Страница 31 из 50 ПерваяПервая ... 272829303132333435 ... ПоследняяПоследняя
Показано с 301 по 310 из 498
Тема: DaDither - еще одна програмка для dither-га картинок
  1. #301
    Londonderry, UK
    https://youtu.be/zsjTpFR0oYQ
    took me ten years had to use 5 programs ended up with bmp2scr be nice if we could simplify the process no?
    - - - Updated - - -
    spectra has 2x2 attribute but only 64 colours is it supported?
    ula+ has 256 colour palette and 64 onscreen 8 pixel attributes can we blend 2 screens at 25hz for more colours and 256x384? also ula+ support timex hirez 512x192 again can we use 2 screens at 25hz blend them 4 grey scale and 512x384?
    sam coupe mode 4 is 4bits per pixel 16 colours from 128 again can we blend 2 screens at 25hz for more colours higher rez 256x384? also mode 3 512x192 only 2bits per pixel again cab we blend 2 screens at 25hz
    im trying to make full screen animations like anton javorcek c....
    https://youtu.be/NDe1U7A7yGk
    - - - Updated - - -
    i need avi video file converter can this do the job?
    - - - Updated - - -
    was using 5 programs
    windows media player classic to play video full screen at 320x200 and then
    camtasia studio with a capture window at 256x192
    then fed this file into bmp2scr from lcd fantastic program
    this gives u a giant tap/tzx file
    sim coupe sam emulator didnt used to support tap/tzx so andrew collier wrote a python script which used to be available from world of sam converts tap into atom lite hdf compact flash records
    we just need shanazx dma interface for sam to get it wirking on real hardware apols my russian is only
    yedan dva tre pyeteri pyiet shest!
    atkooda? da vie bleem
    - - - Updated - - -
    ZXPRESS •ZXTUNES •Virtual TR-DOS •World of Spectrum •ZX Spectrum Old Demos •
    Log OutSettingsMy ProfileNotificationsWelcome, rogerjowett
    ArticlesForumNew PostsPrivate MessagesFAQCalendarCommunityForum ActionsQuick LinksBlogsБарахолкаWhat's New?Правила ZX-PK.ru
    Advanced Search
    ForumZX Spectrum SoftwareГрафикаDaDither - еще одна програмка для dither-га картинок
    РЕКЛАМА
    РОСПИСЬ ХРАМА.
    РОСПИСЬ ХРАМА.
    БОЛЬШЕ НА
    ARTEL-RADOST.COM
    + Reply to Thread
    Page 31 of 31First...2728293031
    Results 301 to 301 of 301
    Thread: DaDither - еще одна програмка для dither-га картинок
    Thread ToolsSearch ThreadRate This ThreadDisplay
    25th April 2022, 03:39#301
    rogerjowett
    JuniorJoin DateThanks Thanks
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Edit Post Reply Reply With Quote
    + Reply to Thread
    Quick Navigation Графика Top
    Quick Reply
    FontSize
    - - - Updated - - -
    http://www.fruitcake.plus.com/Sincla...aInterface.htm
    - - - Updated - - -
    c 2x2 attributes but only 64 colours what a shame im trying to persuade paul farrow and ula+ to double the amount of video ram hardware interlace and vdp9990!
    u seen the byte delight zx hdmi? it uses a pi0 to give speccy hdmi output the pi0 in the z spectrum next offers sid emulation if it can emulate a sound chip why not a video chip? super fx anyone?!
  2. #301
  3. #302
    Londonderry, UK
    https://drive.google.com/file/d/1L1b...w?usp=drivesdk
    - - - Updated - - -
    works in fuse only has ay sample and loadsa screen$
    can we convert it to ula+ ? interlaced? hi rez? spectra 2x2 attributes?
  4. #303
    Londonderry, UK
    ula+? spectra? avi video file conversion?
  5. #304
    г. Тотьма
    345
    182 сообщений
    Автор (Dec) был тут месяц назад. Может, письмо ему послать? Рядом с именем пользователя выпадающее меню - Отправить email.
    Leningrad 1/Sega Joy Adapter
    DivGMX
    ZX Spectrum +2A
    ZX Evolution rev. C
    Орск
    1,257
    371 сообщений
    Не ведитесь. это троллинг сильно законспирированный
    З.Ы. не прошу считать за истину. сугубо моё имхо
    prdisvalald
  7. #306
    199
    137 сообщений
    Не, там человек реально сконвертировал клип покадрово в экраны ZX. и походу вручную..
    - - - Updated - - -
    Actually it works not only in FUSE. I've checked it in Spin, ZEsarUX and also on real machine (Sizif 512) with Esxdos - it works. But unfortunately i didn't heard AY sample...
  8. #307
    Белоруссия
    21
    14 сообщений
    Данный BMP (и не только он) отображается в DaDither перевёрнутым
    • Тип файла: zip MG030.zip (18.7 Кб, Просмотров: 65)
    Your life is REAL. Change it UNREAL!
  9. #308
    2,368
    1,317 сообщений
    39 Post(s)
    Отрицательная высота, что сигнализирует о хранении строк сверху-вниз, только читал о таких bmp.
  10. #309
    Londonderry, UK
    По умолчанию spaceba
    thanks will do
    - - - Updated - - -
    prdisvalald
    highly conspiratorial trolling what planet are you on?
    prdisvalald
    yeah but can you imagine if it was ula+ spectra interlacedf 8 pixel attributes and 256 colour palette and 2x2 attributes for spectra be fantastic no just need shamazx dma
    Последний раз редактировалось rogerjowett; 03.06.2022 в 19:19.
  11. #310
    Киров
    200
    99 сообщений
    12 Post(s)
    Исправил.
    Этот пользователь поблагодарил Dec за это полезное сообщение:
    transman(16.06.2022)
  1. ...И еще одна РК-шка...
    от Anubis_OD в разделе Радио-86РК
    Ответов: 19
    Последнее: 20.04.2016, 12:09
  2. Ответов: 14
    Последнее: 08.05.2013, 10:18
  3. Еще одна CP/M помойка
    от Error404 в разделе Оси
    Последнее: 18.09.2007, 21:18
  4. Ещё одна плата
    от CityAceE в разделе Несортированное железо
    Последнее: 25.04.2005, 10:41
