Показано с 1 по 3 из 3
Тема: Dangerous NEMO IDE ports
    Praha
    34
    15 сообщений
    По умолчанию Dangerous NEMO IDE ports
    As I see, all NEMO IDE ports use dangerous adress value. Software using NEMO IDE ports can't work on all ZX models/clones with incomplette adressation of paging ports if NEMO IDE interface absent.
    - any read from NEMO IDE ports will crash on real ZX Spectrum 128 or +2 or can return value from AY ports (if software use only 8bit adress for NEMO IDE).
    - any write to NEMO IDE ports will write data value parallel to memory paging port and on some models parallel to ULA port #FE.This is list on machines unusable with NEMO IDE software if NEMO IDE interface absent:
    Pentagon 128
    Pentagon 256
    Pentagon 512
    Pentagon 1024 SL
    ZX PROFI
    ZX Spectrum 128
    ZX Spectrum 128+2(grey)
    ZX Spectrum 128+2A
    ZX Spectrum 128+3
    and other models....
    If NEMO IDE is connect then active signal IORQGE on ZX BUS for possibility use IDE ports without risc (without rewrite paging port value). But some ZX models absent signal IORQGE on ZX BUS (ZX Spectrum 128+2A and +3) ZX Spectrum 128 and +2 contain IORQGE signal, but for disable ula port #FE only Then NEMO IDE interface or software with NEMO IDE drivers can't be used on ZX128/+2/+2A/+3.
  1. Rick Dangerous 1,2-глюк
    от Vitron в разделе Игры
    Последнее: 03.01.2023, 16:18
  2. PAGING PORTS of ZX / CLONES
    от VELESOFT в разделе Память
    Ответов: 42
    Последнее: 28.01.2013, 21:02
  3. Dangerous software for Pentagon 1024SL
    от VELESOFT в разделе Оси
    Последнее: 07.03.2010, 02:03
  4. бумажные игрушки из Rick Dangerous и Switchblade
    от Vinnny в разделе Разный софт
    Последнее: 09.11.2009, 17:16
  5. Nemo
    от kgbplus в разделе Люди
    Ответов: 63
    Последнее: 05.11.2007, 10:53
