163152
@10000/125252 12706
010002/125252 10000
010004/125252 12746
010006/125252 340
010010/125252 12746
010012/125252 10016
010014/125252 2
010016/125252 4567
010020/125252 14
010022/125252 105737
010024/125252 177560
010026/125252 100375
010030/125252 113703
010032/125252 177562
010034/125252 207
010036/125252 105737
010040/125252 177562
010042/125252 105737
010044/125252 177564
010046/125252 100375
010050/125252 112737
010052/125252 26
010054/125252 177566
010056/125252 12700
010060/125252 1000
010062/125252 5004
010064/125252 4715
010066/125252 110324
010070/125252 5300
010072/125252 1374
010074/125252 5007
@10000G
HX 2.0 - Warm boot v1.3 177560
HX DSK/TTY multiplexer v3.1 2014
SL V08.00 [SW] Сторожевых С.В. 1988
RT-11SP (Y) V05.04 G (01)
.SE USR NOSWAP
.SE EXIT NOSWAP
.SE TT SCOPE
.LO SL
.SE SL ON
.DAY
Время Дата
17:23:56 17-Июл-2014, Четверг
.SH ALL
Booted from HX0:RT11SP
USR is set NOSWAP
EXIT is set NOSWAP
KMON is set NOIND
TT is set NOQUIET
ERROR is set ERROR
SL is set ON
EDIT is set KED
KMON nesting depth is 3
PDP 11/23 Processor
256KB of memory
FP11 Hardware Floating Point Unit
Extended Instruction Set (EIS)
Memory Management Unit
50 Cycle System Clock
NO Terminal Interrupts
No SYSGEN options enabled
Device Status CSR Vector(s)
TT Installed 000000 000
SL 141076 000000 000
LD Installed 000000 000
HX Resident 177560 000
DZ Not installed 000000
HD Not installed 177720 000
TT
HX (Resident)
HX0 = DK , SY
SL (Loaded)
LD
20 free slots
Job Name Console Level State Low High Impure
0 RESORC 0 0 Run 000000 141024 N/A
No multi-terminal support
Address Module Words
160000 IOPAGE 4096.
156242 HX 431.
145406 RMON 2254.
141070 SL 1127.
131024 USR 2066.
001000 ..BG.. 22538.
No LD units mounted
