Страница 14 из 70 ПерваяПервая ... 101112131415161718 ... ПоследняяПоследняя
Показано с 131 по 140 из 699
Тема: SjASMPlus от z00m
  1. #131
    Prague, Czech Republic
    103
    77 сообщений
    Цитата Сообщение от Demige Посмотреть сообщение
    Can you add support of defining big text blocks in source?
    Hmm... it's possible, but it will very likely have the limits of sjasmplus parser, i.e. max 2048 chars per line... Actually not, if I would add it, I would have to avoid regular read-buffered-line, because it does some very limited parsing to correctly read multi-line comment blocks and strings in quotes/apostrophes, and that's not something to be done in the big-text block, so I would definitely have to write second "read-input" code to avoid regular, and then it can be without those limits of regular parser.
    Ok, so it's possible, and I will add it to my TODO.txt.
    But I find it very low priority, because I don't see much point in it.
    Are you aware that you can write your big-text in other file, like "scroller2.txt", and do in ASM source simple:
    LabelTXT:      INCBIN "scroller2.txt"
    I find this workaround very reasonable, often maybe even better than having the text data directly in the ASM source (and I don't need to write whole new input-stream-reader ).
    Let me know if you disagree or INCBIN solution doesn't fit your purpose, and let me know what is problematic (if you want the "big-text" feature to get higher priority).
    With my current information about the issue, I will very likely keep it on the bottom of TODO list, so it may never happen or very lately.
  2. #132
    г.Кстово
    In my project I have much text data (text dialogs). They not very big at once (may be 200b-3K for block), but their count big enough. And for each I need label to print text to screen. If I will use incbin, this would need for 500+ files to include.
    I could wrote fulltext parser to get labels from text, but then I would have to solve problem where to store this labels and how to name them.
    Последний раз редактировалось Demige; 24.07.2019 в 18:09.
    Zx-Evolution rev.c
    ZS Scorpion 1024K rev.2013
  3. #133
    г. Новосибирск
    323
    152 сообщений
    Demige, а что если попробовать на LUA написать аналог INCBIN. Назвать его INCTEXT. Пусть он работает так же как INCBIN, но строки текста заканчивающиеся особым знаком превращал в метки.
    Тогда подсунув ему такой текст в файле Messages.txt:
    Label1>>
    Supertext
    Message1>>
    Game over!
    Вызвав INCTEXT "Messages.txt",">>"
    Он создаст две метки для двух текстов.
    Этот пользователь поблагодарил Reobne за это полезное сообщение:
    Demige(25.07.2019)
  4. #134
    103
    77 сообщений
    I see, ok, this is the kind of stuff which makes big-text seem more important than I expected.
    Some notes about possible workarounds with current sjasmplus version:
    You can process data in device memory (reading them with { address } operator), but you can't easily build dynamic labels name from that, and values from memory can be read only in pass3, so the INCBIN+MACRO+DEFINE path would be very difficult to create some workaround, and it would probably not work well = unless I'm overlooking something, this is wrong approach.
    Lua can add symbols (labels) (build dynamically, from file content for example) and can add bytes to the output (at least according to docs, I don't have these covered in tests, so you may find new bugs if you will try these, reporting them with example.asm will help me a lot). And there's probably a way in Lua to open text file and parse it, so you can implement your own INCTEXT as Reobne suggested, seems like good idea and should very likely work well (unless you run into some bug in sjasmplus). If you will go this route, and run into some problems, let me know, so we can fix it all.
    Finally is the classic DB way *that* bad for these things?
    Dialog1:
      db "Hi", 13, 13
      db "Some text.", 13
      db "Next line.",0
      ; to get zero terminated text with ZX enter=13 newlines
    Depending on your workflow and where the devtime is mostly spent, having external .txt file processed by lua may even bring some productivity boost and may make it easier for non-programmer people to contribute to your project, so the Lua workaround sounds to me quite good, maybe even better than native support for big-text blocks from sjasmplus, but it's more initial work to get that setup working.
    (would be also nice example of lua usage, if you want to share it afterwards , I can add it to the project tests/luaexamples)
    Последний раз редактировалось Ped7g; 25.07.2019 в 05:00.
    Этот пользователь поблагодарил Ped7g за это полезное сообщение:
    Demige(31.07.2019)
  5. #135
    г. Новосибирск
    323
    152 сообщений
    Thumbs up
    Кажется получилось!
    Вот пример. Он компилируется! Для проверки - просмотр в дебагере.
    IncText_test.asm
    		DEVICE 	ZXSPECTRUM128
    		LUA PASS1
    		function inc_text(file_name,label_attr,line_terminator)
    			if line_terminator==nil then
    				l_t=13
    			else
    				l_t=line_terminator
    			end
    			for line in io.lines(file_name) do
    				if string.sub(line,1+string.len(line)-string.len(label_attr))==label_attr then
    					--print          (string.sub(line,1,string.len(line)-string.len(label_attr)),sj.current_address)
    					sj.parse_line(string.sub(line,1,string.len(line)-string.len(label_attr)))
    				else
    					for i = 1,string.len(line) do
    						sj.add_byte(string.byte(line,i))
    					end
    					sj.add_byte(l_t)
    				end
    			end
    		end
    		ENDLUA
    		ORG	#8000
    START
    		LD HL,TT1
    		LD DE,TT2
    		LD IX,TT3
    MainLoop
    		JP	MainLoop
    		LUA ALLPASS
    			inc_text("test.txt",">>")
    		ENDLUA
    		SAVESNA "textovik.sna",START	;в папку unreal после компиляции сохранится снапшот для запуска в эмуляторе, содержащий программу, описанную сверху
    Образец текста.
    test.txt
    TT1>>
    Hello!!
    Ready?
    Go!
    TT2>>
    SOS!!!
    TT3>>
    GAME OVER
    PRESS ANY KEY
    Final>>
    	LD A,123>>
    	RLCA>>
    	JP Final>>
    	BYTE "SEVER",0,"BURAN",0>>
    Как видите, можно добавлять через текст не только метки.
    Это моя первая "программа" на LUA, так что я готов к любой критике как стиля так и содержания.
    Эти 2 пользователя(ей) поблагодарили Reobne за это полезное сообщение:
    Black Cat / Era CG(25.07.2019), Ped7g(30.07.2019)
  6. #136
    г. Дзержинск, Украина
    663
    513 сообщений
    device
    zxspectrum128\256\512\1024
    slot 0
    page 0
    вообще работает?
    slot 3
    page 5
    error: [PAGE] Page number must be in range 0..3
    о_О
    slot 1
    page 5
    как вообще сохранить sna
    с нужной включенной в slot 3 страницей?
    Последний раз редактировалось NEO SPECTRUMAN; 30.07.2019 в 18:07.
  7. #136
  8. #137
    г. Арзамас
    180
    126 сообщений
    а шо, у какого-то были такие девайсы?
  9. #138
    663
    513 сообщений
    а шо другие sjasm-ы так ругаются?
    для особо непонятливых
    ZXSPECTRUM256
    Same as russian clone Scorption 256. Has 16 RAM pages (0-15) with size 4000h.
    ZXSPECTRUM512
    Same as russian clones ATM Turbo 512 and Pentagon 512. Has 32 RAM pages (0-31) with size 4000h.
    ZXSPECTRUM1024
    Same as russian clones ATM Turbo 2 and Pentagon 1024 SL. Has 64 RAM pages (0-63) with size 4000h.
    а еще есть пентевы с 256 страниц в любое окно...
    которых нет в комплиторах....
  10. #139
    г. Арзамас
    180
    126 сообщений
    в тсконфе решалось SPG builder'ом.
  11. #140
    663
    513 сообщений
    а в не тс конфе не решается
    да и sjasm больше метра не делает
    а когда вопрос подымался
    всех все устраивает
    как я помню
    а я спг делалку еще и дето потерял
    да и другой версией
    которая работает
    не могу воспользоваться тк
    error: [LUA] Maximum size of Lua script is 32768 bytes
    только sjasm от z00m
    переваривает
    https://zx-pk.ru/threads/4057-perepi...uot/page6.html
  1. SjASMPlus Z80 кросс ассемблер
    от Aprisobal в разделе Программирование
    Ответов: 1663
    Последнее: 19.06.2021, 01:36
  2. Исходники TR-DOS для SjASMPlus
    от Keeper в разделе Программирование
    Ответов: 20
    Последнее: 11.02.2011, 11:57
  3. Запуск STS из .sna, сгенерированного sjasmplus.
    от siril в разделе Программирование
    Последнее: 11.10.2010, 21:33
  4. Breakpoints в связке Sjasmplus+UnrealSpeccy
    от Kurles в разделе Программирование
    Ответов: 19
    Последнее: 26.01.2009, 12:36
  5. Disturbed COverMAnia ( music disk with z00m music collection)
    от kyv в разделе Музыка
    Последнее: 27.03.2008, 10:01
