Показано с 1 по 10 из 14
Тема: TRD images on HDD
    Praha
    34
    15 сообщений
    По умолчанию TRD images on HDD
    What format of HDD use russian clones ? (smuc interface, etc...)
    Is supported only TRD images ?
    VELESOFT
    USA
    ATM, NEMO (2 different formats), and SMUC.
    No, not only TRD. Some clones (such as ATM Turbo 2+, Profi...) have support of CP/M. Also OS TASiS was developed (only for ATM). IS-DOS can be installed on almost every russian clone (exclude weird old ones). All this OS' support HDD and have they own file system. It's possible to keep TRD images on HDD and run it when you want to. In case of ATM you can put TRD image on RAM disk and start special version of TR-DOS which supports RAM disk.
    Последний раз редактировалось Adramelek; 25.10.2008 в 05:08.
    Praha
    34
    15 сообщений
    Цитата Сообщение от Adramelek Посмотреть сообщение
    ATM, NEMO (2 different formats), and SMUC.No, not only TRD. Some clones (such as ATM Turbo 2+, Profi...) have support of CP/M. Also OS TASiS was developed (only for ATM). IS-DOS can be installed on almost every russian clone (exclude weird old ones). All this OS' support HDD and have they own file system. It's possible to keep TRD images on HDD and run it when you want to. In case of ATM you can put TRD image on RAM disk and start special version of TR-DOS which supports RAM disk.
    And what is format of HDD ?
    IDE medium can be formatted as FAT 16/32 or use dirrerent file system (only for ZX) ?
    Can be same HDD used for PC and for ZX (russian clones) ?
    All disk images(TRD) is conected in one big block(file) ?
    Is supported SCL files ?
    Any support for loading TAP,Z80,SNA ?
    Is on HDD used TRD images with different size(longer or less) than 640kB ?
    OK, with HDD can work only special TR-DOS roms with modified ramdisk support, but on HDD will not work software used #3D2F (as on my SPRINTER 2000 with HDD support)
    VELESOFT
    Последний раз редактировалось VELESOFT; 25.10.2008 в 13:44.
    USA
    I just said that: "All this OS' support HDD and have they own file system." Of course it's not FAT, but some tools allow you to use FDD in MS-DOS format.
    Unreal Speccy supports real HDDs.
    I don't think so. Why it would be like that?
    No, any OS have no native support of any of these files (include TRD). You can use TRD images only with help of some special tools such as TRDEXE.COM for CP/M. If you want to load TAP or SNA, you probably need to write your own software for that. Maybe somebody already did it, but I'm not sure.
    TRDEXE.COM supports IMG images with size less than 640 Kb. TRD images -- standart size only AFAIK.
    You need to talk with Max Timonin about that: max_timonin@mail.ru. He's the guy who know everything about CP/M, IS-DOS, and TASiS for ATM Turbo clone.
    Последний раз редактировалось Adramelek; 26.10.2008 в 00:46.
    Praha
    34
    15 сообщений
    Original ZX with MB02 interface use also real MS-DOS 1.8MB !!! FDD(HD FDD).
    http://translate.google.cz/translate...hl=cs&ie=UTF-8
    http://www.8bc.com/sinclair/DOWNLOAD/index.htm
    This only transport TRD image from HDD to real FDD or RAMDISK ? Direct access to IDE device is more usable(and need only modified trdos without any convertor)
    This software exist from year 2002. It is DEMFIR - system for czech DIVIDE interface. For use with any other ZX clones need only three(or two) 16kB ram pages in memory space 0-16383. System contain comfortable NMI menu with real CD-ROM support. Support also work with ISO images on HDD/CF, TAP,TZX,SNA,Z80,SCR loading.
    DEMFIR use different IDE ports than russian IDE interfaces, but source code is free
    Exist more other systems for DIVIDE interface:
    http://www.divide.cz/?x=info
    For use with russian clones is best system FATWARE:
    This is comfortable disk browser with FAT16 support(also support 4GB FAT16 partitions supported by WIN XP). Can load any TAP,SNA,Z80,SCR and DITHVIDE(2x6912 bytes long file = interlace two videorams) files. For use with any other ZX clones need only three(or two) 16kB ram pages in memory space 0-16383.
    But standard size of SINGLE SIDE/80 TRK disk is 320kB, SINGLE SIDE/40 TRK disk is 160kB, etc...
    VELESOFT
    Последний раз редактировалось VELESOFT; 26.10.2008 в 02:22.
    USA
    You can find some commanders for TR-DOS such as HDD v2.0 and HDD Commander v1.2f. I think they have support of NEMO interface and TR-DOS format. But actually I know nothing about it, so you better ask another guy.
    It's pretty cool, but since nobody using cassette tapes in Russia, almost every piece of software existed was converted to TRD or SCL. May be somebody in Russia need to load TZX from HDD, but I never heard about such of thing.
    320 Kb? 160 Kb? I'm not sure it's standart anymore.
    P.S. BTW, what are you trying to tell me? What is this all about? It is some kind of advertisement?
    Последний раз редактировалось Adramelek; 26.10.2008 в 02:22.
    91
    54 сообщений
    Diamond....coder from exAreasoft, some time ago he wrote correction for trdos for possibility of work with hdd. But at present the project is not finished. There is a full documentation with all coments on alteration. An essence that it has given the chance to work trdos with hdd. Without everyones rom-disk`s. in idea he used a trd image on fat hdd. to load and work with image it used a commander...but...not finished(((
    I hope that it will transfer it to me or still to somebody for work continuation.
    0A заповедей:
    I. Не удаляй каталог свой.
    III. Не кради файлы.
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    Praha
    34
    15 сообщений
    Modified TRDOS with FDC controller emulation (software emulation similar as on my project)
    http://atmturbo.nedopc.com/projects/hdd_prj.htm
    This is TRDOS version for ATM TURBO computer. If source code will free, I can compare both (this and my) emulation routines/methods and this help me with hdd-trdos finalization.
    LAESQ (author of ESXDOS system) use also software FDC emulation:
    http://esxdos.org/
    VELESOFT
    Саратов
    я был бы безмерно счастлив,если б душка VELESOFT портировал свой чудо эмуль для pentagon1024sl2.2+Gluk menu+nemoIDE интерфейс...
    к примеру: прога прописывается на fat32 раздел (с правильного сектора),и загружается из меню "hdd boot",вирт дисковод становиться А:,реальный-B:,и из оболочки проги загружаем trd/scl (tap/tzx/sna) образ для дальнейшего получения удовольствия..
    мечты..мечты..
    ALL,переведите басурманину плз-а ну как изготовит..
    ATM 7.10 | hdd | cd-rom
    Commodore 64 | fdd
    БК 0010-01
    Praha
    34
    15 сообщений
    мечты..мечты..
    Yes, all is possible. But PENTAGON 1024 can in low16kB set only ROM or RAM0 page. So must be used rom chip with modified TRDOS rom version.... Software for support TAP/SNA/Z80/TZX need also modified rom.
    VELESOFT
