Страница 29 из 37 ПерваяПервая ... 252627282930313233 ... ПоследняяПоследняя
Показано с 281 по 290 из 364
Тема: ZX ULA наконец-то будет взломана!
  1. #281
    12
    г. Екатеринбург
    34
    29 сообщений
    0.1% как раз на то, что работать будет криво.
    Моё железо
    ZX Spectrum +2
    ZX Spectrum +3
    Harlequin 48K
    Harlequin 128K
    Karabas-128
    197
    164 сообщений
    OffTop !!!
    почему 99.9, а не 100?
    http://www.devic.us/hacks/z80-soul/
    "I loaded and run "ZEXDOC" and "ZEXALL" test programs that exercised Z80 instructions. All documented and undocumented instructions are passing but only the quirky undocumented CPIR and LDIR family's IX and IY flags are not correct. This presents no practical problems with any code"
    далее смотрим картинку...
    http://www.devic.us/hacks/retrochallenge/#more-1108
    "Once the CPU was formally done, I could run anything, using every instruction assembled and pushed onto my simple "board" model, including some devilish and interrupt-bombardment tests. I also run well known ZEXDOC and ZEXALL tests. They all passed except several weird XF/YF (undocumented flags) behavior for 2 sets of instructions. Those are really weird and if you have ever played with Z80 emulators you would know what I mean. I believe this particular Z80 (mis)behavior is likely a side-effect of internal bus charge/discharge cycles and some spurious control signals since different second-sourced Z80 chips behave differently in these scenarios. I decided not to sweat over it as it had no practical impact."
    Последний раз редактировалось AlexG; 16.11.2015 в 08:58.
  4. #284
    255
    223 сообщений
    Z80 и ULA ИМХО разные вещи. Z80 Лисыцин и на AVR полностью эмулировал.
  5. #285
    г. Одесса, Украина
    64
    33 сообщений
    А пока некто Mark Smith сделал платку на Xilinx, заменитель ULA. Назвал SLAM48, 128+ и т.д.
    Вот пост в фейсбуке
    Вот картинка, если линк не откроется..
    Допиливает как раз.. пишет что:
    "Ula+ version is ready it will support all Timex modes too, so mono 512x192 (with ula+ palette), shadow screen at 6000h, and hires (32x192) attributes. The prototype already supports those modes, but a second prototype is needed so as to test a design that uses fewer components."
    Последний раз редактировалось Anubis_OD; 29.12.2015 в 13:37.
    С Уважением, Андрей!
  6. #286
    г. Екатеринбург
    34
    29 сообщений
    Интересно какова будет цена?
    Моё железо
    ZX Spectrum +2
    ZX Spectrum +3
    Harlequin 48K
    Harlequin 128K
    Karabas-128
  8. #287
    г. Одесса, Украина
    64
    33 сообщений
    Учитывая дефицитность и все меньшую доступность.. я думаю что баксов 25-30 зарядит.
  9. #288
    Anubis_OD, За границей все цены начинаются от 100$ + доставка.
    С уважением, Дмитрий.
  10. #289
    г. Одесса, Украина
    64
    33 сообщений
    Не убедил..Сайт sallmyretro имеет много всяких девайсов/девайсиков за более скромные деньги.. но,да, альтруизмом тамошние ваятели не страдают..
  11. #290
    г. Екатеринбург
    34
    29 сообщений
    За эту цену я купил ZX Spectrum +2 вместе с ULA, так что в данный момент продажи по такой цене у него не попрут.
    Моё железо
    ZX Spectrum +2
    ZX Spectrum +3
    Harlequin 48K
    Harlequin 128K
    Karabas-128
  1. под TS FM будет кто ваять?
    от Romanich в разделе Музыка
    Ответов: 145
    Последнее: 28.05.2007, 12:29
  2. Наконец то запустил ZX + TR-DOS
    от andrew76 в разделе Несортированное железо
    Последнее: 09.03.2007, 08:55
  3. А вот кто меняться будет?
    от Vint в разделе Барахолка (архив)
    Ответов: 23
    Последнее: 11.11.2006, 20:15
  4. Ответов: 5
    Последнее: 19.03.2005, 02:15
