Страница 13 из 18 ПерваяПервая ... 91011121314151617 ... ПоследняяПоследняя
Показано с 121 по 130 из 180
Тема: Почему компилированный Бейсик выполняется быстро?
  1. #121
    252
    226 сообщений
    8 Post(s)
    А под какой ассемблер Open82?
    Makefile
    # Makefile: Build script
    # From the Open82 project
    # Copyright (c) 2000 Matthew Westcott
    # $Id: Makefile 16 2005-12-18 16:45:24Z gasman $
    # This program is free software; you can redistribute it and/or modify
    # it under the terms of the GNU General Public License version 2 as
    # published by the Free Software Foundation.
    # This program is distributed in the hope that it will be useful
    # but WITHOUT ANY WARRANTY; without even the implied warranty of
    # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    # GNU General Public License for more details.
    # You should have received a copy of the GNU General Public License
    # along with this program; if not, write to the Free Software
    # Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
    # Author contact information:
    # E-mail: matthew@west.co.tt
    # Postal address: 14 Daisy Hill Drive, Adlington, Chorley,
    #                 Lancs, PR6 9NE, United Kingdom
    # Configuration options - override these in a file named config.mk if required
    # Path to the Fuse <http://fuse-emulator.sourceforge.net/> executable, used by
    # 'make fuse' to start up the emulator with the ROM image installed
    FUSE=fuse
    # Font to incorporate into the ROM. Valid options are ZX81ACE and CLAIRSYS
    FONT=ZX81ACE
    # End configuration options
    -include config.mk
    .PHONY: fuse clean
    ifeq ($(FONT),CLAIRSYS)
      FONT_FILE=fonts/clairsys.bin
    else
      FONT_FILE=fonts/zx81_ace.asm
    endif
    open82.bin: rom.asm restarts.asm startup.asm printing.asm keyboard.asm interpreter.asm cassette.asm clear_screen.asm errors.asm memory.asm expressions.asm functions.asm commands.asm print_string.asm graphics.asm calculator.asm diagnostics.asm splash_screen.asm $(FONT_FILE)
    	pasmo --equ FONT_$(FONT) rom.asm open82.bin open82.sym
    # build the ROM and run it in Fuse
    fuse: open82.bin
    	$(FUSE) --rom-48 open82.bin --machine 48 --no-traps
    clean:
    	rm -f open82.bin open82.sym
    Цитата Сообщение от Conan Посмотреть сообщение
    ресурсы (деньги)
    на ерунду всякую деньги тратил, царство ему небесное! Нет чтобы на zx spectrum сосредоточить их все. Вот какая-то зараза ему нашептала, что у компьютера век недолог.
  2. #121
  3. #122
    1,462
    951 сообщений
    Выше уже приводился пример, где на давно зафиксированном железе, имевшееся ПЗУ для ZX Spectrum доделывали и улучшали. С более современными знаниями, подходами, средствами разработки, интернетом и прочими чудесами цивилизации. Заняло это от 5 лет, а результат оказался востребованным чуть менее чем заурядная дема или игра.
    там изначально была совсем другая цель, нужно было сделать аналог, но с другим кодом.
    для применения в коммерческих проектах.
    родную прошивку в продаваемом железе использовать нельзя.
  4. #123
    Moscow
    282
    109 сообщений
    Компьютеры ZX Spectrum (включая плюсы) производились до того, как их перестали раскупать и даже после этого на склад.
    там изначально была совсем другая цель, нужно было сделать аналог, но с другим кодом. для применения в коммерческих проектах.
    Все верно, но сроки реализации слишком затянулись.
    Этот пользователь поблагодарил Conan за это полезное сообщение:
    Barmaley_m(26.11.2023)
  5. #124
    193
    154 сообщений
    "эта аппаратура" должна быть современной. Тогда и старые программы на ней будут "летать". А кому надо их притормаживать - должен это делать с легкостью.
    Тогда это не про Спектрум
    какую ответственность разделяет шаман, если сроки "заточки каменного топора" отсутствуют?
    При том, что он определял сроки и ресурсы (деньги) для разработки кода ПЗУ ZX Spectrum.
    Исключаем его ограничения и получаем: open source replacement operating system ROM for the Timex 2000 series and Sinclair ZX Spectrum
    Которая даже не 5+ лет, а с 2001 года все еще бета версия. Бесплатная (хобби), не фултайм, но и конца-края разработки не видно уже двадцать лет.
    Вообще не интересно в данной теме про время деньги сроки.
    Интересно (мне!) лишь чисто техническая часть.
    Имеется Спектрум 48. Имеется стандартное пзу.
    Вопрос, что в рамках этих 16к пзу можно сделать, чтобы улучшить его характеристики как встроенной ос или Биос.
    Это интересно. Чисто техническая часть. Безотносительно того, что там было 40 лет назад у Синклера и вопросов, почему оно так было.
  6. #125
    Moscow
    282
    109 сообщений
    Цитата Сообщение от SfS Посмотреть сообщение
    Имеется Спектрум 48. Имеется стандартное пзу. Вопрос, что в рамках этих 16к пзу можно сделать, чтобы улучшить его характеристики как встроенной ос или Биос.
    Ничего существенного. Значительное переписывание ПЗУ приведет ухудшению совместимости. Новые функции "BIOS" без программной поддержки и с глюками старого софта вряд ли кто-то назовет улучшением ПЗУ ZX Spectrum 48.
    Фирменное ПЗУ пытались "улучшать" много раз. Начиная от замены (С) на "свое" и добавления кириллицы, заканчивая турбо загрузчиками и встроенными мониторами. Результаты известны.
  7. #126
    193
    154 сообщений
    Про совместимость речь вообще не идёт.
  8. #127
    Moscow
    282
    109 сообщений
    Тогда можно продолжать теоретизировать о переписывании всего ПЗУ, не оглядываясь на фирменное. Практически любой написанный ранее код можно улучшать и оптимизировать. Пока не надоест.
  9. #128
    193
    154 сообщений
    Именно это мы и делаем тут))
  10. #129
    193
    154 сообщений
    Прям зацепила идея бейсика на базе форта) Из головы не выходит. Даже книги начал читать)
  11. #130
    Moscow
    282
    109 сообщений
    Создателей Бейсика и железа ZX Spectrum подобная идея тоже "зацепила". В результате появился Jupiter Ace. Особого успеха он не имел: по оценкам в прессе было продано около 5 тысяч компьютеров. По словам Стива Викерса (автора встроенного ЯВУ) быстро удалось продать всего 300 штук.
  1. Ответов: 47
    Последнее: 02.02.2021, 14:06
  2. Как быстро летит время.
    от Mick в разделе Новости
    Ответов: 18
    Последнее: 25.02.2020, 08:43
  3. Почему Спектрум-бейсик такой медленный?
    от mmxdmv в разделе ZX Концепции
    Ответов: 53
    Последнее: 07.07.2018, 19:39
  4. Как быстро добраться до мыши?
    от TomCaT в разделе Для начинающих
    Ответов: 38
    Последнее: 02.03.2010, 11:00
  5. Быстро переместить 384b
    от Aprisobal в разделе Программирование
    Последнее: 23.01.2005, 15:23
