Показано с 1 по 3 из 3
Тема: The Witch
    Cardiff, Wales, UK
    105
    38 сообщений
    По умолчанию The Witch
    If you missed the premiere of our new video don't worry.
    The Witch is a remake of the classic game Caldron and is even better.
    Эти 4 пользователя(ей) поблагодарили morcar1975 за это полезное сообщение:
    ace210(24.10.2020), kas29(26.10.2020), shadwork(04.11.2020), TomCaT(03.11.2020)
    г. Таллин, Эстония
    226
    160 сообщений
    In original places on earth where you can land are marked with dots.
    Heavy on the disasm
    Eric and the disasm
    Mask 3: Venom strikes disasm
    Bard's disasm
    Одесса
    75
    31 сообщений
    Here you can land almost anywhere.
    Smooth and fun. Can shoot any enemy before it darts for you, enemies above behave very differently, some just fly up-down (nice shooting ground-to-air plants ).
    No enemy hinders your walks for keys and doors. Much more fair underground walks, nice lava spits inside the volcano.
    The noticed minuses so far:
    The moon is not in full.
    Too straight and easy underground caves.
    I've managed to walk into the rock and die (when going too far past the door with no appropriate key).
    I've jumped up-down on the lift (southeastern corner of the volcano) and eventually just fell through it (doing no left-right movement). Maybe it's the AGS engine.
    Too small collected items icons.
    The inventory limit of 2 is extended to full six, so it's too easy to pass a cave with its 3 items. The casket and pot are also missing, so the volcano and crypt can be done in any order and just once. Maybe using this original trick tasks with added magic springs to replenish magic would do better.
    And what about the logo? Doesn't it remind of something?
    Помни. Только на компьютере можно семь раз Cut, а один - Format. В реале все иначе. (c)
    Власть людей сильнее, чем люди у власти.
    Чем меньше мы смотрим на мир, тем больше задумываемся о нем. (c)
    Can you help Robin in his quest for the silver arrow? (c) Odin "Robin of the Wood"
    Мы все немного режем по дереву, а потом собираем корабли в бутылках.
    Is it the same old story you are going to tell me
    or is it the old story telling me and you we are the same?
    http://www.sky.od.ua/~ptsk
  1. The Witch
    от Slider в разделе Новые игры для ZX Spectrum
    Последнее: 17.12.2020, 18:57
