Кто-нибудь может мне объяснить суть сего произведения?
Вот не влом было регить com-адрес ради такого...
P.S. Под Макстоном сработало с глюками, под Файрфоксом всё вроде ОК.
по данным WHOIS.OPENSRS.NET:
Registrant:
Aethon
3 Chandlers Court
4 Rose Road
Southampton, Hampshire SO14 6TF
GB
Domain name: RTAPELOADINGERROR.COM
Administrative Contact:
Bailey, Malcolm mbailey@aethon.co.uk
3 Chandlers Court
4 Rose Road
GB
+44.2380233808
Technical Contact:
3 Chandlers Court
4 Rose Road
GB
+44.2380233808
Registration Service Provider:
UK Reg, domains@fasthosts.co.uk
+44 1452 541252
+44 1452 538485 (fax)
http://www.ukreg.com/
Registrar of Record: TUCOWS, INC.
Record last updated on 10-Feb-2007.
Record expires on 26-Oct-2007.
Record created on 26-Oct-2006.
Domain servers in listed order:
NS26.BULKDNS.CO.UK
NS25.BULKDNS.CO.UK
Domain status: clientTransferProhibited
clientUpdateProhibited
The Data in the Tucows Registrar WHOIS database is provided to you by Tucows
for information purposes only, and may be used to assist you in obtaining
information about or related to a domain name's registration record.
Tucows makes this information available "as is," and does not guarantee its
accuracy.
By submitting a WHOIS query, you agree that you will use this data only for
lawful purposes and that, under no circumstances will you use this data to:
a) allow, enable, or otherwise support the transmission by e-mail,
telephone, or facsimile of mass, unsolicited, commercial advertising or
solicitations to entities other than the data recipient's own existing
customers; or (b) enable high volume, automated, electronic processes that
send queries or data to the systems of any Registry Operator or
ICANN-Accredited registrar, except as reasonably necessary to register
domain names or modify existing registrations.
The compilation, repackaging, dissemination or other use of this Data is
expressly prohibited without the prior written consent of Tucows.
Tucows reserves the right to terminate your access to the Tucows WHOIS
database in its sole discretion, including without limitation, for excessive
querying of the WHOIS database or for failure to otherwise abide by this
policy.
Tucows reserves the right to modify these terms at any time.
By submitting this query, you agree to abide by these terms.
NOTE: THE WHOIS DATABASE IS A CONTACT DATABASE ONLY. LACK OF A DOMAIN
RECORD DOES NOT SIGNIFY DOMAIN AVAILABILITY.
Описание полей в ответах WHOIS-сервиса о доменах
по данным WHOIS.VERISIGN-GRS.COM:
Whois Server Version 2.0
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to http://www.internic.net
for detailed information.
Domain Name: RTAPELOADINGERROR.COM
Registrar: TUCOWS INC.
Whois Server: whois.opensrs.net
Referral URL: http://domainhelp.tucows.com
Name Server: NS25.BULKDNS.CO.UK
Name Server: NS26.BULKDNS.CO.UK
Status: clientTransferProhibited
Status: clientUpdateProhibited
Updated Date: 21-dec-2006
Creation Date: 26-oct-2006
Expiration Date: 26-oct-2007
>>> Last update of whois database: Tue, 13 Mar 2007 09:49:26 UTC <<<
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar. Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability. VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
speccy merchandise
У меня этот сайт на работе не открывается, может дома и откроется.
max iwamoto, КОЛЛЕГА! Давно искал такого же умника, как я![]()
GMX для Scorpion'а можно приобрести здесь
ZX-BUS XTRaiser v2.1 (активный расширитель ZX-BUS здорового человека на 3 слота) можно приобрести здесь
SMUC 2.1 rev. C Black & White edition (v.2022) можно приобрести здесь
Scorpion ZS-256 Turbo, GMX 2048Kb, ZX-BUS XTRaiser v2.0, SMUC v2.0 rev. A, SDCard 32Gb, GS 2Mb,
ZXMC 2v28, TSFM, FDD 5'25 Teac x2, FDD 3'5 Sony, VGA&PALv2.09, PC Keyboard & Mouse
Открылся дома этот адрес!!!
Прикольно тем что непонятно!
может вирус хотели прицепить к этому ,а потом забросили (шутка).
Ну почему вирус ? Просто прикололся кто-то и сделал это отлично. На подобие мультика на флешке с песней - "hey 16 key". Самое приятное, что каждый раз при запуске RTAPELOADINGERROR.COM выбирается по РНД название загружаемой. Я вообще, заметил, что РНД в таком виде только используют спектрумисты.
Для начала, правая кнопка мыши и смотрим html:
Затем вынимаем swfobject.js и смотрим описалку:Код:<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /> <title>Online - ZX Spectrum emulator</title> <script type="text/javascript" src="swfobject.js"></script> <SCRIPT LANGUAGE="JavaScript" type="text/javascript">
* SWFObject v1.4.2: Flash Player detection and embed - http://blog.deconcept.com/swfobject/
* SWFObject is (c) 2006 Geoff Stearns and is released under the MIT License:
* http://www.opensource.org/licenses/mit-license.php
* **SWFObject is the SWF embed script formerly known as FlashObject. The name was changed for
* legal reasons.
Вот наверно автор где то там.....
http://www.digg.com/programming/Flas...ctrum_emulator
http://www.urban75.net/vbulletin/sho...25#post5495825
Последний раз редактировалось AAA; 09.04.2007 в 00:57.
