Показано с 1 по 10 из 13
Тема: Russian ZX BUS
    Master Аватар для VELESOFT
    Praha
    33
    14 сообщений
    По умолчанию Russian ZX BUS
    Where can I find informations about ZX BUS used on russian ZX clones ? Pinout is same as on original ZX Spectrum BUS ?
    VELESOFT
    Последний раз редактировалось VELESOFT; 22.10.2008 в 00:51.
    Master Аватар для Keeper
    VELESOFT
    1. You should use schematic diagram of the russian clone named KAY.
    2. You should use schematic diagram of the russian clone named Scorpion.
    3. You should use document from attachment.
    • Тип файла: txt ZXBUS.TXT (5.7 Кб, Просмотров: 655)
    Последний раз редактировалось Keeper; 22.10.2008 в 03:16.
    Banned Аватар для Black_Cat
    S.Pb
    Now the ex Soviet Union standard ZX Spectrum bus - NemoBus. NemoBus - is a modified bus ZX Bus. NemoBus - this is not the Russian standard, this standard ex Soviet Union. NemoBus used in all computers KAY, Pentagon-1024SL v1.4, v2.2. A computer Scorpion ZS256/Turbo+ is not used NemoBus, there is clone ZX Bus. The main difference NemoBus of ZX Bus - the existence of arbitration. Slots NemoBus not the same, highest priority is the 1 st slot, the 3rd slot is the lowest priority. To work NemoBus are most familiar to the original scheme of computer KAY-1024SL:KAY-1024.rar
    Attention! Archive will be removed within a week.
    343
    190 сообщений
    Try this...
    Praha
    33
    14 сообщений
    Try this...
    This is very similar as original ZX Spectrum BUS
    Pinout of main signals(from CPU) is same.
    You can connect interface designed for original ZX models to russian ZX clones with this ZX bus layout.
    S.Pb
    This of course can be done, but it does not make sense.
    Praha
    33
    14 сообщений
    You can connect to russian ZX clones:
    - my K-MOUSE TURBO interface (compatible with russian wheeled kempston mouse)
    - DATA-GEAR (DMA)
    - SAA1099 interface (sound chip from SAM COUPE)
    - DivIDE interface (use extra rom+ram, ide ports, systems with FAT16 support, TAP, SNA, Z80 loading....)
    - MB02 interface (DMA support, external memory rom and ram(512kB),rtc,8255)
    And I can connect to my original ZX128+2:
    - GENERAL SOUND
    - Z-CONTROLLER
    - ZXMC
    Последний раз редактировалось VELESOFT; 22.10.2008 в 20:30.
    S.Pb
    - DATA-GEAR (DMA)
    In the ex USSR normally connect using soldering iron.
    Doubtful that these devices will be popular in the ex Soviet Union.
    Praha
    33
    14 сообщений
    No, but is it possible connect.
    Exist any russian interface with external memory (sram/rom) ?
    VELESOFT
    Explaine, please.
  1. Russian Bear Group
    от Serdjuk в разделе Люди
    Ответов: 54
    Последнее: 06.04.2010, 12:35
  2. RUSSIAN SOFTWARE and real ZX
    от VELESOFT в разделе Игры
    Ответов: 74
    Последнее: 29.11.2008, 13:49
  3. Looking for Russian Games
    от CityAceE в разделе RST#38
    Последнее: 19.02.2008, 16:24
  4. SINCLAIR ZX SPECTRUM 48k RUSSIAN model MASTER NIB!
    от dhau в разделе Барахолка (архив)
    Последнее: 24.01.2006, 19:36
