Показано с 1 по 1 из 1
Тема: JetSet Willy Mono Plus
    Derby, United Kingdom
    24
    По умолчанию JetSet Willy Mono Plus
    I built this from the original patch:
    JSW Mono Plus
    A small expansion on the existing 'JSW Mono' variant offering a choice of colours!
    Upon loading the player is presented with a neat and tidy menu offering a range of suggested presets, selectable by a letter key:
    White ink with black paper
    White ink with black paper and bright enabled (This is the original 'JSW Mono patch' effect output when applied to the game engine)
    The above options are also offered in inverse! That being white paper with black ink, again available with or without bright.
    A basic 'green screen' choice is available, limited to green ink on black paper but with the option of bright enabled or not.
    The player may also select their own preference for desired ink , paper , bright and (if they insist!) flash options. A basic sanity check is applied to prevent the player choosing the same value for paper and ink and a further check to confirm they really do want flash enabled. Upon completion of picking the colour options the text for the custom option is displayed in those colours.
    Please refer to screenshots of the menu, it was written to be self-explanatory as far as sensibly possible.
    The player may at this stage change their mind and pick a default value or re-enter a choice of custom values.
    When happy pressing the 'R' key will "run" the game code, this is necessary even if one of the pre-defined choices is selected. A basic check is present to ensure an option has been chosen before the 'R' key will function as no option is selected by default. The currently "active choice" is shown by the menu letter control key being set to flash. Again please take a look at the screenshots.
    We hope you enjoy this small expansion tweak to the existing 'JSW Mono' !
    https://jswmm.co.uk/files/file/142-j...lly-mono-plus/
ID:	75874   Нажмите на изображение для увеличения.
    Andy
    Эти 3 пользователя(ей) поблагодарили spider за это полезное сообщение:
    ALS(25.07.2021), Black Cat / Era CG(25.07.2021), OMu4(25.07.2021)
  1. Perils of Willy ZX, The
    от abelenki в разделе Игры
    Последнее: 18.03.2020, 14:43
  2. Jetset Willy 2015 - Bug Fixed Edition
    от Rindex в разделе Игры
    Последнее: 05.06.2015, 21:51
  3. Willy The Wasp
    Последнее: 23.06.2014, 10:35
  4. Jet Set Willy 64: Willy - The Man Who Sold the World!
    от kyv в разделе Игры
    Последнее: 23.06.2008, 12:21
  5. Ответов: 4
    Последнее: 01.01.2008, 23:22
