А на той, где играет, где тоже Вин7?
---------- Post added at 03:19 ---------- Previous post was at 03:14 ----------
В общем, звук играет через esiwave, wavepci и spdifoutwave.
а на встроенном HDA-audio нет - а это все новые встроенные звуковые
Судя по всему все дело в отсуствие pin'ов у устройств для вывода звука (сам не знаю, почему их пинами называют).
Сделал еще больше отладочной инфы в районе пинов:
Код:0.501: Entering RenderThreadProc
0.508: Device found
0.509: Instance succeeded
0.510: Total 2 pins found
0.510: Pin 0:
0.510: Communication = 1
0.511: Pin 1:
0.511: Communication = 0
0.511: Pin communication value doesn't make sense
0.511: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.512: No valid pins found on the filter
0.513: Pins not Enumerated
0.513: Failed to create filter for \\?\pci#ven_1102&dev_0004&subsys_00511102&rev_03#4&3029db9d&0&50f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\dmsynth
0.514: Instance succeeded
0.515: Total 2 pins found
0.515: Pin 0:
0.515: Communication = 1
0.516: Pin 1:
0.516: Communication = 0
0.516: Pin communication value doesn't make sense
0.516: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.517: No valid pins found on the filter
0.517: Pins not Enumerated
0.517: Failed to create filter for \\?\pci#ven_1102&dev_0004&subsys_00511102&rev_03#4&3029db9d&0&50f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\syntha
0.518: Instance succeeded
0.518: Total 2 pins found
0.518: Pin 0:
0.520: Communication = 1
0.521: Pin 1:
0.521: Communication = 0
0.521: Pin communication value doesn't make sense
0.521: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.521: No valid pins found on the filter
0.522: Pins not Enumerated
0.522: Failed to create filter for \\?\pci#ven_1102&dev_0004&subsys_00511102&rev_03#4&3029db9d&0&50f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\synthb
0.522: Failed to get requested DeviceInterfaceAlias
0.523: Instance succeeded
0.523: Total 4 pins found
0.523: Pin 0:
0.523: Communication = 1
0.524: Pin 1:
0.524: Communication = 0
0.524: Pin communication value doesn't make sense
0.524: Pin 2:
0.524: Communication = 1
0.525: Pin 3:
0.525: Communication = 0
0.525: Pin communication value doesn't make sense
0.525: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.525: No valid pins found on the filter
0.526: Pins not Enumerated
0.526: Failed to create filter for \\?\pci#ven_1102&dev_0004&subsys_00511102&rev_03#4&3029db9d&0&50f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\uart1
0.527: Instance succeeded
0.527: Total 5 pins found
0.527: Pin 0:
0.527: Communication = 1
0.528: Pin 1:
0.528: Communication = 0
0.528: Pin communication value doesn't make sense
0.528: Pin 2:
0.528: Communication = 1
0.529: Pin 3:
0.529: Communication = 0
0.529: Pin communication value doesn't make sense
0.530: Pin 4:
0.530: Communication = 1
0.530: RenderSink = 1, RenderSource = 0, CaptureSink = 1, CaptureSource = 0
0.530: Valid pins found on the filter
0.531: Pins Enumerated
0.531: Succeeded to create filter for \\?\pci#ven_1102&dev_0004&subsys_00511102&rev_03#4&3029db9d&0&50f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wavepci
0.531: Failed to get requested DeviceInterfaceAlias
0.532: Failed to get requested DeviceInterfaceAlias
0.533: Failed to get requested DeviceInterfaceAlias
0.534: Failed to get requested DeviceInterfaceAlias
0.535: All devices enumerated
0.536: Filters enumerated
0.536: Filter for rendering is avaliable
0.536: Total 1 filters
0.537: Pin for rendering is avaliable
0.538: Заполнение буфера 16-битным синусом
0.546: Pin state is KSSTATE_STOP
Win7 x64
Цитата:
0.500: Entering RenderThreadProc
0.512: Device found
0.513: Instance succeeded
0.513: Total 2 pins found
0.514: Pin 0:
0.514: Communication = 1
0.514: Pin 1:
0.515: Communication = 0
0.515: Pin communication value doesn't make sense
0.515: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.518: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_1458a 022&rev_1003#4&24707100&0&0201#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rearlineoutwave3
0.518: Failed to get requested DeviceInterfaceAlias
0.519: Failed to get requested DeviceInterfaceAlias
0.520: Failed to get requested DeviceInterfaceAlias
0.521: Failed to get requested DeviceInterfaceAlias
0.521: Instance succeeded
0.522: Total 2 pins found
0.522: Pin 0:
0.522: Communication = 1
0.523: Pin 1:
0.523: Communication = 0
0.526: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.526: No valid pins found on the filter
0.526: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_1458a 022&rev_1003#4&24707100&0&0201#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtspdifoptwave
0.527: Failed to get requested DeviceInterfaceAlias
0.528: Total 2 pins found
0.528: Pin 0:
0.528: Pin 1:
0.529: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.529: No valid pins found on the filter
0.530: Pins not Enumerated
0.530: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_1458a 022&rev_1003#4&24707100&0&0201#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtspdifwave
0.530: Failed to get requested DeviceInterfaceAlias
0.531: All devices enumerated
0.534: EnumFilters failed
0.534: Leaving RenderThreadProc
win7 max, sb live
пищит, пробовал первую и последнюю версию теста.
0.502: Entering RenderThreadProc
0.509: Device found
0.511: Failed to get requested DeviceInterfaceAlias
0.514: Total 2 pins found
0.515: Pin 0:
0.516: Pin 1:
0.517: Communication = 0
0.518: Pin communication value doesn't make sense
0.519: RenderSink = 1, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.524: Valid pins found on the filter
0.525: Pins Enumerated
0.526: Succeeded to create filter for \\?\pci#ven_1102&dev_0007&subsys_100a1102&rev_00#4 &e6d76c4&0&10f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\spdifwave
0.530: Instance succeeded
0.530: Total 4 pins found
0.531: Pin 0:
0.532: Communication = 1
0.533: Pin 1:
0.534: Communication = 0
0.535: Pin communication value doesn't make sense
0.536: Pin 2:
0.537: Communication = 1
0.538: Pin 3:
0.538: Communication = 0
0.542: Pin communication value doesn't make sense
0.556: RenderSink = 1, RenderSource = 0, CaptureSink = 1, CaptureSource = 0
0.557: Valid pins found on the filter
0.557: Pins Enumerated
0.558: Succeeded to create filter for \\?\pci#ven_1102&dev_0007&subsys_100a1102&rev_00#4 &e6d76c4&0&10f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
0.559: All devices enumerated
0.561: Filters enumerated
0.562: Filter for rendering is avaliable
0.562: Total 2 filters
0.565: Pin for rendering is avaliable
0.566: Заполнение буфера 16-битным синусом
0.573: Pin state is KSSTATE_STOP
6.846: Setting Pin to KSSTATE_RUN ...
6.848: Packet 0 is available... Submitting packet 0
6.851: Position = 0, Position2 = 280, Delta = 280
Я так понимаю, что эти устройства:
rearlineoutwave3 - задний линейный выход
rtspdifoptwave - spdif opt(?)
rtspdifwave - spdif
Но ни в одном из них нет RenderSink-пинов, позволяющих выводить звук.
---------- Post added at 11:37 ---------- Previous post was at 11:31 ----------
У тебя два устройства, позволяющие выводить звук - это spdifwave и wave. Он выбирает по умолчанию первое. Но вот дельта у spdif плохая - 280.
Еще один лог для Win 7 x64 ниже. После RUN при возврате фокуса после потери падает, дамп тут.
UPD: У меня интегрированная AC'97 (дефолтное аудиоустройство) и USB-гарнитура.
Код:0.503: Entering RenderThreadProc
0.519: Device found
0.523: Total 2 pins found
0.524: Pin 0:
0.525: Communication = 1
0.525: Pin 1:
0.526: Communication = 0
0.526: Pin communication value doesn't make sense
0.527: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.530: No valid pins found on the filter
0.531: Pins not Enumerated
0.532: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_104384fb&rev_1003#4&382096a2&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rearlineoutwave3
0.535: Failed to get requested DeviceInterfaceAlias
0.536: Failed to get requested DeviceInterfaceAlias
0.537: Instance succeeded
0.537: Total 2 pins found
0.538: Pin 0:
0.538: Communication = 1
0.539: Pin 1:
0.543: Communication = 0
0.544: Pin communication value doesn't make sense
0.544: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.545: No valid pins found on the filter
0.545: Pins not Enumerated
0.546: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_104384fb&rev_1003#4&382096a2&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtspdifoptwave
0.547: Failed to get requested DeviceInterfaceAlias
0.548: Instance succeeded
0.548: Total 2 pins found
0.549: Pin 0:
0.549: Communication = 1
0.550: Pin 1:
0.550: Communication = 0
0.551: Pin communication value doesn't make sense
0.551: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.552: No valid pins found on the filter
0.552: Pins not Enumerated
0.553: Failed to create filter for \\?\hdaudio#func_01&ven_10ec&dev_0892&subsys_104384fb&rev_1003#4&382096a2&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtspdifwave
0.553: Failed to get requested DeviceInterfaceAlias
0.554: Failed to get requested DeviceInterfaceAlias
0.556: DeviceInterfaceAlias disabled
0.557: Instance succeeded
0.557: Total 5 pins found
0.557: Pin 0:
0.558: Communication = 1
0.558: Pin 1:
0.558: Communication = 3
0.559: Pin 2:
0.559: Communication = 4
0.559: Pin communication value doesn't make sense
0.559: Pin 3:
0.560: Communication = 4
0.560: Pin communication value doesn't make sense
0.560: Pin 4:
0.561: Pin communication value doesn't make sense
0.561: RenderSink = 1, RenderSource = 1, CaptureSink = 1, CaptureSource = 0
0.561: Valid pins found on the filter
0.561: Pins Enumerated
0.562: Succeeded to create filter for \\?\usb#vid_047f&pid_aa15&mi_00#8&30b5d44&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
0.562: All devices enumerated
0.563: Filters enumerated
0.563: Filter for rendering is avaliable
0.563: Total 1 filters
0.564: Pin for rendering is avaliable
0.564: Заполнение буфера 16-битным синусом
0.569: Pin state is KSSTATE_STOP
3.795: Setting Pin to KSSTATE_RUN ...
3.800: Packet 0 is available... Submitting packet 0
Могу, только, ответить цитатой из datsheet на ALC892:
Цитата:
Hardware Features
- DACs with 95dB SNR (A-weighting), ADCs with 90dB SNR (A-weighting)
- Ten DAC channels support 16/20/24-bit PCM format for 7.1 channel sound playback, plus 2 channels of concurrent independent stereo sound output (multiple streaming) through the front panel output
- Two stereo ADCs support 16/20/24-bit PCM format, multiple stereo recording
- All DACs supports 44.1k/48k/96k/192kHz sample rate
- All ADCs supports 44.1k/48k/96k/192kHz sample rate
- Primary 16/20/24-bit SPDIF-OUT supports 32k/44.1k/48k/88.2k/96k/192kHz sample rate
- Secondary 16/20/24-bit SPDIF-OUT supports 32k/44.1k/48k/88.2k/96k/192kHz sample rate
- 16/20/24-bit SPDIF-IN supports 44.1k/48k/96k/192kHz sample rate
- All analog jacks (port-A to port-G) are stereo input and output re-tasking
- Port-D/E/F built-in headphone amplifiers
- Port-B/C/E/F with software selectable boost gain (+10/+20/+30dB) for analog microphone input
- High-quality analog differential CD input
- Supports external PCBEEP input and built-in digital BEEP generator
- Software selectable 2.5V/3.2V/4.0V VREFOUT
- Up to four channels of microphone array input are supported for AEC/BF applications
- Three jack detection pins; each designed to detect up to 4 jacks
- Supports legacy analog mixer architecture
- Up to two GPIOs (General Purpose Input and Output) for customized applications. GPIO0 and GPIO1 share pin with DMIC-CLK and DMIC-DATA
- Supports mono and stereo digital microphone interface (pins shared with GPIO0 and GPIO1)
- Supports anti-pop mode when analog power LDO-IN is on and digital power is off
- Content Protection for Full Rate lossless DVD Audio, Blu-ray DVD, and HD-DVD audio content playback (with selected versions of WinDVD/PowerDVD/TMT)
- 1dB per step output volume and input volume control
- Supports 3.3V digital core power, 1.5V or 3.3V digital I/O power for HD Audio link, and 5.0V analog power
- Intel low power ECR compliant and power status control for each analog/digital converter and pin widget
- 48-pin LQFP ‘Green’ package
Software Features
- Meets Microsoft WLP 3.x and future WLP audio requirements
- WaveRT-based audio function driver for Windows Vista and Windows 7
- Direct Sound 3D™ compatible
- I3DL2 compatible
- 7.1+2 channel multi-streaming enables concurrent gaming/VoIP
- Emulation of 26 sound environments to enhance gaming experience
- Multiband software equalizer and tools provided
- Voice Cancellation and Key Shifting effect
- Dynamic range control (expander, compressor, and limiter) with adjustable parameters
- Intuitive Configuration Panel (Realtek Audio Manager) to enhance user experience
- Microphone Acoustic Echo Cancellation (AEC), Noise Suppression (NS), and Beam Forming (BF) technology for voice applications
- Smart multiple streaming operation
- HDMI audio driver for AMD platform
- Optional Dolby PCEE program, SRS TruSurround HD, SRS Premium Sound, Fortemedia SAM, Creative Host Audio, Synopsys Sonic Focus, DTS Surround Sensation | UltraPC, and DTS Connect licenses
win7 x64 звук via
Цитата:
0.515: Entering RenderThreadProc
0.515: Device found
0.515: Failed to get requested DeviceInterfaceAlias
0.515: Instance succeeded
0.515: Pin 0:
0.515: Pin 1:
0.515: No valid pins found on the filter
0.531: Failed to create filter for \\?\hdaudio#func_01&ven_1106&dev_0397&subsys_10438 415&rev_1000#4&16c93ada&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\ehdmioutwave
0.531: Instance succeeded
0.531: Total 2 pins found
0.531: Pin 0:
0.531: Communication = 1
0.531: Pin 1:
0.531: Communication = 0
0.546: Pin communication value doesn't make sense
0.546: RenderSink = 0, RenderSource = 0, CaptureSink = 0, CaptureSource = 0
0.546: No valid pins found on the filter
0.546: Pins not Enumerated
0.546: Failed to create filter for \\?\hdaudio#func_01&ven_1106&dev_0397&subsys_10438 415&rev_1000#4&16c93ada&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\eslavedhplineoutwave
0.546: All devices enumerated
0.546: EnumFilters failed
0.546: Leaving RenderThreadProc
Логи теста?
С другими эмулями сравнивать не надо, у них иной принцип, есичо)
---------- Post added at 13:37 ---------- Previous post was at 13:32 ----------
Похоже, ему не нравится USB-гарнитура. Он его опознает, как USB global (почему такое название?), считает, что через это можно выводить и где-то спотыкается.
