Показано с 1 по 3 из 3
Тема: Eye Ache 2 on Pentagon 48
    Berlin, Germany
    47
    31 сообщений
    По умолчанию Eye Ache 2 on Pentagon 48
    Hi,
    a while ago I designed this board for Pentagon 48 computers, which adds 128K RAM and adjusts the timing to Pentagon 128. So far it has been working nicely (Rage, Across the Edge, etc.). Only issue I encountered was with Eye Ache 2, the demo works, but whenever the disk drive gets accessed the demo slows down considerably (running at something around 30%) - I'm not a coder and therefore can't trace the issue. Does anyone have any ideas what might cause this?
    Pentagon 48 + MIKAY128 + VG93 Turbo + Stereo Covox + KJoy
    Москва 128 + AY
    Pentagon 1024SL 2.2 + ZXM-GS + Z-Controller + TSFM + Tape-In
    ZX Evolution Rev. C + ZX-MultiSound
    Compact 256 Turbo 1.1 (ZS Scorpion 256 INT, Port #FF, Port #FB) + Covox + ProfROM + NemoBus + NemoIDE + ZXM-GS
    ZS Scorpion 256 Turbo+ + GMX + SMUC + GS Classic 2MB
    Sprinter 2016S
    К сожалению, я не говорю по-русски / Sorry, I don't speak Russian
    https://github.com/zxshock
    275
    167 сообщений
    It's because of the demo needs right interleave of sectors on diskette - it should be standart interleave 2 (sector numbers on diskette track: 1,9,2,10,3,11,4,12,5,13,6,14,7,15,8,16). With fast (turbo) interleave (1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16) the demo can not get in time do its visual effects before reading of next disk sector, so it waits full turn of the diskette to read next sector. So you should format your diskette for the demo with normal (not turbo) option to avoid the demo slow down.
    Этот пользователь поблагодарил Spectramine за это полезное сообщение:
    Shockwav3(04.02.2023)
    Berlin, Germany
    47
    31 сообщений
    That fixed it Thank you.
    Москва 128 + AY
    Sprinter 2016S
  1. Dizzy-AGE RUS: Dizzy And The Emerald Eye на русском
    от Rindex в разделе Dizzy-AGE
    Ответов: 28
    Последнее: 01.02.2016, 08:04
  2. Ответов: 186
    Последнее: 01.07.2012, 18:43
  3. Dizzy-AGE: Dizzy And The Emerald Eye
    Ответов: 19
    Последнее: 05.05.2011, 23:11
  4. Ответов: 0
    Последнее: 24.01.2010, 21:46
  5. Eye-Q [Organism]
    от GibbS в разделе Люди
    Последнее: 29.04.2007, 09:44
