Страница 6 из 134 ПерваяПервая ... 2345678910 ... ПоследняяПоследняя
Показано с 51 по 60 из 1334
Тема: Звуковая карта "ZXM-SoundCard"
  1. #51
    Praha
    34
    15 сообщений
    Цитата Сообщение от БК-0010 Посмотреть сообщение
    VELESOFT, what ports are used?
    This is 16bit ports. I must find manual. But you can see all ports on SID PLAYER source code:
    http://simonowen.com/sam/sidplay/
    See in schematic:
    8bit port #D4
    and A8-A12 + A15 select adress for SID chip.
    This port is unusable on real ZX Spectrums (collision wih port FE and 7FFD,etc...) but complette schematic and port decoder can be modified (integrated to one CPLD)
    SOURCE CODE OF SIDPLAYER:
    ; SID interface functions
    sid_reset:     ld   hl,last_regs
                   ld   bc,&00d4       ; SID base port is &D4
                   ld   d,b            ; write 0 to all registers
                   ld   a,25           ; 25 registers to write
    reset_loop:    out  (c),d          ; write to register
                   ld   (hl),d         ; remember new value
                   inc  hl
                   set  7,b
                   out  (c),d          ; effectively strobe write
                   res  7,b
                   inc  b
                   cp   b
                   jr   nz,reset_loop  ; loop until all reset
                   xor  a
                   ld   (last_regs+&04),a   ; control for voice 1
                   ld   (last_regs+&0b),a   ; control for voice 2
                   ld   (last_regs+&12),a   ; control for voice 3
                   ret
    sid_update:    ex   de,hl          ; switch new values to DE
                   ld   c,&d4          ; SID interface base port
                   ld   hl,25          ; control 1 changes offset
                   add  hl,de
                   ld   a,(hl)         ; fetch changes
                   and  a
                   jr   z,control2     ; skip if nothing changed
                   ld   (hl),0         ; reset changes for next time
                   ld   hl,&04         ; new register 4 offset
                   ld   b,l            ; SID register 4
                   add  hl,de
                   xor  (hl)           ; toggle changed bits
                   out  (c),a          ; write intermediate value
                   ld   (last_regs+&04),a ; update last reg value
                   set  7,b
                   out  (c),a          ; strobe
    control2:      ld   hl,26          ; control 2 changes offset
                   add  hl,de
                   ld   a,(hl)
                   and  a
                   jr   z,control3     ; skip if no changes
                   ld   (hl),0
                   ld   hl,&0b
                   ld   b,l            ; SID register 11
                   add  hl,de
                   xor  (hl)
                   out  (c),a
                   set  7,b
                   out  (c),a
    control3:      ld   hl,27          ; control 3 changes offset
                   add  hl,de
                   ld   a,(hl)
                   and  a
                   jr   z,control_done ; skip if no changes
                   ld   (hl),0
                   ld   hl,&12
                   ld   b,l            ;  SID register 18
                   add  hl,de
                   xor  (hl)
                   out  (c),a
                   set  7,b
                   out  (c),a
    control_done:  ld   hl,last_regs   ; previous register values
                   ld   b,0            ; start with register 0
    out_loop:      ld   a,(de)         ; new register value
                   cp   (hl)           ; compare with previous value
                   jr   z,sid_skip     ; skip if no change
                   out  (c),a          ; write value
                   ld   (hl),a         ; store new value
                   set  7,b
                   out  (c),a          ; effectively strobe write
                   res  7,b
    sid_skip:      inc  hl
                   inc  de
                   inc  b              ; next register
                   ld   a,b
                   cp   25             ; 25 registers to write
                   jr   nz,out_loop    ; loop until all updated
                   ld   hl,7
                   add  hl,de          ; make up to a block of 32
                   ret
    start_50Hz:    equ  0
    step_50Hz:     equ  0
    end_50Hz:      equ  0
    start_60Hz:    equ  191             ; start on line 191
    step_60Hz:     equ  312/6           ; step back 52 lines
    step5_60Hz:    equ  start_60Hz-(4*step_60Hz) ; in top border
    end_60Hz:      equ  start_60Hz-(5*step_60Hz) ; frame int finish
    start_100Hz:   equ  88
    step_100Hz:    equ  0
    end_100Hz:     equ  start_100Hz
    ; Set playback speed, using timer first then ntsc flag
    set_speed:     ld   hl,(c64_cia_timer) ; C64 CIA#1 timer frequency
                   ld   a,h
                   or   l
                   jr   nz,use_timer    ; use if non-zero
                   ld   a,(ntsc_tune)   ; SID header said NTSC tune?
                   and  a
                   jr   nz,set_60hz     ; use 60Hz for NTSC
    set_50hz:      ld   h,start_50Hz
    ;              ld   l,end_50Hz
    ;              ld   a,step_50Hz
    set_exit:      ld   (line_step1+1),a
                   ld   (line_step2+1),a
                   ld   a,h
                   ld   (line_start+1),a
                   ld   (line_num),a
                   ld   a,l
                   ld   (line_end+1),a
                   ld   a,&ff
                   out  (line),a        ; disable line interrupts
                   ret
    set_60hz:      ld   h,start_60Hz
                   ld   l,end_60Hz
                   ld   a,step_60hz
                   jr   set_exit
    set_100hz:     ld   h,start_100Hz
                   ld   l,end_100Hz
                   ld   a,step_100Hz
                   jr   set_exit
    ; 985248.4Hz / HL = playback frequency in Hz
    use_timer:     ld   a,h
                   cp   &22             ; 110Hz (PAL)
                   jr   c,bad_timer     ; reject >100Hz
                   cp   &2b             ; 90Hz
                   jr   c,set_100Hz     ; use 100Hz for 90-110Hz
                   cp   &3b             ; 65Hz
                   jr   c,bad_timer     ; reject 65<freq<90hz
                   cp   &45             ; 55Hz
                   jr   c,set_60Hz      ; use 60Hz for 55-65Hz
                   cp   &56             ; 45Hz
                   jr   c,set_50Hz      ; use 50Hz for 45-55Hz
                                        ; reject <45Hz
    bad_timer:     pop  hl              ; junk return address
                   ld   a,ret_timer     ; unsupported frequency
                   ret
    gap4:          equ  &dd00-$         ; error if previous code is
                   defs gap4            ; too big for available gap!
                   defs 16              ; CIA #2 (serial, NMI)
                   defs 32              ; small private stack
    new_stack:     equ  $
    blocks:        defw 0               ; buffered block count
    head:          defw 0               ; head for recorded data
    tail:          defw 0               ; tail for playing data
    init_addr:     defw 0
    play_addr:     defw 0
    play_song:     defb 0
    ntsc_tune:     defb 0               ; non-zero for 60Hz tunes
    Последний раз редактировалось VELESOFT; 02.01.2010 в 19:22.
  2. #52
    S.Pb
    For bus NemoBus collision will not.
    ---------- Post added at 19:44 ---------- Previous post was at 19:34 ----------
    What is the significance bits of address lines A14, A13?
    Последний раз редактировалось Black_Cat; 02.01.2010 в 19:44.
  3. #53
    Praha
    34
    15 сообщений
    Ports must be changed for better compatibility (possibility connect) with other ZX models/clones. A14 and A13 is not used in schematic.
  4. #54
    S.Pb
    What is the address used in the software?
  5. #55
    Praha
    34
    15 сообщений
    ??? For SIDINTERFACE exist only one player utility. All other ports than xxD4 is extra ports for SAM COUPE computer (memory paging etc...). This must be rewrited, if you need run this player on ZX/clones. Player is designed for Z80 CPU at 6 MHz, then on ZX clones must be used turbo mode. Player emulate in realtime CPU from Commodore 64 and is usable only for play original SID tunes. On ZX with this sidinterface is better direct access to SID via OUTs. Or write SID tracker for create new tunes.
    Последний раз редактировалось VELESOFT; 02.01.2010 в 22:16.
  6. #56
    83 сообщений
    What for so it is difficult?
    Unless it was not easier to convert all SID tracks in dump registers and to play them primitive player on ZX?
    ---------- Post added at 01:03 ---------- Previous post was at 00:57 ----------
    By the way who this hero written emulator processor of C64 under z80?
  7. #57
    Praha
    34
    15 сообщений
    Yes, is possible convert SID music to register values and play it on ZX. But file size will long.
  8. #58
    Praha
    34
    15 сообщений
    SIMON OWEN (Sam Coupe user)
    This is emulation of CPU 6510.
    For ZX Spectrum at 3.5MHz exist also more software emulators of machines based at CPU 6502. For example APPLE 1 emulators (ZX version in attachment)
    APPLE 1 emul for SAM COUPE (Z80 CPU)
    http://simonowen.com/sam/apple1emu/
    VIC 20 emulator , etc...
    http://simonowen.com/spectrum/vic20emu/
    ORAO emul
    http://simonowen.com/sam/oraoemu/
    Последний раз редактировалось VELESOFT; 03.01.2010 в 01:45.
  9. #59
    S.Pb
    In clones using NemoBus, this electronic circuit will work without any alterations.
    Последний раз редактировалось Black_Cat; 03.01.2010 в 03:24.
  10. #60
    Praha
    34
    15 сообщений
    But on other machines it will problem. New interface must use compatible ports. (or can be designed only for computers with NEMO bus )
  1. Ответов: 67
    Последнее: 21.04.2021, 14:51
  2. Куплю "Электронику КР-02" (клон "Радио-86РК")
    от Titus в разделе Барахолка (архив)
    Последнее: 18.08.2009, 15:30
  3. Ответов: 18
    Последнее: 27.08.2008, 20:27
  4. Ответов: 6
    Последнее: 20.11.2007, 11:29
