Цитата:
Читаем страницы 1-1 и 1-2 User Manual and Development Kit:
1.2 Protocol Support
The XPort™ uses the Internet Protocol (IP) for network communications and the Transmission Control Protocol (TCP) to assure that no data is lost or duplicated, and that everything sent to the connection arrives correctly at the target.
Other supported protocols are listed below:
ARP, UDP, TCP, ICMP, Telnet, TFTP, AutoIP, DHCP, HTTP, and SNMP for network communications and management.
TCP, UDP, and Telnet for connections to the serial port.
TFTP for firmware and web page updates.
IP for addressing, routing, and data block handling over the network.
User Datagram Protocol (UDP) for typical datagram applications in which devices interact with other devices without maintaining a point-to-point connection.
SMTP for e-mail transmission.
Специально для вас еще раз объясняю, фраза:
