Цитата Сообщение от cyb2600 Посмотреть сообщение
Maybe I connected to tape out instead of tape in? I used pin 1, with pin 2 for ground.
I have taken a look at the schematics, and tape in is pin 3 of the DIN socket marked as O_O on the backside. Pin 1 is tape out that goes right into the base of the speaker amplifier transistor so this explains why you hear the sound from the speaker.
Отправлено с моего SM-T720 через Tapatalk
