assign I_RED = {vga_out[7:5], vga_out[7:5], vga_out[7:6]};
assign I_GREEN = {vga_out[4:2], vga_out[4:2], vga_out[4:3]};
assign I_BLUE = {vga_out[1:0], vga_out[1:0], vga_out[1:0], vga_out[1:0]};
Гы..!
wire
omercury, туплю, помоги :
module vga_gen
input wire clk_50MHz,
output wire [7:0] TMDS
wire h_sync;
wire v_sync;
wire picselclock;
wire hdmi_clock;
wire blank;
wire vaddr[7:0];
vga_sync VGA_SYN
( .clk_in (clk_50MHz),
.picselclock(picselclock) ,
.hdmi_clock(hdmi_clock),
.vga_hsync (h_sync),
.vga_vsync (v_sync),
.disp_enable (blank),
.v_addr (vaddr)
hdmi #(
.FREQ(5200000),
.FS(48000),
.CTS(25200),
.N(6144))
HDMI1 (
.I_CLK_VGA (picselclock),
.I_CLK_TMDS (hdmi_clock),
.I_HSYNC (h_sync),
.I_VSYNC (v_sync),
.I_BLANK (~blank),
//.I_RED (8'b11111111),
.I_RED (),
.I_GREEN (),
.I_BLUE (),
.I_AUDIO_PCM_L (1'b0),
.I_AUDIO_PCM_R (1'b0),
.O_TMDS (TMDS)
assign I_RED = { vaddr[7:5], vaddr[7:5], vaddr[7:6]};
assign I_GREEN = { vaddr[4:2], vaddr[4:2], vaddr[4:3]};
assign I_BLUE = { vaddr[1:0], vaddr[1:0], vaddr[1:0], vaddr[1:0]};
endmodule
- - - Добавлено - - -Цитата:
Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(56): created implicit net for "I_RED"
Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(57): created implicit net for "I_GREEN"
Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(58): created implicit net for "I_BLUE"
Error (10044): Verilog HDL error at vga_gen.v(30): expression cannot reference entire array "vaddr"
Error (10048): Verilog HDL error at vga_gen.v(30): values cannot be assigned directly to all or part of array "vaddr" - assignments must be made to individual elements only
Error (10133): Verilog HDL Expression error at vga_gen.v(56): illegal part select of unpacked array "vaddr"
Error (10133): Verilog HDL Expression error at vga_gen.v(57): illegal part select of unpacked array "vaddr"
Error (10133): Verilog HDL Expression error at vga_gen.v(58): illegal part select of unpacked array "vaddr"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 5 errors, 3 warnings
Error: Peak virtual memory: 4622 megabytes
Error: Processing ended: Sat Oct 05 15:42:10 2019
Error: Elapsed time: 00:00:09
Error: Total CPU time (on all processors): 00:00:09
Error (293001): Quartus II Full Compilation was unsuccessful. 7 errors, 3 warnings
Мда , досадная ошибка из-за невнимательности ...
Надо
wire [7:0] vaddr;
а не
wire vaddr[7:0];
module vga_gen
wire h_sync;
wire v_sync;
wire picselclock;
wire hdmi_clock;
wire blank;
wire vaddr[7:0];
vga_sync VGA_SYN
.v_addr (vaddr)
hdmi #(
.FREQ(5200000),
.FS(48000),
.CTS(25200),
.N(6144))
HDMI1 (
.I_HSYNC (h_sync),
.I_VSYNC (v_sync),
.I_BLANK (~blank),
.I_RED (I_RED ),
.I_GREEN (I_GREEN),
.I_BLUE (I_BLUE),
.O_TMDS (TMDS)
wire [7:0] I_RED = { vaddr[7:5], vaddr[7:5], vaddr[7:6]};
wire [7:0] I_GREEN = { vaddr[4:2], vaddr[4:2], vaddr[4:3]};
wire [7:0] I_BLUE = { vaddr[1:0], vaddr[1:0], vaddr[1:0], vaddr[1:0]};
endmodule[свернуть]
Цвета не подключил.
Что ж так тормозит-то?
Угу и это то же.
Вообщем счас так :
Можно продолжать...Код:module vga_gen
wire h_sync;
wire v_sync;
wire picselclock;
wire hdmi_clock;
wire blank;
wire [7:0] vaddr;
vga_sync VGA_SYN
.v_addr (vaddr)
hdmi #(
.FREQ(5200000),
.FS(48000),
.CTS(25200),
.N(6144))
HDMI1 (
.I_HSYNC (h_sync),
.I_VSYNC (v_sync),
.I_BLANK (~blank),
.I_RED ({ vaddr[7:5], vaddr[7:5], vaddr[7:6]}),
.I_GREEN ({ vaddr[4:2], vaddr[4:2], vaddr[4:3]}),
.I_BLUE ({ vaddr[1:0], vaddr[1:0], vaddr[1:0], vaddr[1:0]}),
.O_TMDS (TMDS)
endmodule
Шрифт ещё не подбирал?
Угу ...
Копипаст с нотепада++ прокатывает только до сохранения , дальше так же .
Плюнул, камменты english only, forever ...
HardWareMan, Вот RTL :
RTL кликабельно
dosikus, ты его не мне показывай. Ты его сам научись правильно считывать.
HardWareMan, в смысле читать /понимать?
