Страница 5 из 23 ПерваяПервая 123456789 ... ПоследняяПоследняя
Показано с 41 по 50 из 229
Тема: Написание программ для БК0010
  1. #41
    г. Самара
    714
    596 сообщений
    Вот так правильней
    ; Input: R3
    		MOV	#6,R0
    		MOV	#<DecStr+6>,R1
    1$:
    		CLR	R2
    		DIV	#10.,R2
    ;		INC	R3
    		ADD	#'0, R3
    		MOVB	R3,-(R1)
    		MOV	R2,R3
    		SOB	R0,1$
  2. #42
    178
    138 сообщений
    21 Post(s)
    Вот так правильней
    согласен
  3. #43
    г. Самара
    714
    596 сообщений
    А теперь классика:
    ; CVBTOD
    ;	Converts the binary value passed in R0 to a string of
    ;	ascii characters which is the decimal equivalent and
    ;	places them in the buffer pointed to by R1
    ; CALL:
    ;	R0 =  16-bit number
    ;	R1 -> conversion buffer
    ; RETURNS:
    ;	R0 = 0
    ;	R1 -> byte following last digit in converted number
    CVBTOD:	MOV	R0,-(SP)	;SAVE THE NUMBER PASSED TO US
    	CLR	R0		;SET FOR CRUDE DIVIDE BY 10.
    10$:	INC	R0		;BUMP QUOTIENT
    	SUB	#10.,(SP)	;REDUCE NUMBER BY 10.
    	BHIS	10$		;IF SIGN DIDN'T CHANGE...
    	ADD	#10.+60,(SP)	;MAKE REMAINDER PRINTABLE
    	DEC	R0		;REDUCE QUOTIENT
    	BEQ	20$		;IF ZERO, TIME TO PRINT
    	CALL	CVBTOD		;OTHERWISE, RECURSE !
    20$:	MOVB	(SP)+,(R1)+	;STORE A CONVERTED DIGIT
    	RETURN			;UNWIND THE RECURSION
    TEST	MACRO V05.06R Tuesday 04-Jun-19  Page 1
         12	000000					.PSECT A1
         13					; Decimal by Manwe
         14					; input:  R0 - number to print
         15					; output: R1 - pointer to text string
         17	000000	012701 	000046'		DECIM:  MOV #NUMBER,R1 ; pointer to output text string
         18	000004	105041 			        CLRB -(R1)     ; end of text marker
         19	000006	012704 	000012 		        MOV #10.,R4
         20	000012	012705 	177777 		10$:    MOV #-1.,R5
         21	000016	005205 			20$:    INC R5         ; counter of 10s
         22	000020	160400 			        SUB R4,R0
         23	000022	103375 			        BHIS 20$       ; branch if higher or same
         24	000024	062700 	000072 		        ADD #72,R0     ; #10. + '0' ASCII code
         25	000030	110041 			        MOVB R0,-(R1)  ; store R0 to text string
         26	000032	010500 			        MOV R5,R0      ; let's count next how many 10s in number of 10s
         27	000034	001366 			        BNE 10$
         28	000036	000207 			        RETURN         ; returns text string pointer in R1
         29
         30	000040				.BLKB 6
         31	000046				NUMBER:
         32
         33	000000					.PSECT A2
         34	000000	010046 			CVBTOD:	MOV	R0,-(SP)	;SAVE THE NUMBER PASSED TO US
         35	000002	005000 				CLR	R0		;SET FOR CRUDE DIVIDE BY 10.
         36	000004	005200 			10$:	INC	R0		;BUMP QUOTIENT
         37	000006	162716 	000012 			SUB	#10.,(SP)	;REDUCE NUMBER BY 10.
         38	000012	103374 				BHIS	10$		;IF SIGN DIDN'T CHANGE...
         39	000014	062716 	000072 			ADD	#10.+60,(SP)	;MAKE REMAINDER PRINTABLE
         40	000020	005300 				DEC	R0		;REDUCE QUOTIENT
         41	000022	001402 				BEQ	20$		;IF ZERO, TIME TO PRINT
         42	000024	004767 	177750 			CALL	CVBTOD		;OTHERWISE, RECURSE !
         43	000030	112621 			20$:	MOVB	(SP)+,(R1)+	;STORE A CONVERTED DIGIT
         44	000032	000207 				RETURN
    Со счётом 40:34 победил автор из DEC (и это я ещё не засчитал буфер и не возможность разместить в ПЗУ)
    Как видно, в DEC знали про этот подход или у них был свой Дженсен
  4. #44
    1,473
    525 сообщений
    20 Post(s)
    Для комплекта ещё - вариант из Stop the Express для MS-0515.
    Но на самом деле тут в конце приписан ещё лишний нолик, потому что выводятся заработанные очки.
    Точку входа Z34420 можно использовать для печати 3-значного числа.
    ; Подпрограмма: Печать 5-значного десятичного числа; R3=число
    Z34400: MOV	#023420, R2		; 10000.
    Z34404: CALL	Z34454			;
    Z34410: MOV	#001750, R2		; 1000.
    Z34414: CALL	Z34454			;
    Z34420: MOV	#000144, R2		; 100.
    Z34424: CALL	Z34454			;
    Z34430: MOV	#000012, R2		; 10.
    Z34434: CALL	Z34454			;
    Z34440: ADD	#000060, R3		; '0'
    Z34444: MOVB	R3, (R1)+		;
    Z34446: MOVB	#000060, (R1)+		;
    Z34452: RETURN				;
    Z34454: MOV	#000060, R0		; '0'
    Z34460: SUB	R2, R3			;
    Z34462: BLO	Z34470			;
    Z34464: INC    	R0			;
    Z34466: BR     	Z34460			;
    Z34470: ADD	R2, R3			;
    Z34472: MOVB	R0, (R1)+		; копируем в экран план
    Z34474: RETURN
    Последний раз редактировалось nzeemin; 05.06.2019 в 11:46.
  5. #45
    406
    257 сообщений
    Плохо жить без DIV
    Кто запустил УКНЦшников в тему БК-0010?!!
    А в чём "невозможность" размещения в ПЗУ? Буфер текстовой строки - это любое место в ОЗУ.
    И зачем было считать за часть программы занесение адреса текстового буфера в R1, если в другой программе он не считается?
    Ещё они не заносят в текстовый буфер символ конца строки (0). Если из моей программы убрать и это, она станет на одно слово короче DECовской. Тогда получится 13:14 в мою пользу!
    ; Decimal by Manwe
    ;         R1 - pointer to text buffer + 6
    ; output: R1 - pointer to the text to print
    DECIM:  CLRB -(R1)     ; end of text marker
            MOV #10.,R4
    1:      MOV #-1.,R5
    2:      INC R5         ; counter of 10s
            SUB R4,R0
            BHIS 2         ; branch if higher or same
            BNE 1
            RET            ; returns text string pointer in R1
    Так-то идея с рекурсией прикольная, респект. Но с практической точки зрения там много операций со стеком, что сказывается на производительности. Этот алгоритм и без того тормозной, так ещё и усугублять постоянными обращениями к (SP)... Наверное, целью было сэкономить регистры любой ценой.
    Естественно, "в DEC был свой Дженсен" - несколько хакеров из MIT перешли на работу в DEC. Собственно, они повлияли на само становление архитектуры PDP-1.
    Последний раз редактировалось Manwe; 05.06.2019 в 19:07.
    manwe.pdp-11.ru
  6. #46
    406
    257 сообщений
    Вариант из Stop the Express занимает 31 слово (в десятичной системе счисления).
    Я делал быстрый (без CALLов) вариант со степенями 10. Из полезного: не печатает лидирующие нули, добавляет в конец символ конца строки.
    Размер 25 слов:
    ; Fast DECIMAL by Manwe
    ;        R1 - pointer to output text string
    DECIM:	MOV #TEN,R5	; table address
    1:	CMP (R5)+,R0	; skip leading zeros
    	BHI 1		; branch if higher, for 16-bit not signed
    	MOV -(R5),R3
    	BEQ 4		; if less then 10
    2:	MOV #57,R4	; 0 symbol in ASCII codepage - 1
    3:	INC R4		; count digits
    	SUB R3,R0
    	BHIS 3		; branch if higher or same, for 16-bit not signed
    	MOVB R4,(R1)+	; print R4
    	ADD (R5)+,R0
    	MOV (R5),R3
    	BNE 2
    4:	ADD #60,R0	; 0 symbol in ASCII codepage
    	MOVB R0,(R1)+	; print R0
    	CLRB (R1)	; write end marker of the text string
    	RET
    TEN:	.WORD 10000.,1000.,100.,10.,0
    Последний раз редактировалось Manwe; 05.06.2019 в 18:21.
    manwe.pdp-11.ru
  7. #46
  8. #47
    406
    257 сообщений
    Не нашёл более подходящей темы, спрошу здесь.
    При обращении к адресу @#167776 БК-0011М вылетает на середине команды. По адресам 160000-177777 находится область регистров внешних устройств и конкретно по адресу 167776 в данный момент ничего не подключено (обычно бывает подключён контроллер СМК и в этой ячейке памяти записана версия контроллера).
    Действительно ли БК должна прерываться по 4-ому вектору при обращении к адресу 167776?
    Касается ли это только БК-0011М, или также БК-0010?
    Известны ли какие-то ещё устройства, использующие порт 167776?
    Заранее спасибо.
    manwe.pdp-11.ru
  9. #48
    г. Самара
    714
    596 сообщений
    При обращении по несуществующему адресу будет прерывание по вектору 4. И не важно, куда указывает адрес
  10. #49
    54
    43 сообщений
    Адрес существует всегда! но по нему могут не отвечать. Или никто не живет или разговаривать не хотят. А могут только читать а писать нет!
    Для БК страница ввода-вывода определена в документации 177600-177776 и называется областью системных регистров. В этом одно из несоответствий архитектуре PDP-11
    1. Конфигурация без расширенной памяти.
     0         ------------------------------
               ! Область стека и системных  !
               ! переменных                 !
     1000      ------------------------------
               ! ОЗУ пользователя           !
     40000     ------------------------------
               ! ОЗУ экрана                 !
     100000    ------------------------------
               ! Системное ПЗУ              !
     120000    ------------------------------
               ! Сменное (съемное)          !
               ! ПЗУ (Фокал)                !
     140000    ------------------------------
               ! Сменное ПЗУ                !
     160000    ------------------------------
               ! Сменное системное  ПЗУ     !
     177600    ------------------------------
               ! Область  системных         !
               ! регистров                  !
     177777    ------------------------------
    2. Конфигурация с расширенной памятью.
               ! переменных                 !
               ! ОЗУ пользователя или       !
               ! экрана                     !
     70000     ------------------------------
               ! ОЗУ экрана                 !
               ! Системное ПЗУ (монитор и   !
               ! драйверы)                  !
               ! ПЗУ-интерпретатор Фокала   !
               ! ПЗУ резервное              !
               ! ПЗУ. тесты                 !
               ! регистров                  !
  11. #50
    г. Самара
    714
    596 сообщений
    Адрес, при обращении по которому в течении 15 мкс не прилетел BRPLY L
    Ну, строго говоря, в архитектуре PDP-11 нигде не постулируется, что в старших 8 кб адресного пространства располагается страница в/в или что там обязательно только регистры внешних устройств. Более точный вариант для PDP - сигнал BBS7 L, хотя и это - не постулат. Но если требуется работа ОС от DEC без необходимости модификации - это до некоторой степени предполагается. Хотя более точный вариант (но тоже не постулат) - по адресам 177560-177566 - регистры адаптера подключения консольного терминала плюс по некоторым адреса (не обязательно на странице в/в) ПЗУ с по крайне мере начальным загрузчиком (или ввод его тем или иным способом) плюс по некоторым адресам (не обязательно на странице в/в) регистров устройства, откуда пойдёт начальная загрузка некоей системы. Но это не обязательно, особенно в варианте с прошитым в ПЗУ софтом.
  1. написание простейшей демки для тренировки
    от AAA в разделе Для начинающих
    Ответов: 121
    Последнее: 22.05.2012, 18:06
  2. написание музыки на Dendy.
    от s1moncpu в разделе Nintendo
    Ответов: 27
    Последнее: 25.05.2007, 05:34
  3. написание музыки на Dendy.
    от s1moncpu в разделе Музыка
    Последнее: 16.05.2007, 10:59
  4. Тестирование программ
    от Vitamin в разделе Программирование
    Последнее: 23.01.2005, 21:46
