Typically, the ex-USSR, the problem is solved with the help of "blunt hot object", ie the soldering iron.You need to agree on a hardware protocol to achieve the necessary results.I believe that this interest is, especially if BSDOS be able to work on all major clones: Scorpion, Kay, Pentagon.
Ответить с цитированием
( Would they be willing to do that? To connect one more card? What do you think?
