Итак, на текущий момент в коллекции (рабочих) процессорных плат для стенда есть
- LSI-11/2
- KDF11-A и её аналог М6
- KDF11-B
- KDJ11-A и её аналог М8
- KDJ11-B
- KDJ11-D
- МС1201.01
- МС1201.02
- МС1201.03
- МС1201.04
Что кажет RT-11 на М6:
Код:.BOO RT11XM HX DSK/TTY multiplexer v3.3 2016 RT-11XM (S) V05.07 .R MSCPCK .SHO ALL RT-11XM (S) V05.07 Booted from HX0:RT11XM 22 bit addressing is on USR is set NOSWAP EXIT is set SWAP KMON is set NOIND RUN is set NOVBGEXE MODE is set NOSJ TT is set NOQUIET ERROR is set ERROR SL is set OFF EDIT is set KEX FORTRAN is set FORTRA KMON nesting depth is 3 Global .SCCA flag is disabled CLI is set DCL, CCL, UCL, NO UCF PDP 11/23 Processor 4088KB of memory FP11 Hardware Floating Point Unit Extended Instruction Set (EIS) Memory Management Unit Parity Memory 50 Hertz System Clock Memory parity support Global .SCCA support FPU support Extended unit support Device Status CSR Vector(s) ------ ------ --- --------- RK Not installed 177400 220 DL Not installed 174400 160 DU Installed 172150 154 HX Resident 177560 000 ZA Not installed 161014 350 ZB Not installed 161054 354 ZC Not installed 161114 360 ZD Not installed 161154 364 ZE Not installed 161214 370 ZF Not installed 161254 374 WQ Not installed 177134 204 WS Not installed 177134 204 LD Installed 000000 000 VM Installed 177572 000 MU Not installed 174500 260 NL Installed 000000 000 SL Installed 000000 000 NQ Not installed 174440 120 TT (Resident) HX (Resident) HX0 = DK , SY MQ (Resident) LD SL DU VM NL 20 free slots Job Name Console Level State Low High Impure --- ---- ------- ----- ----- --- ---- ------ 0 RESORC 0 0 Run 000000 104076 120510 No multi-terminal support ------- Extended Memory -------- Address Module Words Type ------- ------ ----- ---- 17760000 IOPAGE 4096. PRM HDW BYP 17760000 MEMTOP 00760000 VM 1966080. SHR 00216500 ...... 90464. 00204100 SL 2688. PVT 00161200 DU 4832. PVT 00160000 MCA 320. PRM 00000000 KERNEL 28672. PRM HDW ------ Low Memory ------- Address Module Words ------- ------ ----- 156170 HX 452. 116142 RMON 8203. 104100 USR 2577. 001000 ..BG.. 17184. No LD units mounted .
Ответить с цитированием
