Показано с 1 по 10 из 23
Тема: ALASM for PROFI clone??
    Czech Republic
    32
    8 сообщений
    По умолчанию ALASM for PROFI clone??
    Dear ZX PROFI clone users,
    some of you may be using ALASM 507 or 508. I tried to run the official ALASM version in PROFI mode, but it seems not working. It seems to me that the official release of ALASM is designed to be run only on Pentagon.
    What is the mystery of runnig ALASM in PROFI mode? I suppose it is the BASIC loader, that have to be different for PROFI and for Pentagon (and maybe also different ALASM BASIC loader for Scorpion and other clones) Would you tell me, please?
    Thanks
    Hood
    Новосибирск
    91
    54 сообщений
    may be problem in memory driver. you can load alasm in 128kb mode and load profi memory driver source and fix it.
    i`m not use alasm version 5.x. only 4.x and 3.9 in trdos.
    0A заповедей:
    I. Не удаляй каталог свой.
    III. Не кради файлы.
    Sprinter resurrect:
    Telegram
    Discord
    Repo
    Forum
    Czech Republic
    32
    8 сообщений
    По умолчанию Solution found
    Thanks
    Hood
    Hello, so with Velesoft, we found out the solution.
    Here is a part of the mem driver:
    ;PROFI HIGH MEMORY DRIVER
    ORG #7000
    MEMDRV
    ADAS LD A,#04
    ZAP LD BC,#DFFD ;PROF MEM DRV
    LD E,#7F
    LD D,A
    AND #07
    LD L,A
    XOR D
    RRCA
    RRCA
    RRCA
    SET 4,L
    JP #3899
    LD HL,#C000 ;JUMPER 23600
    PUSH HL
    JR ADAS ;26 üÇëĺ
    On the JP 3899h, this is a jump to ROM, where some OUT instructions are placed+RET.
    The problem is, that on 3899h in our ROM, we do not have such OUT instructions, so it is just enough to redirect JP 3899h somewhere, where I place the OUT instructions, and that is the solution.
    The same jump is for example also in ATM memory driver.
    Hood
    Ижевск
    чето у меня не хочет Профик1024 с аласмом дружить.
    пзу basic-48 НЕ стандартное.
    JP #3899 менял на out-ы.
    всё равно не хочет.
    возможно аласм еще где-то обращается к пзу basic-48?
    подскажите плиз, кто в курсе..
    ---------- Post added at 14:04 ---------- Previous post was at 13:47 ----------
    попробовал щас аласм в эмуле с basic-48 и c basic-48_for_128.
    при выборе в конфиге драйвера профи, вроде бы метр памяти видится, но жмем любую клавишу и комп(эмуль) виснет.
    че ему еще надо то блин??
    Рязань
    всё равно не хочет.
    Не влезло в 26 байт?
    Перед переключением драйвера памяти установи все страницы в конфиге на 128К.
    Samara
    335
    256 сообщений
    alone, скинь лучше сразу настроенный аласм с комментами
    сразу станет проще
    С уважением,
    Jerri / Red Triangle.
    Ижевск
    пробовал и так вот даже:
    вместо JP#3899 ставил JP L3899, а саму метку эту L3899 размещал в самом низу драйвера. а с неё уже out (c),a: ld b,e: out (c),l: ret
    там итак по умолчанию стоит драйвер 128к.
    Рязань
    Так делать нельзя. Драйвер копируется в область системных переменных и лежит там резидентом. Там места всего 26 байт.
    Установи все СТРАНИЦЫ в конфиге на 128К.
    сразу станет проще
    В данный момент здесь у меня нет аласма.
    Ижевск
    поясни плиз подробнее.
    Рязань
    1. Запусти конфиг.
    2. Установи все страницы только 0,1,3,4,6,7.
    3. Выйди из конфига.
    4. Запусти конфиг.
    5. Установи другой драйвер памяти.
  1. using macros in ALASM
    от hood в разделе Софт
    Последнее: 05.10.2009, 14:36
  2. Alasm 507- help
    Последнее: 13.04.2009, 14:56
  3. Помощь по ALASM
    от Zloy в разделе Программирование
    Ответов: 16
    Последнее: 01.04.2009, 19:29
  4. BYTE Spectrum clone
    от [ro]psergiu в разделе RST#38
    Последнее: 20.03.2007, 17:19
  5. GPL CP/M clone
    от dhau в разделе Оси
    Ответов: 21
    Последнее: 12.03.2006, 17:00
