APL-11 (for RSX and RSTS/E)
Наткнулся на конференцию с исходниками АПЛ-11 для PDP-11
> On 3/30/20 3:21 PM, Mark Matlock via cctech wrote:
>> Bill (Gunshannon),
>> The APL-11 files on DECUS RSX85A are not a complete distribution but a
>> modified version that was intended to run under I/D on M+.
>> I have the APL-11 V2.1 source files on a RL02 disk image. I will make it
>> available at http://www.rsx11m.com/apl11.zip
>> Once you mount the disk image with Simh, the are two ready to run task
>> images that will run under RSX11M or M+
>> In [201,200]APL6OK.TSK and APL7OK.TSK that are the REAL*4 and REAL*8
>> versions of APL-11. On the disk are the
>> Original .MAC sources as well as files from a RSX SIG tape that modified
>> APL-11 for I/D under RSX11M+ that increased
>> The workspace (.BXWA from ~3 to ~6 bytes). It also contains a
>> character set for Vt220 for the APL character set.
>> When you install the APL task experiment with the /INC to maximize the
>> available workspace, On my system, I can
>> INS APL6.TSK/INC=37000 to max the workspace for the single precision version.
>> Also, the scanned APL-11 reference manual can be downloaded at
>> http://www.rsx11m.com/APL-11-Ref-Man.pdf
(AA-5076B-TC APL-11 Programmers Reference Manual.pdf) APL-11-Ref-Man.pdf - тут: https://archive.org/details/bitsaver...Jan80_68040338
>> and the APL11 installation guide at http://www.rsx11m.com/APL11ins.pdf
(AA-J794A-TC APL-11 Installation Guide, Release Note.pdf)
>> The RSX SIG files that have the info to change APL-11 to an I/D RSX11M+
>> task from RSX85A are also at [370,360] on the RL02 disk. I remember having
>> this work back in the mid-1980s but I have not been able to get it to work
>> today. If I link it with ODT it seems to blow up when the first overlay is
>> loaded. If anyone could help with that I’d really appreciate it!
так же copies of "The Special Character Set", the newsletter of the APL SIG. April 1985 (apapril1985.pdf) Page 10 & 13:
https://rsx11.blogspot.com/2019/07/m...er-issues.html
