Страница 23 из 24 ПерваяПервая ... 192021222324 ПоследняяПоследняя
Показано с 221 по 230 из 233
Тема: Подключение SID'а к Спектруму
  1. #221
    Брест/Минск
    124
    62 сообщений
    Что такое корка?
    С уважением, Александр.
    SID-Blaster/ZX
  2. #222
    Архангельск
    13
    13 сообщений
    Ewgeny7,угу в свободном доступе, точно нет. Ну где взять железку известно.
    BYTEMAN, http://opencores.org/projects
    дабы не мнгогословить
  3. #223
    Брест/Минск
    124
    62 сообщений
    Софтверное ядро имеется ввиду?
    SID-Blaster/ZX
  4. #224
    Архангельск
    13
    13 сообщений
    BYTEMAN, можно вообщем то и так сказать
  5. #225
    Zielona Gora, Poland
    I'm thinking of adding the SID support to Speccy 2010. Could you give me the link with a Spectrum test program/player of any kind and schematics/info how the SID is connected to the bus? Thanks.
  6. #226
    Брест/Минск
    124
    62 сообщений
    Hi! Current version of SID-Card is not final. We want to add a real 6502 to the card. But if you wish to add current version, look at this post (the latest version of player). SID is connected to the bus at #xxCF ports array (where xx corresponds to SID address inputs). But we recommend you to wait until we'll release a final "standardized" version of card. Thanks.
    зы. Ну как, неплохо у меня с английским?
    SID-Blaster/ZX
  7. #226
  8. #227
    Thanks BYTEMAN. I've been able to connect the SID model to the Speccy with #xxCF ports (15-13 set to any value). I can write simple commands to get the sound but none of the SID Player demos works. Which ports are the using?
  9. #228
    Брест/Минск
    124
    62 сообщений
    We used this version of player. This player uses ports of ZS-Scorpion 256 Turbo+. This player makes RAM to appear instead of ROM page to have continuous array of memory.
    SID-Blaster/ZX
  10. #229
    BYTEMAN,
    Thanks a lot. Finally it seems to be working. First of all I had to implement the Scorpion memory map - done. Then to check the port mapping to not overlap with SamCoupe. But finally I DID it. Works like a charm...ok it just works with 14 and 28MHz clock
    The drwaback is that the SID emulation is lacking the filters so the sound is kinda harsh....
  11. #230
    г. Рубцовск, Алтайский край
    Нашел я тут немного времени, прикрутил SID к анрилу (плюс убил пару багов). Результат *****кодинга (в комплекте несколько сидовых мелодий, в папке sids):
    http://narod.ru/disk/2419223001/us03...(sid).rar.html
    Тут SID сидит на порте xxCF, в старшем байте - номер регистра. Насчет конфликтов пока не думал.
    Перезалейте
  1. Литература по Спектруму
    от scooter в разделе Барахолка (архив)
    Последнее: 08.01.2011, 13:23
  2. Спектруму 28 лет.
    от Rindex в разделе Поздравления
    Последнее: 28.04.2010, 15:44
  3. Как подключить дисководы от PC к спектруму?
    от dhau в разделе Внешние накопители
    Ответов: 22
    Последнее: 23.09.2005, 19:41
