Показано с 1 по 6 из 6
Тема: General sound 512 emulation
    Madrid, Spain
    46
    18 сообщений
    По умолчанию General sound 512 emulation
    Hi
    I’m planning to add General Sound emulation to my ZEsarUX emulator
    I have found information about programming the GS: type and format of the messages, ports etc
    But I have not found info about how internally works the GS:
    -ports used (the same as on the speccy side?)
    -controlling dac interface: ports, volumes etc
    -interrupts: how the interrupts are fired?
    Etc...
    Anyone has that info? I don’t know Russian but using a translator should be enough (I hope )
    Regards
    César
    1,497
    974 сообщений
    try examine this http://dlcorp.nedopc.com/download/file.php?id=3014
    it`s source of UnrealSpectrum emulator
    Madrid, Spain
    46
    18 сообщений
    Thanks. I already found that. But there’s no documentation nor comments that explain clearly how it works
    Великий Новгород
    233
    99 сообщений
    Here is some documentation about GS, including schemes and internal ports (in russian)
    Also, you can examine this sources - https://github.com/samstyle/Xpeccy/b...ccy/sound/gs.c
    • Тип файла: zip GS.zip (279.2 Кб, Просмотров: 85)
    Последний раз редактировалось SAM style; 08.11.2020 в 17:47.
    Все любят гипножабу
    Этот пользователь поблагодарил SAM style за это полезное сообщение:
    sdima1357(08.11.2020)
    Madrid, Spain
    46
    18 сообщений
    Thank you! That will be a lot of help!
    Cheers
    Cesar
    Madrid, Spain
    46
    18 сообщений
    Hi
    I've been looking at the mapping register:
    port 0 "extended memory"
    bits D0 - D3 switch pages by 32Kb
    page 0 - ROM
    digits D4 - D7 are not used
    # 0000 - # 3FFF - first 16Kb of ROM
    # 4000 - # 7FFF - first 16Kb of the first page of RAM
    # 8000 - #FFFF - turnable pages of 32Kb
    page 0 - ROM,
    page 1 - first page of RAM
    page 2 ... RAM
    So, when register is 0, ROM is mapped on 8000H-FFFH
    When register is 1, first 32 KB of RAM (ram 0) are mapped on 8000H-FFFH
    When register is 2, second 32 KB of RAM (ram 1) are mapped on 8000H-FFFH
    If you have a General Sound 512KB, the mapping register will be maximum value 15, so, when you are paging RAM 15-1=14, that means you can have different 15 pages mapped, so 15 X 16 = 480 KB
    So the last 32 kb can't be used... right?
    Using the same example, a General Sound with 128kb ram, can map up to 128-32=96 KB ram (but I read on some places than can map up to 112 KB)
    Is there anything wrong here? Have I understood it well?
    Thanks
    Could it be that:
    # 4000 - # 7FFF - LAST 16 kb of RAM
  1. Sound emulation ПЭВМ "БАЙТ" with КР580ВИ53
    от Gelip в разделе Эмуляторы
    Ответов: 28
    Последнее: 17.01.2026, 21:42
  2. General Sound
    от GM BIT в разделе Программирование
    Ответов: 13
    Последнее: 31.05.2011, 01:34
  3. Ответов: 245
    Последнее: 28.05.2011, 21:48
  4. General Sound на ютубе.
    от moroz1999 в разделе Разный софт
    Последнее: 16.05.2010, 17:04
  5. General Sound
    от newart в разделе Звук
    Ответов: 133
    Последнее: 11.10.2006, 22:58
