Цитата:
So, to manage the pitchbend data and use it to alter the pitch of a tone in a synthesizer we need to do the following steps.
1. Combine the MSB and LSB to get a 14-bit value.
2. Map that value (which will be in the range 0 to 16,383) to reside in the range -1 to 1.
3. Multiply that by the number of semitones in the ± bend range.
4. Divide that by 12 (the number of equal-tempered semitones in an octave) and use the result as the exponent of 2 to get the pitchbend factor (the value by which we will multiply the base frequency of the tone or the playback rate of the sample).
A pitchbend value of 8,192 (MSB 64 and LSB 0) will mean 0 bend, producing a pitchbend factor of 2(0/12) which is 1; multiplying by that factor will cause no change in frequency. Using the example message from above, a pitchbend of 12,280 will be an upward bend of 4,088/8191=0.499. That is, 12,280 is 4,088 greater than 8,192, so it’s about 0.499 of the way from no bend (8,192) to maximum upward bend (16,383). Thus, if we assume a pitchbend range setting of ± 2 semitones, the amount of pitch bend would be about 0.998 semitones, so the frequency scaling factor will be 2(0.998/12), which is about 1.059. You would multiply that factor by the fundamental frequency of the tone being produced by your synthesizer to get the instantaneous frequency of the note.
