C:\Share>maketzx.exe "Sound 4.wav" -lf -fo -ft3
-=[ MakeTZX v2.31 ]=- (C) 1998-2001 RAMSOFT, a ZX Spectrum demogroup.
■ Checking input file... ok!
■ RIFF Wave PCM (WAV), 14262012 samples.
■ Sampling rate: 44100 Hz (playing time: 05:23.401)
■ Digital filter: Butterworth low-pass 4100.00 Hz, order 2
■ Operating in SOFTLOCK mode
Block 1 => Program: E L I T E - Header: Length= 17, Pause=1015ms.
Block 2 => ------------------- - Line= 0, Length= 387, Pause=3782ms.
Block 3 => Softlock Block - Multiple sub-blocks sequence starting
-->Sub-block 1 ! Start=16384, Length= 7168
Block 3 => Block End - Total Length=7171, Pause=190065ms.
■ Auto-detection enabled
■ Operating in RAW mode
Block 4 => F:127 - Speed: 100% F Chk=ERR ( 97), Length= 1646, Pause=0ms.
Block 5 => F: 20 - Speed: 100% F Chk=ERR ( 47), Length= 1053, Pause=97391548ms.
Block 6 => F: 0 - Speed: 127% - Chk=OK! ( 1), Length= 720, Pause=1313ms.
Done!
