Показано с 1 по 4 из 4
Тема: Дождался! Fuse (Spectrum Emulator) Preview Edition for Wii.
    1,675
    579 сообщений
    50 Post(s)
    По умолчанию Дождался! Fuse (Spectrum Emulator) Preview Edition for Wii.
    http://giesler.biz/~bjoern/blog/inde...review_release
    Цитата Сообщение от Björn's Blog
    FUSE preview release
    June 7th, 2008
    I'm releasing a preview of FUSE for the Wii. It still has a couple bugs and lacks a couple features, but it's very useable.
    FUSE is the Free Unix Spectrum Emulator by Philip Kendall, an emulator for the Sinclair ZX Spectrum, a home computer that was very popular in the 80s. For more information (and thousands of games!), see World of Spectrum.
    You can download it here. Just unpack the archive under /apps on your SD card and run it.
    Most Spectrum software assumes you have a keyboard attached (since the original Spectrum is an all-in-one home computer). FUSE for the Wii supports USB keyboards. You will probably need one.
    When you run FUSE, you get the Spectrum 48K boot screen. You can now attach a USB keyboard and write BASIC programs!
    You can also push the HOME button on your Wiimote. This brings up a menu that you can use to load Spectrum games from SD card. The A button selects a menu entry, the B button brings you up one menu. You should also tell FUSE to use your Wiimote as a Sinclair Joystick: Options->Joysticks->Joystick 1->Sinclair Joystick
    Now, when you start a game, tell the game to use the Sinclair interface. Hold the Wiimote sideways so the 1&2 buttons are on the
    right. The directional pad is your joystick, 2 is Fire button 1, 1 is Fire button 2.
    To quit FUSE, bring up the menu and select File->Exit, press A on the question whether you really want to quit.
    Have fun and direct any and all questions to me!
    Последний раз редактировалось CityAceE; 11.06.2008 в 04:11.
    С уважением, Станислав.
    1,675
    579 сообщений
    50 Post(s)
    А вот видео по теме:
    http://youtube.com/watch?v=NpBIej-NB-o
    Земля, Москва, Марьино
    17 сообщений
    __________________
    А управление с кубовского джоя и AY в 128 играх есть ?
    Надо будет по твоей инструкции сделать как нить...
    1,675
    579 сообщений
    50 Post(s)
    Это пока preview версия. На сколько я понял, там только Remote поддержан. Я сам только Batty запускал, да и то не смог управление выбрать толком. Посему жду более полной версии.
  1. Higgins Spectrum Emulator
    от Higgins в разделе Эмуляторы
    Ответов: 56
    Последнее: 16.01.2011, 19:17
  2. FUSE & Pentagon1024
    от Vinnny в разделе Эмуляторы
    Ответов: 59
    Последнее: 16.11.2007, 13:47
  3. J2ME ZX Spectrum emulator for Siemens x65
    от cbn в разделе Эмуляторы
    Последнее: 16.08.2006, 14:25
  4. Quick Commander v4.00 (preview)
    от Знахарь в разделе Софт
    Последнее: 11.11.2005, 13:40
