Показано с 1 по 10 из 1910
Тема: ПЛИС и всё что с ними связано
    Ярославль
    omercury, туплю, помоги :
    module vga_gen
    input wire clk_50MHz,
    output wire [7:0] TMDS
    wire h_sync;
    wire v_sync;
    wire picselclock;
    wire hdmi_clock;
    wire blank;
    wire vaddr[7:0];
    vga_sync VGA_SYN
    ( .clk_in (clk_50MHz),
    .picselclock(picselclock) ,
    .hdmi_clock(hdmi_clock),
    .vga_hsync (h_sync),
    .vga_vsync (v_sync),
    .disp_enable (blank),
    .v_addr (vaddr)
    hdmi #(
    .FREQ(5200000),
    .FS(48000),
    .CTS(25200),
    .N(6144))
    HDMI1 (
    .I_CLK_VGA (picselclock),
    .I_CLK_TMDS (hdmi_clock),
    .I_HSYNC (h_sync),
    .I_VSYNC (v_sync),
    .I_BLANK (~blank),
    //.I_RED (8'b11111111),
    .I_RED (),
    .I_GREEN (),
    .I_BLUE (),
    .I_AUDIO_PCM_L (1'b0),
    .I_AUDIO_PCM_R (1'b0),
    .O_TMDS (TMDS)
    assign I_RED = { vaddr[7:5], vaddr[7:5], vaddr[7:6]};
    assign I_GREEN = { vaddr[4:2], vaddr[4:2], vaddr[4:3]};
    assign I_BLUE = { vaddr[1:0], vaddr[1:0], vaddr[1:0], vaddr[1:0]};
    endmodule
    Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(56): created implicit net for "I_RED"
    Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(57): created implicit net for "I_GREEN"
    Warning (10236): Verilog HDL Implicit Net warning at vga_gen.v(58): created implicit net for "I_BLUE"
    Error (10044): Verilog HDL error at vga_gen.v(30): expression cannot reference entire array "vaddr"
    Error (10048): Verilog HDL error at vga_gen.v(30): values cannot be assigned directly to all or part of array "vaddr" - assignments must be made to individual elements only
    Error (10133): Verilog HDL Expression error at vga_gen.v(56): illegal part select of unpacked array "vaddr"
    Error (10133): Verilog HDL Expression error at vga_gen.v(57): illegal part select of unpacked array "vaddr"
    Error (10133): Verilog HDL Expression error at vga_gen.v(58): illegal part select of unpacked array "vaddr"
    Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 5 errors, 3 warnings
    Error: Peak virtual memory: 4622 megabytes
    Error: Processing ended: Sat Oct 05 15:42:10 2019
    Error: Elapsed time: 00:00:09
    Error: Total CPU time (on all processors): 00:00:09
    Error (293001): Quartus II Full Compilation was unsuccessful. 7 errors, 3 warnings
    Мда , досадная ошибка из-за невнимательности ...
    Надо
    wire [7:0] vaddr;
    а не
    wire vaddr[7:0];
    Profi 1024+CF+CPM+VGA
    ATARI 800XL+SIO2PC+SIO2SD
    RK86@Maximite
    г. Королёв
    12
    11 сообщений
    Цитата Сообщение от dosikus Посмотреть сообщение
    туплю
    module vga_gen
    wire h_sync;
    wire v_sync;
    wire picselclock;
    wire hdmi_clock;
    wire blank;
    wire vaddr[7:0];
    vga_sync VGA_SYN
    .v_addr (vaddr)
    hdmi #(
    .FREQ(5200000),
    .FS(48000),
    .CTS(25200),
    .N(6144))
    HDMI1 (
    .I_HSYNC (h_sync),
    .I_VSYNC (v_sync),
    .I_BLANK (~blank),
    .I_RED (I_RED ),
    .I_GREEN (I_GREEN),
    .I_BLUE (I_BLUE),
    .O_TMDS (TMDS)
    wire [7:0] I_RED = { vaddr[7:5], vaddr[7:5], vaddr[7:6]};
    wire [7:0] I_GREEN = { vaddr[4:2], vaddr[4:2], vaddr[4:3]};
    wire [7:0] I_BLUE = { vaddr[1:0], vaddr[1:0], vaddr[1:0], vaddr[1:0]};
    endmodule
    Цвета не подключил.
    Что ж так тормозит-то?
    от Grand в разделе ДВК, УКНЦ
    Ответов: 4575
    Последнее: 17.11.2025, 11:38
  2. PAL/GAL и все что с ними связано.
    от Mick в разделе Клоны на ПЛИС, МК и БМК
    Ответов: 489
    Последнее: 19.09.2025, 18:39
  3. SMUC на дискретах и ПЛИС
    от spensor в разделе Scorpion
    Ответов: 846
    Последнее: 02.05.2025, 08:36
  4. Ответов: 1215
    Последнее: 10.02.2025, 19:04
  5. Вопрос по ПЛИС
    от Zloy в разделе Несортированное железо
    Ответов: 23
    Последнее: 17.10.2015, 17:12
