё скопировали на СМ-1700
    Там цепляли устройства, кои были на UNIBUS. Однако памяти там сильно более ... И вот для сего пользовали - unibus mapping.
    Единственно чего не знаю , так где - unibus mapping ранее применили??? Или на VAX сначала, а потом на PDP-11 c 22-битами перетащили, либо на оборот ???
    На Электронике-79 были ли - unibus mapping регистры??
  11. #160
    г. Самара
    714
    596 сообщений
    Да, это родилось на PDP-11, когда 18 бит (ака 248 кб) стало не хватать.
    Причём первоначально оно было только на unibus машинах, а когда встал вопрос подключения unibus контроллеров к qbus-машинам, то сделали это дело в конвертере qbus-unibus (см PDP-11/83 - PDP-11/84)
    Мне кажется, на QBus было проще расширить (в силу мультиплексирования адреса-данных - меньше занято контактов на разъёмах), а в Unibus отдельно хлеб, отдельно пельм... ээээ... отдельно адрес, отдельно данные - может и не получилось добавить 4 контакта-проводка. Но это моё ИМХО, почему так - в доках от DEC не попадалось.
    На 100 процентов уверять не буду (память ничего не подсказывает), но! Её драли с PDP-11/70, на коей точно есть, так что - скорее всего и на Э79
  1. Ответов: 5
    Последнее: 07.12.2018, 15:46
  2. Плата рк-86
    от oracleua в разделе Радио-86РК
    Ответов: 16
    Последнее: 22.01.2015, 18:05
  3. Ответов: 16
    Последнее: 17.03.2012, 10:00
  4. Ответов: 2
    Последнее: 19.12.2011, 11:50
  5. Схемы контроллеров B48, BZ128
    от klingon в разделе Внешние накопители
    Последнее: 06.04.2010, 14:11
