Показано с 1 по 8 из 8
Тема: Help building an Aleste remake board
    Montevideo, Uruguay
    По умолчанию Help building an Aleste remake board
    Hi guys this is my first post so like to say hello to everybody, and thanks for letting me in the forums
    Now to business going to build an Aleste kit that got from Tetroid.
    I like to know if this PCB requieres any corrections to it before building ?.
    Also checked the shematics but don't see any place to feed power (+ and -) power input to the board where is the best place to do it ?.
    Regards.
    1,470
    958 сообщений
    in the middle at right side (holes at c20)
    http://www.cpcwiki.eu/index.php/Ales...X_-_Schematics
    Montevideo, Uruguay
    Thank you very much for the info.
    Do you happen to know if the pcb requieres any correction/fixes to it ?
    Воронеж
    43
    16 сообщений
    Take a look at this topic, it might help you:
    https://zx-pk.ru/threads/20769-kompy...20ex-quot.html
    Montevideo, Uruguay
    Thanks for the link Willy i have read the thread like 20 times using a translator, but the translation is terrible and is very hard to understand what is going on.
    Воронеж
    43
    16 сообщений
    Try to ask directly in that thread, probably, people who assembled that board will help you.
    Otherwise try to read it again starting from page 15, information about different components begins there.
    г.Королёв, Московская обл.
    Hello !
    As I see you have a board version 1.004, which means that it does not needed any correction.
    For the first start, I recommend not to install a coil "DR2"
    Montevideo, Uruguay
    Going to check again at that page, don't wanted to ask in English there not sure if the rules of the forum permit that.
    Цитата Сообщение от yuriy_sazonov Посмотреть сообщение
    Hello !
    Thanks for the information that was i needed to know before starting, also what about the coil "DR2" causes any issues ?.
  1. MagicSound для Aleste 520
    от Sherlock в разделе Разное
    Ответов: 137
    Последнее: 27.11.2022, 14:03
  2. Aleste 520EX в корпус УКНЦ
    от Павел Рябцов в разделе Разное
    Ответов: 178
    Последнее: 28.05.2021, 11:06
  3. Подскажите по cpu-board
    от nzqr в разделе Зарубежные компьютеры
    Последнее: 20.07.2011, 23:41
  4. Куплю компьютер Aleste 520EX (Алеста)
    от Nickolas в разделе Барахолка (архив)
    Последнее: 23.10.2009, 05:06
  5. Insert Board( SoC)
    от andrews в разделе Несортированное железо
    Ответов: 22
    Последнее: 24.07.2006, 21:41
