DDp, интересная утилита для расчета контрольных сумм Лешего. TZX-ы с ее помощью создавались? То-есть уже нет проблем с записями по схеме 'Леший'?
I have Byte computer with 2 oryginal cassetes and 1 other Церикопик cassete. Does anyone other cassetes with Церикопик?
Yes, I know. Try make WAV from my casette but this is very trouble :-(. I was able to record to WAV and LOAD to Spectaculator (over Virtual Audio Cable) with Winamp 5 (EQ ON 60Hz full) but not able load this to Compress Copy (L) (Parity)
I convert to 22050Hz 8Bit Mono but Spectaculator wrong loading screen. If take load from Winamp with EQ some setting - all game La Formica loading OK :-) OK, I attach game (WAV) La Formica. Please help to make TAP from this :-)
La Formica WAV
Содержание кассеты:Скрытый текст
000_TAPE HEAD.tap 648
001_SEYMOUR TAKE ONE[CSL and F.C.A. 1992].tap 32265
002_SPEED DUEL.tap 25448
003_ZAXXON [Protected by SPEEDLOCK].tap 49887
004_Turbo Compress Copy [installed by Kato 1988].tap 2464
005_KRAKOUT [NICOLAS RODIONOV].tap 49461
Архив с кассетой(78 Кб):
ftp://anonymous@ftp.zxtapes.ru/LAS/cass02122012.zip
Link fixed :-) La Formica WAV
P.S. Converted to 22050Hz 8bit Mono working in Spectaculator 7.51 (opened directly WAV i menu file) working loading screen but only if disable some option Cassette Recorder in Spectaculator:
Fast loading, Flashloading and Edge detection
Copy-Copy can not load block screens and Tape error :-(
снова итальянцы. журнал №3 http://zxspectrum.hal.varese.it/lnr.php
только у тебя похоже более полная версия (с картинкой)
OK. I make WAV file 44100Hz, 8bit mono to open in Spectaculator. This working OK :-) But how convert this to TZX? This link is WAV and RZX file: La Formica
