Показано с 1 по 10 из 27
Тема: APU для Spectrum -арифметический сопроцессор
    zx_
    По умолчанию APU для Spectrum -арифметический сопроцессор
    набрел здесь на заметку, о подключении 8231 к спектруму, пишут из старого немецкого журнала
    схемка
    I'm probably able to give you some hints because of... a couple of weeks ago I started to build a Sinclair ZX / ZX81 APU Prototyp card based on an article of an old German computer magazin.
    So even that the ROM seems to be missing on your card you are probably able to use the card with some Basic coding as we started here in Germany to do some simple tests.
    APU Intel 8231A or AMD AM9511A are pin compatible
    So beside some coding we started with using the original Spectrum ZX ROM without any changes:
    Used I/O Addresses to communicate with the APU are as follows, while the APU is using two registers for the calculation(s): a Data- and a Command Register
    D=Data-Adresse = 31d -> 1Fh (or 125d -> 7Dh)
    C=Command-Adresse = 95d -> 5Fh (or 127d -> 7Fh)
    in our case we toggle address bit A6 to switch between Data and Command register (see my attached schematic snapshoot), so the Apple I/O Addresses needs to be used here, instead.
    APU Testprogramm using the Standard Speccy 48K ROM
    Arithmetic APU Operation -> 16 Bit Addition: Command 108d -> 6Ch
    PROGRAM: APU-Test
    100 REM TESTPGM 8231A or AM9511A APU
    110 LET C=95: LET D=31 REM 95d = Command Register; 31d = Data Register
    120 OUT D,10: OUT D,0 REM load value 10 to the APU
    130 OUT D,20: OUT D,0 REM load value 20 to the APU
    140 OUT C,108 REM use APU command 108d -> 6Ch to do a 16nd Bit Addition
    150 LET A=IN D: LET B=IN D REM get calculation result(s)
    160 PRINT A REM A should held 0
    160 PRINT B REM B should held 30 -> which is the result of 10 + 20 (see above)
    хехЪ
    здесь ориджинал
    https://www.applefritter.com/comment...#comment-86258
    Самара
    34
    28 сообщений
    зачем оно надо? кто то будет новую Элиту с заливкой делать?
    zx_
    sergio78, а вдруг?
    или сумасшедший старый физик, на спектруме с арифметическим сопроцессором, посчитает пузырь Алькубьерре
    г. Запорожье, Украина
    365
    239 сообщений
    смотрел я както даташит на чип АМД - 4 тыс тактов на один синус - малавата будет )
    http://www.hartetechnologies.com/man...9511%20FPU.pdf
    стр. 6
    Последний раз редактировалось shurik-ua; 09.02.2019 в 15:53.
    Самара
    34
    28 сообщений
    а вдруг?
    по этому- а вдруг, падает только рубль на бирже. а новая спековкая Элита с заливкой, это из раздела, Сказки и Фантастические истории.
    Цитата Сообщение от shurik-ua Посмотреть сообщение
    малавата будет )
    для чего, маловато? Если для игр, аля Квейк, таки да.
    г. Могилёв, Беларусь
    120
    74 сообщений
    Учитывая успехи орионщиков, тема становится актуальной.
    ¡Un momento, señor fiscal!
    251
    225 сообщений
    8 Post(s)
    Не знаю как там на ваши рубли, но на наши их цена сегодня четыре огромных сумки жрачки. Так что актуальной становится эмуляция этого чипа на другом железе. Да и Paypal отрубили, нечем более на eBay баблить.
    г. Зеленоград
    231
    123 сообщений
    Можно на STM32 сделать. И тогда уже не эмулятор этой микросхемы, а полноценный вычислитель. Правда цены сейчас -- порядка 1000р за голый контроллер. У кого 500..600 -- нет в наличии. То есть висит старая цена без обновлений.
    Короме того, возникает вопрос, а зачем в качестве ускорителя использовать машинку, которая как минимум в100 раз быстрее спектрума
    г. Харьков, Украина
    22
    18 сообщений
    для ускорения, ваш КО
    г. Самара
    714
    596 сообщений
    Я последний примерно год или полтора покупки на eBay оплачивал без PayPal - напрямую, с карты сбера. Но сейчас проблема в другом - в доставке. Так что вариантов нет не из-за PayPal. Перекрестился (хоть и не верующий), что две последние покупки всё таки доставили - терять больше семисот баксов как то было не очень весело
  1. [Поиск 1] Сопроцессор 8087
    от trader2k4 в разделе Поиск
    Ответов: 17
    Последнее: 26.03.2018, 21:51
  2. z80 и арифметический сопроцессор AM95
    от zx_ в разделе Несортированное железо
    Ответов: 16
    Последнее: 18.08.2017, 22:53
  3. Сопроцессор
    от LeoN65816 в разделе Агат
    Последнее: 29.10.2016, 07:54
  4. Математический сопроцессор.
    от Demige в разделе Несортированное железо
    Ответов: 28
    Последнее: 01.05.2012, 11:15
  5. Куплю СоПроцессор 387sx
    от REMR в разделе Барахолка (архив)
    Последнее: 02.01.2010, 23:55
