MiX, а с HX загружались после запуска кода из ПЗУ?
А то все параметры читаются из EEPROM, а после чтения эмуляция FP-11 и MOVR устанавливается командой MED6X.
Немного баловства на 11/83 :DКод:.INI DU2:/NOQ
.COP 010000.RAM DU2:
Files copied:
DK:010000.RAM to DU2:010000.RAM
.COP/DEV/NOQ SY:/STA:0/END:0 DU2:
?DUP-W-Output device is larger than input device
.R SIPP
*DU2:/A
Base? 0
Offset? 2000
Base Offset Old New?
000000 002000 012737 12700
000000 002002 003140 104
000000 002004 000100 12701
000000 002006 005037 37400
000000 002010 000102 12702
000000 002012 005003 10000
000000 002014 011367 4777
000000 002016 003714 3710
000000 002020 012706 112
000000 002022 010000 ^Y
*DU2:010000.RAM/A
Base? 0
Offset? 2772
000000 002772 177520 0
000000 002774 016706 ^Z
Offset? 13770
000000 013770 177521 1
000000 013772 177560 ^Z
Offset? 24050
000000 024050 177520 0
000000 024052 004767 ^Z
Offset? 24516
000000 024516 005067 5037
000000 024520 142776 0
000000 024522 000167 ^Z
Offset? 24532
000000 024532 177520 0
000000 024534 012737 ^Z
Offset? 24562
000000 024562 177520 0
000000 024564 110015 ^Z
Offset? 24716
000000 024716 177520 0
000000 024720 012737 ^Z
Offset? 24762
000000 024762 177520 0
000000 024764 012737 ^Z
Offset? 25306
000000 025306 177521 1
000000 025310 012701 ^Z
Offset? 26236
000000 026236 177520 0
000000 026240 005767 ^Y
*^C
.BO DU2:/FO
BOOT-E-EEPROM checkum invalid - reconfigure processor board
BOOT-E-Invalid entry in auto-boot or device translation table entry ignored
Testing in progress please wait
4088 K Bytes RAM
M11 Bootstrap/Diagnostic Version V 1.4I
Commands are :
BOOT - Boot from a specific device.
HELP - Re-display this summary of commands.
LIST - List the bootstraps provided.
MAP - Display a map of the address space.
SETUP - Configure the M11.
TEST - Enter a continuous test mode
Enter a command and press the return key :M
Memory Map
Starting at Ending at
00000000 17757776
17760100 17760106
17760500 17760516
17765000 17765776
17767770 17767774
17772100 17772102
17772150 17772152
17772200 17772376
17772516 17772516
17773000 17773776
17774440 17774456
17774500 17774502
17776500 17776536
17777514 17777524
17777546 17777546
Press <CR> to continue
Memory Map
17777560 17777566
17777572 17777676
17777744 17777752
17777766 17777766
17777772 17777772
17777776
Commands are :
Enter a command and press the return key :B DU3
Starting system ...
RT-11ZM (S) V05.07
?DATE-I-Time source: AA-00-04-00-06-F8, RSX-11M-PLUS V4.6 BL87 (KOPOBA)
?DATE-I-Date & time: 15-SEP-2017 01:37:03
Для чистоты эксперимента еще вариант теста MOVR, в точности такой как делается в RSX при выяснении есть ли эта команда (пока просто проверка трапается или нет):Код:.D 1000=75310,104350
.ST 1000
form, На плате есть перемычки, может и можно задействовать но нужно описание.
