Для порта можно использовать преобразователь USB-TTL 5V.
Бинарник для прошивки Атмеги: Вложение 76842
Требуется кварц 16МГц и правильно выставить фьюзы.
В порт выводятся передаваемые клавиатурой сканкоды.
Вот исходник:
Код:#include <PS2KeyRaw.h>
#define AX0 4
#define AX1 5
#define AX2 6
#define AX3 7
#define AY0 8
#define AY1 9
#define AY2 10
#define RSTMT 14
#define CSMT 15
#define DATMT 16
#define STBMT 17
#define DATAPIN 2
#define IRQPIN 3
volatile boolean d = HIGH;
uint8_t table[128] = {127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,0,127,127,32,48,127,127,127,1,17,16,33,49,127,
127,3,2,18,34,51,50,127,127,112,4,19,36,35,52,127,127,115,116,100,20,84,68,127,127,127,114,99,83,67,66,127,
127,127,98,82,81,64,65,127,127,127,127,97,127,80,127,127,127,127,127,127,127,127,127,127,127,113,96,127,127,127,127,127,
127,127,127,127,127,127,64,127,127,127,127,52,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127};
PS2KeyRaw keyboard;
void setup() {
//Инициализация портов
pinMode(AX0, OUTPUT); //AX0
pinMode(AX1, OUTPUT); //AX1
pinMode(AX2, OUTPUT); //AX2
pinMode(AX3, OUTPUT); //AX3
pinMode(AY0, OUTPUT); //AY0
pinMode(AY1, OUTPUT); //AY1
pinMode(AY2, OUTPUT); //AY2
pinMode(RSTMT, OUTPUT); //RES
pinMode(CSMT, OUTPUT); //CS
pinMode(DATMT, OUTPUT); //DAT
pinMode(STBMT, OUTPUT); //STB
//Инициализация клавиатуры
keyboard.begin( DATAPIN, IRQPIN );
//Последовательный порт
Serial.begin(115200);
Serial.println("Speccy+");
//Инициализация MT8816
SetAddr(0);
digitalWrite(RSTMT, LOW);
digitalWrite(CSMT, LOW);
digitalWrite(DATMT, LOW);
digitalWrite(STBMT, LOW); //инициализация
digitalWrite(CSMT, HIGH); //выбор чипа
digitalWrite(RSTMT, HIGH);
digitalWrite(RSTMT, LOW); //сброс
SetAddr(table[0x12]);
SetKey(LOW);
void SetAddr(uint8_t addr) {
digitalWrite(AX0,bitRead(addr,0));
digitalWrite(AX1,bitRead(addr,1));
digitalWrite(AX2,bitRead(addr,2));
digitalWrite(AX3,bitRead(addr,3));
digitalWrite(AY0,bitRead(addr,4));
digitalWrite(AY1,bitRead(addr,5));
digitalWrite(AY2,bitRead(addr,6));
void SetKey(boolean data){
digitalWrite(STBMT, HIGH); //строб on
digitalWrite(DATMT, data); //данные
digitalWrite(STBMT, LOW); //строб off
void loop()
if( keyboard.available() ){
int c = keyboard.read(); //чтение кода
Serial.println(c); //печать в порт сканкода
switch (c) {
case 0xE0: //если считался префикс 0xE0
break;
case 0xF0: //если считался префикс 0xF0 (отпускание клавиши)
d = LOW;
break;
case 0x66: //если считался код 0x66 [BS]
SetKey(d);
SetAddr(table[0x45]);
SetKey(d);
d = HIGH;
break;
case 0x6B: //если считался код 0x6B [Left]
SetKey(d);
SetAddr(table[0x2E]);
SetKey(d);
d = HIGH;
break;
case 0x72: //если считался код 0x72 [Down]
SetKey(d);
SetAddr(table[0x36]);
SetKey(d);
d = HIGH;
break;
case 0x75: //если считался код 0x75 [Up]
SetKey(d);
SetAddr(table[0x3D]);
SetKey(d);
d = HIGH;
break;
case 0x74: //если считался код 0x74 [Right]
SetKey(d);
SetAddr(table[0x3E]);
SetKey(d);
d = HIGH;
break;
case 0x76: //если считался код 0x76 [Edit]
SetKey(d);
SetAddr(table[0x16]);
SetKey(d);
d = HIGH;
break;
case 0x58: //если считался код 0x58 [Caps lock]
SetKey(d);
SetAddr(table[0x1E]);
SetKey(d);
d = HIGH;
break;
case 0x0D: //если считался код 0x0D [Ext mode]
SetKey(d);
SetAddr(table[0x59]);
SetKey(d);
d = HIGH;
break;
case 0x41: //если считался код 0x41 [,]
SetKey(d);
SetAddr(table[0x31]);
SetKey(d);
d = HIGH;
break;
case 0x49: //если считался код 0x49 [.]
SetKey(d);
SetAddr(table[0x3A]);
SetKey(d);
d = HIGH;
break;
case 0x4C: //если считался код 0x4C [;]
SetKey(d);
SetAddr(table[0x44]);
SetKey(d);
d = HIGH;
break;
case 0x52: //если считался код 0x52 ["]
SetKey(d);
SetAddr(table[0x4D]);
SetKey(d);
d = HIGH;
break;
default:
SetAddr(table[c]);
SetKey(d);
d = HIGH;
