Дык, а что мешает мышиный энкодер приделать?
В продаже (да и в мышиных донорах) их полно самых разных размеров, колесико только придумать надо и шестигранную втулку, тогда весь девайс можно будет вообще в ультра-слим факторе забабахать :)
FlashFloppy v2.11a (Experimental) - 23 May 2019
* Simpler bootloader update process with all-in-one update file
* FF.CFG: sort-priority= to prioritise folders vs files during navigation
- Default: Folders are listed before files
https://github.com/keirf/FlashFloppy...ppy-v2.11a.zip
FlashFloppy v2.12 - 2 June 2019
* HFEv3: Support flaky/weak bytes
* LCD/OLED: Improve power-on initialisation robustness
* Roland: Direct support for *.OUT images
* IO-Test: New alternative firmware to test Gotek I/O pins
- https://github.com/keirf/FlashFloppy...esting-IO-Pins
https://github.com/keirf/FlashFloppy...oppy-v2.12.zip
FlashFloppy v2.13 - 7 June 2019
* HFE: Fix read buffering error
* Update HxC Compat to v6-FF
- More robust error checking on writes
https://github.com/keirf/FlashFloppy...oppy-v2.13.zip
FlashFloppy v3.0a (Experimental) - 10 June 2019
* Disk Change Reset: Emulate explicit Reset signal of certain vintage drives
- Requires a hardware modification and FF.CFG: chgrst=pa14
* Support ZHONGJY_TECH 2.23" 128x32 displays based on SSD1305 controller
- FF.CFG: display-type=oled-128x32-ztech
https://github.com/keirf/FlashFloppy...oppy-v3.0a.zip
FlashFloppy v3.1a (Experimental) - 13 June 2019
* OLED: Text height and content can be configured (FF.CFG: oled-text=)
- New default for 128x64 displays presents a new third text row
* LCD/OLED: Present an action menu when an image is ejected
- Includes Clone and Delete Image operations
https://github.com/keirf/FlashFloppy...oppy-v3.1a.zip
ухитрился воткнуть шлейф наоборот, а эмуль (FlashFloppy) это определил
на oled экране появилась надпись что шлейф возможно перевернут.
FlashFloppy v3.2a (Experimental) - 25 June 2019
* OLED: New default layout for 128x64 displays
* LCD: Support 20x4 character displays
* LCD: Row ordering is configurable
- FF.CFG: Rename oled-text= to display-order= to reflect this
* Eject menu: Confirmation required for Delete/Clone operations
* Trackball: Reduce jitteriness by adding simple inertia
https://github.com/keirf/FlashFloppy...oppy-v3.2a.zip
FlashFloppy v3.3a (Experimental) - 8 July 2019
* FF.CFG: New Disk-Change Reset option: chgrst=delay-N
- Automatically clears the DSKCHG signal Nx0.5s after disk insertion
- chgrst=delay-3 fixes Disk Change on Ensoniq EPS synths
* Change head-step signal handling to reduce interrupt rate
* OLED/LCD: Fix current-folder display line for image-on-startup=init|static
- image-on-startup=static: Please note the static image is now specified in INIT_A.CFG
https://github.com/keirf/FlashFloppy...oppy-v3.3a.zip
Тоже думал о подобном. Но вся эта конструкция вместе с кликером и самим колесом внутри устройства сильно габаритным будет, не вместится (хотя снаружи и аккуратно).
Но потом увидел вот такие штуки:
https://ru.aliexpress.com/item/32734389584.html https://ru.aliexpress.com/item/32805593559.html (SIQ-02FVS3 / SIQ-02FV)
Тут с 4мя контактамии я не уверен что он как кликер может работать. Энкодер+кликер.
Спецификации: https://www.mitsumi.co.jp/latest/Catalog/compo/switch/
Datasheet на английском http://pdf-file.ic37.com/pdf5/MITSUM..._datasheet.pdf
Также есть 6тиконтактный:
https://ru.aliexpress.com/item/33051910087.html (EVQWKL001)
https://ru.aliexpress.com/item/33049515970.html (EVQWKA001)
Они к сожалению все для SMD монтажа, и их полагается плашмя к плате припаивать... ну вообще колесо так и так как-то надо закреплять...
спецификации: https://datasheet.octopart.com/EVQ-W...t-15230683.pdf
А есть вообще вот такие, не дешевые, но весьма симпатичные (меньше чем по 2 штуки к сожалению не продают):
https://ru.aliexpress.com/item/32990950196.html (EVQWGD001)
Никто в этом направлении еще экспериментов не проводил? По-моему может получиться получше, чем с blackberry trackball, и существенно аккуратнее торчащей крутилки.
