Показано с 1 по 3 из 3
Тема: Вышел DevPak от AmigaKit
  1. #3
    201
    139 сообщений
    А есть какая-то информация о компиляторах Modula-2 и Oberon-2 для Amiga?
    У меня нет. Но можно посмотреть на сайте eab.abime.net - если уж там ничего не найдено, то плохо дело.
    На aminet.net поиск по "oberon" дает 39 вхождений. Например:
    Archive: Oberon-A_1.6_bin.lha
    Distribution: Freeware, under the GNU General Public Licence
    Requirements: an Amiga with 1MB and Kickstart 2.0.  A hard disk is
        highly recommended.
    Oberon-A is a freely-distributable Oberon-2 compiler. Oberon-2 is a
    modern object-oriented language designed by Niklaus Wirth, the creator
    of Pascal and Modula-2, and Hanspeter Mössenböck. Oberon-A is an
    implementation of the language for the Amiga computer, ported from a
    compiler written by Niklaus Wirth.
    The archive contains the compiler, a pre-link utility, a linker (BLink),
    error lister, a programmer's environment, other utilities and
    documentation. The documentation is in AmigaGuide and plain ASCII
    formats. A text editor is *not* included.
    This archive is NOT the complete Oberon-A distribution. You must also
    obtain Oberon-A_1.6_lib.lha, which contains the source code for the
    library modules, Amiga interface and examples. Oberon-A_1.6_src.lha
    contains the source for the compiler and utilities, but is optional.
    This archive supersedes Oberon-A_1.5.lha and incorporates all the
    bug-fixes and improvements made to date.
    Там же, на аминете, есть раздел и по m2. Например:
    Turbo Modula-2 V1.40 (26/Jan/95)
    Turbo Modula-2 (c) Copyright 1994/1995 by Amritpal Mann, All Rights Reserved
    Email: turbo@econet.demon.co.uk
    Amiga Turbo Modula-2 is a compiler developed for use with all Amigas.
    Its most notable features are:
    o Interface modules for V40 of the Amiga operating system.
    o Sun Modula-2 like DEFINITION FOR C MODULE's allow access to
    ANSI C standard library functions.
    o Fast single pass compilation with extremely accurate error
    diagnostics.
    o High quality code generation.
    Code is typically 75% faster than code generated by the (ETH
    derived) commercial compiler used for the initial bootstrap, the
    drystone benchmark runs over twice as fast.
    o Residentable code support.
    o Includes a system builder (no messing about with makefiles).
    Amiga Turbo Modula-2 can be obtained from the AmiNet ftp sites.
    /pub/aminet/dev/m2/Turbo_Part1.lha
    /pub/aminet/dev/m2/Turbo_Part2.lha
    Последний раз редактировалось tnt23; 26.10.2020 в 22:28.
    Этот пользователь поблагодарил tnt23 за это полезное сообщение:
    Oleg N. Cher(27.10.2020)
  1. Вышел Caslink3
    от Wierzbowsky в разделе MSX
    Последнее: 11.09.2022, 19:30
  2. Вышел esxDOS 0.8.7
    от nihirash в разделе Оси
    Ответов: 44
    Последнее: 03.05.2021, 22:42
  3. amigakit.com
    от Syntal в разделе Amiga
    Ответов: 25
    Последнее: 19.02.2012, 22:42
  4. Абзац 31 вышел!
    от axor в разделе Пресса
    Последнее: 24.09.2007, 11:23
  5. Абзац 27 вышел
    Последнее: 08.08.2006, 16:39
