Показано с 1 по 10 из 10
Тема: www.rtapeloadingerror.com
    Joensuu (Finland)
    По умолчанию www.rtapeloadingerror.com
    Кто-нибудь может мне объяснить суть сего произведения?
    Вот не влом было регить com-адрес ради такого...
    P.S. Под Макстоном сработало с глюками, под Файрфоксом всё вроде ОК.
    USSR
    по данным WHOIS.OPENSRS.NET:
    Registrant:
    Aethon
    3 Chandlers Court
    4 Rose Road
    Southampton, Hampshire SO14 6TF
    GB
    Domain name: RTAPELOADINGERROR.COM
    Administrative Contact:
    Bailey, Malcolm mbailey@aethon.co.uk
    3 Chandlers Court
    4 Rose Road
    GB
    +44.2380233808
    Technical Contact:
    3 Chandlers Court
    4 Rose Road
    GB
    +44.2380233808
    Registration Service Provider:
    UK Reg, domains@fasthosts.co.uk
    +44 1452 541252
    +44 1452 538485 (fax)
    http://www.ukreg.com/
    Registrar of Record: TUCOWS, INC.
    Record last updated on 10-Feb-2007.
    Record expires on 26-Oct-2007.
    Record created on 26-Oct-2006.
    Domain servers in listed order:
    NS26.BULKDNS.CO.UK
    NS25.BULKDNS.CO.UK
    Domain status: clientTransferProhibited
    clientUpdateProhibited
    The Data in the Tucows Registrar WHOIS database is provided to you by Tucows
    for information purposes only, and may be used to assist you in obtaining
    information about or related to a domain name's registration record.
    Tucows makes this information available "as is," and does not guarantee its
    accuracy.
    By submitting a WHOIS query, you agree that you will use this data only for
    lawful purposes and that, under no circumstances will you use this data to:
    a) allow, enable, or otherwise support the transmission by e-mail,
    telephone, or facsimile of mass, unsolicited, commercial advertising or
    solicitations to entities other than the data recipient's own existing
    customers; or (b) enable high volume, automated, electronic processes that
    send queries or data to the systems of any Registry Operator or
    ICANN-Accredited registrar, except as reasonably necessary to register
    domain names or modify existing registrations.
    The compilation, repackaging, dissemination or other use of this Data is
    expressly prohibited without the prior written consent of Tucows.
    Tucows reserves the right to terminate your access to the Tucows WHOIS
    database in its sole discretion, including without limitation, for excessive
    querying of the WHOIS database or for failure to otherwise abide by this
    policy.
    Tucows reserves the right to modify these terms at any time.
    By submitting this query, you agree to abide by these terms.
    NOTE: THE WHOIS DATABASE IS A CONTACT DATABASE ONLY. LACK OF A DOMAIN
    RECORD DOES NOT SIGNIFY DOMAIN AVAILABILITY.
    Описание полей в ответах WHOIS-сервиса о доменах
    по данным WHOIS.VERISIGN-GRS.COM:
    Whois Server Version 2.0
    Domain names in the .com and .net domains can now be registered
    with many different competing registrars. Go to http://www.internic.net
    for detailed information.
    Domain Name: RTAPELOADINGERROR.COM
    Registrar: TUCOWS INC.
    Whois Server: whois.opensrs.net
    Referral URL: http://domainhelp.tucows.com
    Name Server: NS25.BULKDNS.CO.UK
    Name Server: NS26.BULKDNS.CO.UK
    Status: clientTransferProhibited
    Status: clientUpdateProhibited
    Updated Date: 21-dec-2006
    Creation Date: 26-oct-2006
    Expiration Date: 26-oct-2007
    >>> Last update of whois database: Tue, 13 Mar 2007 09:49:26 UTC <<<
    NOTICE: The expiration date displayed in this record is the date the
    registrar's sponsorship of the domain name registration in the registry is
    currently set to expire. This date does not necessarily reflect the expiration
    date of the domain name registrant's agreement with the sponsoring
    registrar. Users may consult the sponsoring registrar's Whois database to
    view the registrar's reported date of expiration for this registration.
    TERMS OF USE: You are not authorized to access or query our Whois
    database through the use of electronic processes that are high-volume and
    automated except as reasonably necessary to register domain names or
    modify existing registrations; the Data in VeriSign Global Registry
    Services' ("VeriSign") Whois database is provided by VeriSign for
    information purposes only, and to assist persons in obtaining information
    about or related to a domain name registration record. VeriSign does not
    guarantee its accuracy. By submitting a Whois query, you agree to abide
    by the following terms of use: You agree that you may use this Data only
    for lawful purposes and that under no circumstances will you use this Data
    to: (1) allow, enable, or otherwise support the transmission of mass
    unsolicited, commercial advertising or solicitations via e-mail, telephone,
    or facsimile; or (2) enable high volume, automated, electronic processes
    that apply to VeriSign (or its computer systems). The compilation,
    repackaging, dissemination or other use of this Data is expressly
    prohibited without the prior written consent of VeriSign. You agree not to
    use electronic processes that are automated and high-volume to access or
    query the Whois database except as reasonably necessary to register
    domain names or modify existing registrations. VeriSign reserves the right
    to restrict your access to the Whois database in its sole discretion to ensure
    operational stability. VeriSign may restrict or terminate your access to the
    Whois database for failure to abide by these terms of use. VeriSign
    The Registry database contains ONLY .COM, .NET, .EDU domains and
    Registrars.
    Russia, Ulianovsk
    33
    22 сообщений
    5 баллов тому, кто это придумал очень улыбнуло
    speccy merchandise
    В.Новгород
    У меня этот сайт на работе не открывается, может дома и откроется.
    Canada
    Открылся без проблем. Самое интересное, чтокогда я был молодой, то чмтал это примерно так "R-Type Loading Error" и не мог понять какое имеет отношение R-Type к ошибке бэйсика...
    362
    198 сообщений
    max iwamoto, КОЛЛЕГА! Давно искал такого же умника, как я
    В.Новгород
    Открылся дома этот адрес!!!
    Прикольно тем что непонятно!
    может вирус хотели прицепить к этому ,а потом забросили (шутка).
    Ukraine
    Ну почему вирус ? Просто прикололся кто-то и сделал это отлично. На подобие мультика на флешке с песней - "hey 16 key". Самое приятное, что каждый раз при запуске RTAPELOADINGERROR.COM выбирается по РНД название загружаемой. Я вообще, заметил, что РНД в таком виде только используют спектрумисты.
    Земля, Москва, Марьино
    17 сообщений
    Для начала, правая кнопка мыши и смотрим html:
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    <title>Online - ZX Spectrum emulator</title>
    <script type="text/javascript" src="swfobject.js"></script>
    <SCRIPT LANGUAGE="JavaScript" type="text/javascript">
    Затем вынимаем swfobject.js и смотрим описалку:
    * SWFObject v1.4.2: Flash Player detection and embed - http://blog.deconcept.com/swfobject/
    * SWFObject is (c) 2006 Geoff Stearns and is released under the MIT License:
    * http://www.opensource.org/licenses/mit-license.php
    * **SWFObject is the SWF embed script formerly known as FlashObject. The name was changed for
    * legal reasons.
    Вот наверно автор где то там.....
    http://www.digg.com/programming/Flas...ctrum_emulator
    http://www.urban75.net/vbulletin/sho...25#post5495825
    Последний раз редактировалось AAA; 09.04.2007 в 00:57.
    DimkaM
