LED DRIVER TM1623
DESCRIPTION
TM1623 is an LED Controller driven on a 1/7 to 1/8 duty factor. Eleven segment output lines, six grid output lines, 1 segment/grid output lines, one display memory, control circuit, key scan circuit are all incorporated into a single chip to build a highly reliable peripheral device for a single chip microcomputer. Serial data is fed to TM1623 via a three-line serial interface. Housed in a 32-pin SOP Package, TM1623 pin assignments and application circuit are optimized for easy PCB Layout and cost saving advantages.
FEATURES
• CMOS Technology
• Low Power Consumption
• Multiple Display Modes (12 segment, 6 Grid to 11 segment, 7 Grid)
• Key Scanning (8 x 3 Matrix)
• 8-Step Dimming Circuitry
• Serial Interface for Clock, Data Input/Output, Strobe Pins
• Available in 32-pin, SOP Package
APPLICATION
• Micro-computer Peripheral Device
• VCR set
• Combi set
