Перекачка RSX системы для первоначального запуска - процесс пошёл
@7777773000G##
9 8 7 6 5 4 3 2 1
Commands are Help, Boot, List, Map, Test and Wrap.
Type a command then press the RETURN key: BOO DU1:
DU1
RSX-11M-PLUS V4.6 BL87 256.KW System:"KXX001"
>RED DU1:=SY:
>RED DU1:=LB:
>RED DU1:=SP:
>MOU DU1:"TRANSFER"
>@DU1:[1,2]STARTUP
>; PLEASE NOTE
>; If you have not yet read the system release notes, please do so
>; now before attempting to perform a SYSGEN or to utilize the new
>; features of this system.
>* Please enter time and date (HH:MM DD-MMM-YYYY) [S]: 4-AUG-2020 23:56
>TIME 4-AUG-2020 23:56
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>CLI /INIT=DCL/CTRLC/DPR="<15><12>/$ /"
>INS LB:[1,1]RMSRESAB.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBL.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBM.TSK/RON=YES/PAR=GEN
>INS $QMGCLI
>INS $QMGCLI/TASK=...PRI
>INS $QMGCLI/TASK=...SUB
>QUE /START:QMG
>INS $QMGPRT/TASK=PRT.../SLV=NO
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>SET /EBC=TI:
>VCP CONNECT LB:[DISKS]UTILS.DSK=VF1:
VCP - Device VF1: has been assigned.
>MOU VF1:UTILS/PUB
>ASN VF1:=LB1:/GBL
>REM ...CA.
>INS LB1:[4,54]CCLRES.TSK/TASK=...CA.
>INS LB1:[4,54]CCL.TSK/TASK=...CA0
>INS LB1:[4,54]POLICE/TASK=...CA1
>INS LB1:[1,1]NDTBAS/RON=YES/PAR=GEN
>INS LB1:[1,1]MIMRES/RON=YES/PAR=GEN
>INS $BAD
>INS $BRU
>INS $CMP
>INS $CRF
>INS $DMP
>INS $LBR
>INS $MAC
>INS $RPT
>INS $SLP
>INS $TKB
>INS $VFY
>INS $VMR
>INS $ZAP
>INS LB1:[4,54]BICRES
>INS LB1:[4,54]DOBRES
>INS LB1:[4,54]DUP/INC=18000.
>INS LB1:[4,54]ERR
>INS LB1:[4,54]MIMRES
>INS LB1:[4,54]MIMRES/TASK=...NDT
>INS LB1:[4,54]MIMRES/TASK=...MMM
>INS LB1:[4,54]MO
>INS LB1:[4,54]SRDRES
>ACD UNLINK TI:
>ACD REMOVE NUMBER 20
That ACD is not installed
>ACD INSTALL LB1:[ACD2]MIMACD.TSK AS NUMBER 20 ASSIGN ACD$MIM
>ACD LINK TI: TO NUMBER 20
>@ <EOF>
>DEV DU:
DU0: Loaded Type=RA81
DU1: Public Mounted Loaded Label=TRANSFER Type=RA81
DU2: Loaded Type=RD52
DU3: Loaded Type=RD52
Старый, хорошо знакомый стрёкот винчестера
RSX-11M-PLUS V4.6 BL87 (KXX001) 256K UP 000:00:04 5-AUG-2020 01:08:19
TASK= *IDLE* FREE= SY0:954435. U1:DMO
VF1:1071. U2:FOR PARS
POOL=1444.:1778.:16. SECPOOL=378.:512.:73%
1444.:1778.:16. 378.:512.:73% SECPOL:P
SYSPAR:D
IN: D M TR T DD MV RZZP . F F F DRVPAR:D
8 I C KC T PU UF DCFM . C 1 1 GEN :D
51K R R TT : :: :: :::T . S 1 1
OUT: 1 . N. . A R A A
0 1 . . . T E C C
0K M . . . . S P P
0*******16******32******48******64******80******96******112*****
E-----P---P-------D---------------D------------D----------------
128*****144*****160*****176*****192*****208*****224*****240*****
. A Q S H B R ERRSEQ
. C M Y R A M 0.
. D G S C P D
P 2 . L . 0 T
I 0 . O . 0
P . G .
>CON DISPL ATTR FOR SYS
SYS
PDP-11/53, EIS,QBUS,D-Space,FPP,
Clock=KW11-L, $TKPS=50., $TTPRM=000002
