Страница 104 из 112 ПерваяПервая ... 100101102103104105106107108 ... ПоследняяПоследняя
Показано с 1,031 по 1,040 из 1113
Тема: Софт для ДВК/PDP11
  1. #1031
    Одесса
    109
    75 сообщений
    По умолчанию APL-11 (for RSX and RSTS/E)
    Наткнулся на конференцию с исходниками АПЛ-11 для PDP-11
    > On 3/30/20 3:21 PM, Mark Matlock via cctech wrote:
    >> Bill (Gunshannon),
    >> The APL-11 files on DECUS RSX85A are not a complete distribution but a
    >> modified version that was intended to run under I/D on M+.
    >> I have the APL-11 V2.1 source files on a RL02 disk image. I will make it
    >> available at http://www.rsx11m.com/apl11.zip
    >> Once you mount the disk image with Simh, the are two ready to run task
    >> images that will run under RSX11M or M+
    >> In [201,200]APL6OK.TSK and APL7OK.TSK that are the REAL*4 and REAL*8
    >> versions of APL-11. On the disk are the
    >> Original .MAC sources as well as files from a RSX SIG tape that modified
    >> APL-11 for I/D under RSX11M+ that increased
    >> The workspace (.BXWA from ~3 to ~6 bytes). It also contains a
    >> character set for Vt220 for the APL character set.
    >> When you install the APL task experiment with the /INC to maximize the
    >> available workspace, On my system, I can
    >> INS APL6.TSK/INC=37000 to max the workspace for the single precision version.
    >> Also, the scanned APL-11 reference manual can be downloaded at
    >> http://www.rsx11m.com/APL-11-Ref-Man.pdf
    (AA-5076B-TC APL-11 Programmers Reference Manual.pdf) APL-11-Ref-Man.pdf - тут: https://archive.org/details/bitsaver...Jan80_68040338
    >> and the APL11 installation guide at http://www.rsx11m.com/APL11ins.pdf
    (AA-J794A-TC APL-11 Installation Guide, Release Note.pdf)
    >> The RSX SIG files that have the info to change APL-11 to an I/D RSX11M+
    >> task from RSX85A are also at [370,360] on the RL02 disk. I remember having
    >> this work back in the mid-1980s but I have not been able to get it to work
    >> today. If I link it with ODT it seems to blow up when the first overlay is
    >> loaded. If anyone could help with that I’d really appreciate it!
    так же copies of "The Special Character Set", the newsletter of the APL SIG. April 1985 (apapril1985.pdf) Page 10 & 13:
    https://rsx11.blogspot.com/2019/07/m...er-issues.html
    Этот пользователь поблагодарил anasana за это полезное сообщение:
    hobot(01.06.2020)
  2. #1032
    г. Караганда, Казахстан
    225
    177 сообщений
    17 Post(s)
    Коллеги, напомните, плз, была какая-то программуля, которая выдавала список всего, что найдется на странице ввода-вывода. Или что-то похожее...
  3. #1033
    г. Самара
    714
    596 сообщений
    https://zx-pk.ru/threads/31510-m8-i-...=1#post1054396
    AFZ(04.06.2020)
  4. #1034
    225
    177 сообщений
    17 Post(s)
    А где ее взять? Под RT-11...
  5. #1035
    г. Самара
    714
    596 сообщений
    Тряси Хобота - где то я у него находил, но соваться с очередной раз в его помойку желания нет.
    Мне чего то в ней не понравилось, тот вариант я грохнул, свой пока не дописан.
  6. #1036
    г. Красноярск
    369
    261 сообщений
    22 Post(s)
    https://mirrors.pdp-11.ru/search.php?text=+IOSCAN
    Все о БК ДВК УКНЦ VAX Alpha
    Архив ПО для ретрокомпьютеров
  7. #1036
  8. #1037
    Bryansk
    140
    107 сообщений
    Пойдет?
    ioscan-1.rar
    ioscan.mac
    ioscan.sav
    ioscan-2.rar
    ioscan.bin
    ioscan.bot
    ioscan.cmd
    ioscan.com
    ioscan.lda
    ioscan.mac
    iospp .mac
    iosrsx.mac
    iosrt .mac
    iosst .mac
    iosxdp.mac
    ioscan.pdp
    ioscan.ppu
    ioscan.sav
    ioscan.tsk
    iospos.tsk
    Последний раз редактировалось Arseny; 04.06.2020 в 18:54.
    Этот пользователь поблагодарил Arseny за это полезное сообщение:
    hobot(04.06.2020)
  9. #1038
    225
    177 сообщений
    17 Post(s)
    Всем спасибо, я передал СуперМаксу название, он тут же сам нашел. Просто мы не могли вспомнить, что именно надо искать.
  10. #1039
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    Обновление TTSET V5.1.
    Убрана проверка на наличее драйвера SL в TSX-Plus (там его нет в виде отдельного драйвера).
    DPUCI V01.00 - UCI для TSX-Plus, меняющий подсказку на имя устройства DK.
    .SET KMON UCI=SY:DPUCI
    AZ1>AS SY DK
    AZ0>AS AZ7 DK
    AZ7>AS LD0 DK
    ???>AS LD7 DK
    LD7>SH S
    LD7 --> AZ0:TSXTCP.DSK[4800]
    LD7>
    PMI: KDJ11-BF, MSV11-JE
    VT220, CM7209
    Этот пользователь поблагодарил form за это полезное сообщение:
    hobot(19.03.2021)
  11. #1040
    СССР, Новосибирск
    289
    233 сообщений
    30 Post(s)
    Обновление DATE V05.04.
    Теперь если программа запущена как detached job в TSX-Plus, запрос даты с терминала отключается.
    Это дает возможность запускать программу из DETACH.TSX при запуске системы без риска его завершения из-за попытки ввода с терминала.
    VT220, CM7209
    hobot(11.04.2021)
  1. Криста-2: Софт
    от fan в разделе Вектор
    Ответов: 53
    Последнее: 24.04.2009, 01:31
  2. Софт для Covox'а
    от BYTEMAN в разделе Софт
    Последнее: 30.07.2008, 11:53
  3. Софт под GS ?
    от AAA в разделе Софт
    Последнее: 13.03.2008, 17:08
  4. Софт для ПК
    от Ewgeny7 в разделе Утилиты
    Последнее: 13.07.2006, 11:30
  5. Софт под iS-dos
    от demon_zx в разделе Софт
    Последнее: 07.03.2006, 23:35
