mrcity, AFZ says, that MS-7004 is an exact (up to scan code) copy of lk201, therefore the documentation lk201 is quite suitable for working with MS-7004
А это кстати, интересный вопрос. Я экспериментировал с эмуляцией МС 7105 (клон VT240) в MAME, и его прошивка работает с клавиатурой как с LK201. Если в него "воткнуть" 7004, на старте возникает ошибка клавиатуры. То ли с терминалом шла другая клавиатура (не 7004), то ли прошивка была другой.
Сравните
Код:ms0515 init
[:] 4.824093 > a7 (247) beep
[:] 4.824149 > 11 (021) turn on LED "Lat"
[:] 4.826337 > 90 (220) -//-
[:] 8.612525 < 00 (000)
[:] 8.612544 > ab (253) LK_CMD_REQ_ID
[:] 8.616721 < 01 (001) - expected response
[:] 8.620294 < 00 (000) - expected response
[:] 8.620343 > 11 (021) turn on LED "Lat"
[:] 8.620368 > 90 (220) -//-
mc7105 init
[:] 0.000092 < 00 (000)
[:] 0.000092 > 13 (023) LK_LED_ENABLE
[:] 0.000109 < 00 (000)
[:] 0.000109 > 8f (217) - all LEDs
[:] 0.002501 < 00 (000)
[:] 0.002501 > 8f (217) ???
[:] 0.162661 < 00 (000)
[:] 0.162661 > 11 (021) LK_LED_DISABLE
[:] 0.162677 < 00 (000)
[:] 0.162677 > 8f (217) - all LEDs
[:] 0.165069 < 00 (000)
[:] 0.165069 > 13 (023) LK_LED_ENABLE
[:] 0.167291 < 00 (000)
[:] 0.167291 > 83 (203) - Wait+Compose
[:] 0.327827 < 00 (000)
[:] 0.327827 > 13 (023) LK_LED_ENABLE
[:] 0.327844 < 00 (000)
[:] 0.327844 > 8f (217) - all
[:] 0.330236 < 00 (000)
[:] 0.330236 > 8f (217) ???
[:] 2.311962 < 00 (000)
[:] 2.311962 > 00 (000)
[:] 2.312007 < 00 (000)
[:] 2.312007 > aa (252) ??
[:] 2.314368 < 00 (000)
[:] 2.314368 > ff (377) ??
[:] 3.378832 < 00 (000)
[:] 3.378832 > 11 (021) LK_LED_DISABLE
[:] 3.378849 < 00 (000)
[:] 3.378849 > 80 (200) - all? LEDs
[:] 6.099093 < 00 (000)
[:] 6.099093 > 13 (023) LK_LED_ENSABLE
[:] 6.099110 < 00 (000)
[:] 6.099110 > 8f (217) - all LEDs
[:] 6.101502 < 00 (000)
[:] 6.101502 > 8f (217) ???
[:] 12.730418 < 00 (000)
[:] 12.730418 > a7 (247) beep
[:] 12.730435 < 00 (000)
[:] 12.730435 > a7 (247) beep
[:] 13.766876 < 00 (000)
[:] 13.766876 > fd (375) LK_CMD_POWER_UP
[:] 13.771092 < 01 (001)
[:] 13.772332 < 01 (001)
[:] 13.772332 > 13 (023)
[:] 13.772397 < 01 (001)
[:] 13.772397 > 90 (220)
[:] 13.774669 < 00 (000)
[:] 13.778243 < 00 (000)
[:] 13.781815 < 00 (000)
[:] 13.783312 < 00 (000)
[:] 13.783312 > 0a (012)
[:] 13.783377 < 00 (000)
[:] 13.783377 > 81 (201)
[:] 13.785644 < 00 (000)
[:] 13.785644 > 12 (022)
[:] 13.787862 < 00 (000)
[:] 13.787862 > 82 (202)
[:] 13.790079 < 00 (000)
[:] 13.790079 > 1a (032)
[:] 13.792296 < 00 (000)
[:] 13.792296 > 81 (201)
[:] 13.794515 < 00 (000)
[:] 13.794515 > 22 (042)
[:] 13.796731 < 00 (000)
[:] 13.796731 > 81 (201)
[:] 13.798949 < 00 (000)
[:] 13.798949 > a8 (250)
[:] 13.801169 < 00 (000)
[:] 13.801169 > b6 (266)
[:] 13.803386 < 00 (000)
[:] 13.803386 > 3a (072)
[:] 13.805629 < 00 (000)
Я не очень хорошо знаю, что там чем у DEC комплектовалось. Родной DEC'овский драйвер PI.SYS принимает нашу 7004 как свою, отсюда, по крайней мере, следует то, что 7004 совпадает с тем, чем комплектовались DEC PRO 350, с которой цельноутянута наша Э-85.
Кстати, у LK201 под 0 под 2) есть "секретная" клавиша :):
https://yadi.sk/d/_lyVyOni3YicXm
https://thumbs.worthpoint.com/zoom/i...7cb6d4d6e8.jpg
Hello!
You can boot from the hard drive by giving commands:It is much easier to translate the codes through the keyboard emulator. http://zx-pk.ru/threads/23119-emulya...l=1#post697539Код:@B
$DW[ВК]
At the same time, one should take into account that in real time it will most likely not be possible to control the computer, since the video signal transmission will be transmitted with a delay.
Я помню, как в прошлом исследовал код MAME для MS7004, и он, похоже, не сказал мне коды сканирования простым способом. Мне придется исследовать этот «секретный ключ», и, надеюсь, мой эмулятор доставит его. ;)
Разумно заметить, что видеосигнал может иметь такую задержку, что было бы невозможно эффективно управлять компьютером. Моя надежда состояла в том, чтобы получить услугу с очень низким временем пинга, по крайней мере для пользователей в этом регионе. «Twitch» - это сервис, который я бы попробовал, поскольку геймеры используют его для потоковой передачи. Или, может быть, мой видеоролик будет небольшим, скажем, 0,3 мегапикселя. Все это подвержено экспериментам. Надеюсь, я смогу найти то, что работает.
Но говоря о вещах, которые не работают, это будет включать в себя мои ...
:v2_lol: На самом деле я не тестировал накопитель, но вставка карты контроллера КЖД заставляет компьютер полностью волноваться. Это либо покажет ошибки памяти, как это (с первого раза я попробовал):
http://i.imgur.com/4DL7OSm.jpg
... или он напечатает кучу мусора на экране, как это (с самого последнего времени, когда я это пробовал):
http://i.imgur.com/tUSnTQ2.jpg
Я не вижу никаких физических дефектов на плате контроллера. Но есть также вероятность, что диск полностью измельчен, если головы не припаркованы, прежде чем отправиться в путешествие примерно 9000 км. Тем не менее, это забавная вещь, чтобы gawk в в его текущем состоянии.
T4 RAM test writes about the presence of errors.
( Т4 тест ОЗУ пишет о наличии ошибок. )
To restore the RAM, it is necessary to change all KR565RU5V to 4164 ( KR565RU5A ) with a sampling time of not more than 80 ns.
( Для восстановления работы ОЗУ необходимо сменить все КР565РУ5В на 4164 ( КР565РУ5А ) с временем выборки не более 80 нс.)
Defect RAM in MC1201.03 is associated with the monstrous alcoholization of the developer of this micro-computer.
( Дефект ОЗУ в МС1201.03 связан с чудовищной алкоголизацией разработчика этой микро-ЭВМ.:v2_dizzy_vodka: )
Дело в том что сама веб камера может транслировать с задержкой. Для того чтобы передать изображение с веб камеры надо:
1)записать кадр с матрицы в буферную память.
2)из буферной памяти обработать кодеком (сжать).
3)передать по протоколу ТСР/IP.
И нужно учитывать что требуется передавать не менее 50 кадров в секунду.
Примерно так.
При этом нужно настроить сам кодек передачи изображения на максимальное быстродействие.
Смотрите сигнал готовности после включения. https://en.wikipedia.org/wiki/ST-506
