Показано с 1 по 4 из 4
Тема: TommyGun - a retro development toolkit
    Одесса
    75
    31 сообщений
    По умолчанию TommyGun - a retro development toolkit
    Transferred from "Programming" part, originally posted by 736b
    TommyGun is an Integrated Development Environment (IDE) for creating games and other software for old 8 bit computers. It is a modular and open ended application that can support any type of computer. Although realistically speaking I'm limiting the application to 8 and 16 bit computers. It allows the user to create games for their prized vintage or retro machines.
    Summary of Features
    * Easy to use and easy to learn
    * Use any assembler for your target machine
    * Use any emulator you like (works best with one that except command line arguments)
    * One click build - Will build and then launch your emulator if the build is successful
    * Fully featured Code editor
    * Full set of drawing editors (sprites, tiles, fonts, screens and user defined graphics - UDG's)
    * Complete Map editor
    * Full Undo/Redo system for all operations including drawing and editing. Lots of options and completely configurable
    * Image editors and Code editor has full cut/copy/paste functionality
    * Code editor supports bookmarks
    * Code editor has full search and replace abilities
    * No need for special tools to convert bitmaps in code - all handled by the application
    * Show image animations in the main editor
    * Images support masking
    * Image editor supports auto zoom to window size
    * Plug-in based application that is easily extensible. Only loads plug-ins that require for each machine
    * Support for assemblers and/or C compilers
    * Code editor supports a wide range of data parsers/code generators. (soon to have its own scripting language)
    * Automatic Project Backup system. Each to use Project Restore feature
    * Code editor has build tool profiles so you can easily switch between specific assemblers or emulators
    * Can import a range of images to be transferred into any image type
    * Comes with demo projects to see how things work
    * Also comes with 2 tutorials to get you started (more on the way)
    Official Site http://www.users.on.net/~tonyt73/TommyGun/
    Помни. Только на компьютере можно семь раз Cut, а один - Format. В реале все иначе. (c)
    Власть людей сильнее, чем люди у власти.
    Чем меньше мы смотрим на мир, тем больше задумываемся о нем. (c)
    Can you help Robin in his quest for the silver arrow? (c) Odin "Robin of the Wood"
    Мы все немного режем по дереву, а потом собираем корабли в бутылках.
    Is it the same old story you are going to tell me
    or is it the old story telling me and you we are the same?
    http://www.sky.od.ua/~ptsk
  1. TommyGun - a retro development toolkit
    от 736b в разделе Программирование
    Ответов: 14
    Последнее: 29.09.2006, 15:12
  2. Zx Retro demo compo 2005!!!
    от klim в разделе Демо
    Ответов: 27
    Последнее: 08.03.2005, 16:35
