Что такое корка?
Что такое корка?
Ewgeny7,угу в свободном доступе, точно нет. Ну где взять железку известно.
BYTEMAN, http://opencores.org/projects
дабы не мнгогословить
BYTEMAN, можно вообщем то и так сказать:)
I'm thinking of adding the SID support to Speccy 2010. Could you give me the link with a Spectrum test program/player of any kind and schematics/info how the SID is connected to the bus? Thanks.
Hi! Current version of SID-Card is not final. We want to add a real 6502 to the card. But if you wish to add current version, look at this post (the latest version of player). SID is connected to the bus at #xxCF ports array (where xx corresponds to SID address inputs). But we recommend you to wait until we'll release a final "standardized" version of card. Thanks.
зы. Ну как, неплохо у меня с английским?
We used this version of player. This player uses ports of ZS-Scorpion 256 Turbo+. This player makes RAM to appear instead of ROM page to have continuous array of memory.
BYTEMAN,
Thanks a lot. Finally it seems to be working. First of all I had to implement the Scorpion memory map - done. Then to check the port mapping to not overlap with SamCoupe. But finally I DID it. Works like a charm...ok it just works with 14 and 28MHz clock ;)
The drwaback is that the SID emulation is lacking the filters so the sound is kinda harsh....
