Показано с 1 по 4 из 4
Тема: A thousand furious bees
    【RB】
    135
    83 сообщений
    Thumbs up A thousand furious bees
    Mr.Beep выпустил аудио-диск «A thousand furious bees»
    Tracklist:
    01. MISTER BEEP - Psionic activity
    02. MISTER BEEP - Love Quest
    03. MISTER BEEP - White-hot iron
    04. MISTER BEEP - Bee-Droids attack!
    05. MISTER BEEP - Galactic coursing
    06. MISTER BEEP - Carry out your duty!
    07. MISTER BEEP - The ninth fighter-ship
    08. MISTER BEEP - The prince’s return
    09. MISTER BEEP - A thousand furious bees
    10. MISTER BEEP - Spring is coming
    Total time: 34:44 min.
    All recorded from REAL HARDWARE.
    1-bit multichannel chiptunes made on ZX Spectrum 48K (beeper).
    Published by Italian netlabel Coucou.
    http://coucounetlabel.blogspot.com/
    Direct download:
    http://www.archive.org/download/Micr...rious_bees.zip
    Информация от автора:
    Hi there.
    After my previous minimal chiptune album - 2 channels only - I decided to make on my ZX Spectrum 48Kb something as developed as possible with the machine. I must admit I'm pretty proud to give you my the newest album containing 10 multichannel 1-bit chiptunes, having from 5 to 9 channels.
    Original idea was to make 6-channels chiptunes playing from 2 synchronized Spectrums (3 channels from each ZX, using Special FX engine).
    I managed to make 4 such songs but meanwhile it appeared that Shiru programmed several totally new BEEPER engines: they were highly powerful and capable of playing even NINE channels from a single ZX Spectrum 48K.
    Therefore finally you can find here:
    - 4 stereo songs made on two synchronized Spectrums (Special FX engine, 2 x 3 channels)
    - 5 mono songs coming from a single Spectrum (Octode engine; 9 channels)
    - 1 mono song coming from a single Spectrum (QChan engine, 5 channels).
    Like I used to say, mostly I don't make actual chiptunes - I just make music on a soundchip. :)
    Hence, generally this album is in art-rock style (called 'progressive rock' sometimes), because the most well-known gamesongs from 80s from Spectrum48 were kept in this genre, and they have been written mostly by Tim Follin.
    Anyways. Because of that, I would like to dedicate my album to Tim Follin, as he was the best 1-bit musician on ZX Spectrum 48K in 80s.
    Z80 chip can actually generate whichever sound however ZX fans prefer mostly the characteristic Follin's sound (hard to stand for other 8bit computers' users :) :) ) and because we have a lot of accessible channels, our chiptunes remind mostly something like a furious swarm of hornets or bees. ;)
    Now you can guess where the title came from. ;)
    And believe me, real ZX48 fans would have _never_ exchanged 'Z80 swarm' sound to anything else. :)
    From the 'technical' side..
    Normally 1-bit sound from ZX consists only of a square (more/less) wave tone without any volumes, without any white noises - simply just beeps. However we use various software-synthesizers called "sound engines". Technical details about the engines are as follows:
    - SpecialFX gives me 2 channels of tones + one track of drums. It is PWM-synthesis based (PulseWidthModulation) and it has various envelopes, setup of drums and 2 steps of volume: one channel is louder than another. With clever composing you can get even delays and echoes, which is normally impossible on 1bit sound. This engine keeps tempo perfectly, so I was able to synchronize two ZX Spectrums and have more channels + stereo.
    - QChan gives 4 channels of tones + one track of drums. Its possibilities are in general similar to the above engine however it's more powerful because - except mentioned envelopes - it has almost twice more channels and also more steps of volume (16 - you can chose from them to place the volumes for every tone-channel).
    - Octode is the most powerful 1-bit engine contemporary. It gives 8 channels of tones + one track of drums. 9 channels is a huge effort for Spectrum's Z80 CPU, so the engine can make detunes sometimes. It's not easy to compose music without false notes here, however it is possible. It has an additional feature - tunning command E5x. It changes the notes' frequency and can be used for achieving more interesting 'fat' instruments. I use it often as it gives me some slightly detuned pads, like from analogue synthesizers.
    Huge thanks go to contemporary programmists making new 1-bit software (or hacking the old one) for ZX composing: Shiru, Ccowley, XXL, FrankT.
    Also to the classic programmer - Jonathan 'Joffa' Smith (R.I.P.) - who designed Special FX engine.
    Enjoy the swarm.
    You have been stung.
    MISTER BEEP
    04.2011
    perm/ru
    злозвездато!
    oisee.
    Пенза
    СитуацияЖ челюсть об трубу =зуб на левой верней снороне (язык тревржит нерв).
    ВопросЖ если 2-е нидели ,то капут . Сам почти знаю ответ, но ZX ки (стоматологи) посоветуйте.
    ---------- Post added at 00:17 ---------- Previous post was at 00:13 ----------
    Этот Пост Приоритет!
    83 сообщений
    А можно было просто нажать кнопочку ТУРБО на пентеве которая есть у mr.Beeper'a.
