Показано с 1 по 10 из 38
Тема: ROM files structure
    Praha
    34
    15 сообщений
    Цитата Сообщение от БК-0010 Посмотреть сообщение
    The empty space will appear, if you delete the second address for reading the port #7FFD. The conflict, which may be possible while reading from two K-MOUSE Turbo 2008 does not arise, because their data bus is connected through resistors 150 + 150 = 300 ohms. Therefore, the second address for reading the port #7FFD not needed.
    Readability of port #3EDF is used also for 100% detection of SLAVE K-MOUSE interface.
    Readability of port #FEDF is used also for 100% detection of MASTER K-MOUSE interface.
    http://velesoft.speccy.cz/kmouse/km-...8_tester_2.zip
    http://velesoft.speccy.cz/kmouse/km-...sic_tester.zip
    http://translate.google.com/translat...hl=cs&ie=UTF-8
    Последний раз редактировалось VELESOFT; 18.11.2009 в 02:55.
  1. Spessy EXE files
    от Splinter в разделе Эмуляторы
    Последнее: 25.08.2005, 13:50
