Показано с 1 по 2 из 2
Тема: SPECCY.SU
    Самара
    По умолчанию SPECCY.SU
    Due to serious price drop on .SU registration I get domain name speccy.su
    .SU stands for Soviet Union – yes funny but fact, there is no country but domain name still exists and fell strong.
    Actually now offer free e-mail accounts like [email protected] (where megasoft is your desired login) for all Speccy fans in ex-USSR. Also I recognize that .SU can be translated as Spectrum User. Great oprotunity to promote this service for Western Speccy fans, really?!
    Access to this mail provided via web interface or using mail client. Everything based on the Google Apps for Domains, that’s why e-mail on functionality and volume corresponds to the standard Gmail account.
    To get free e-mail account just send me personal message with 3 main details;
    Surname: Dow
    Login: mylogin
    Please fill each pattern using only latin characters. After registration I shuld mail to you conformation (usually within 24 hours).
    Access to e-mail through a web interface occurs at http://mail.speccy.su
    Default password for the first sign: speccy
    After the first sign you will be asked to change the password. All other settings are can do manually via web-interface.
    All accounts in the system by default are created with the English language interface (UK). When you first login to the system (or later, in the operation), you can switch interface in your own language for which localized GMail.
    SMTP / POP is supported!
    To set up SMTP/POP you need to do simple procedure: Settings > Forwarding and POP to include the possibility of working with POP. And later when you should set up your mail client software please use instead of simply login megasoft is a fully [email protected] - otherwise, it would be an attempt to get e-mail addresses for [email protected] that we do not have ...
    Последний раз редактировалось unbeliever; 05.03.2008 в 16:33. Причина: Добавлено сообщение
  1. Speccy.SU
    от unbeliever в разделе Новости
    Ответов: 56
    Последнее: 08.04.2021, 05:54
  2. USB+Speccy
    от amiguser в разделе Несортированное железо
    Ответов: 73
    Последнее: 15.07.2006, 00:47
