In fact this could be a regeneration cycle (pin 15 is CAS, inverted)
Can you monitor pin 4 (RAS, inverted) along with pin 15?
Pin 4 should be low and pin 15 should be high to trigger regeneration.
But anyways the low frequency "envelope" on your screenshot from the oscilloscope does not look good at all.
Ответить с цитированием
