Страница 42 из 70 ПерваяПервая ... 383940414243444546 ... ПоследняяПоследняя
Показано с 411 по 420 из 699
Тема: SjASMPlus от z00m
  1. #411
    Prague, Czech Republic
    103
    77 сообщений
    So in recent weeks I was abusing sjasmplus script a lot (as a form of test/exercise of the scripting implementation, some of the experience went into improving it just before v1.18.0 release)...
    If you are serious about sjasmplus scripting, maybe you can pick up a trick or two from these:
    https://github.com/ped7g/adventofcode
  2. #412
    г. Дзержинск, Украина
    663
    513 сообщений
    tmp_cnt = 0
    	dup 10
    		if ((tmp_cnt = 0) || (tmp_cnt = 5) || (tmp_cnt = 7) || (tmp_cnt = 8))
    			display tmp_cnt," skip"
    		else
    			display tmp_cnt," ok"
    		endif
    tmp_cnt = tmp_cnt +1
    	edup
    	display " "
    tmp_cnt = 0
    	dup 10
    		if ((tmp_cnt != 0) || (tmp_cnt != 5) || (tmp_cnt != 7) || (tmp_cnt != 8))
    		else
    		endif
    	edup
    	display " "
    tmp_cnt = 0
    	dup 10
    		if ((tmp_cnt =! 0) || (tmp_cnt =! 5) || (tmp_cnt =! 7) || (tmp_cnt =! 8))
    		else
    		endif
    	edup
    	display " "
    tmp_cnt = 0
    	dup 10
    		if ((tmp_cnt <> 0) || (tmp_cnt <> 5) || (tmp_cnt <> 7) || (tmp_cnt <> 8))
    		else
    		endif
    	edup
    > 0x0000 skip
    > 0x0001 ok
    > 0x0002 ok
    > 0x0003 ok
    > 0x0004 ok
    > 0x0005 skip
    > 0x0006 ok
    > 0x0007 skip
    > 0x0008 skip
    > 0x0009 ok
    > 0x0000 ok
    > 0x0001 ok
    > 0x0002 ok
    > 0x0003 ok
    > 0x0004 ok
    > 0x0005 ok
    > 0x0006 ok
    > 0x0007 ok
    > 0x0008 ok
    > 0x0009 ok
    > 0x0000 ok
    > 0x0001 skip
    > 0x0002 skip
    > 0x0003 skip
    > 0x0004 skip
    > 0x0005 skip
    > 0x0006 skip
    > 0x0007 skip
    > 0x0008 skip
    > 0x0009 skip
    test.asm(52): error: Syntax error: > 0) || (tmp_cnt <> 5) || (tmp_cnt <> 7) || (
    tmp_cnt <> 8))
    test.asm(52): error: ')' expected
    почему не работает != ? o_O
    почему =! дает какой то результат?
    Последний раз редактировалось NEO SPECTRUMAN; 05.01.2021 в 03:33.
  3. #413
    103
    77 сообщений
    Looks all correct to me?
    The first part is doing "skip" when cnt is 0 or 5 or 7 or 8
    The second part is doing "ok" every time (first two "(cnt is not 0) or (cnt is not 5)" are enough to be always true for any cnt value)
    The third part "=!" is parsed as: "=" is equivalence operator, "!" is logical not, so 0 becomes -1, and non-zero values become 0
    That leads to "ok" when cnt is -1 or 0
    Fourth is just syntax error, the "<>" operator doesn't exist in sjasmplus.
    Did you want in second block negation of first block? Then: !(A || B) = (!A) && (!B)
    (note the "logical or" becomes "logical and" when whole expression is negated)
    tmp_cnt = 0
    	dup 10
    		if ((tmp_cnt != 0) && (tmp_cnt != 5) && (tmp_cnt != 7) && (tmp_cnt != 8))
    		else
    		endif
    	edup
    Этот пользователь поблагодарил Ped7g за это полезное сообщение:
    NEO SPECTRUMAN(05.01.2021)
  4. #414
    663
    513 сообщений
    значит у меня не правильное понимание || и(людское) &&
    и значит (|| людское and &&) != ((людское OR) людское and (людское AND))
    Последний раз редактировалось NEO SPECTRUMAN; 05.01.2021 в 14:55.
  5. #415
    103
    77 сообщений
    logical or (T = true [-1 in sj], F = false [0 in sj]):
    F || F = F
    T || F = T
    F || T = T
    T || T = T
    logical and:
    F && F = F
    T && F = F
    F && T = F
    T && T = T
    logical not:
    !F = T
    !T = F
    And the general math rules for propagating logical not in complex expressions:
    !(A < B) <=> A >= B
    !(A == B) <=> A != B
    !(A || B) <=> !A && !B
    !(A && B) <=> !A || !B
    https://en.wikipedia.org/wiki/Negation#Distributivity
    sjamplus treats any non-zero value as true, and zero value as false, but when boolean-true is calculated, it is represented by ~0 (-1).
    value = 4 ; value = 4
    value = !4 ; value = 0
    value = !!4 ; value = -1 (true)
    ( "людское ponimanje" => no idea what you are talking about, the math way is the only way I think about logic, even when talking in human language ... but there are many people not able to correctly negate predicate ... for example they ask you if you like blue colour, and you say "no", they will think you hate blue (which is incorrect negation "!like" is not "hate"))
    Последний раз редактировалось Ped7g; 05.01.2021 в 18:25.
  6. #416
    663
    513 сообщений
    не знаю как у вас
    у нас когда люди говорят
    если (if)
    A не равно 1
    или (or)
    A не равно 5
    тогда (then)
    Ы = 7
    если нет (else)
    тогда Ы = 0
    это имеется в виду (и это правильно)
    if A <> 1
      if A <> 5
      Ы = 7
      else
      Ы = 0
      endif
    else
    Ы = 0
    endif
    и ожидаемый результат
    1 Ы=0
    2 Ы=7
    3 Ы=7
    4 Ы=7
    5 Ы=0
    такое никогда не имеют в виду
    if A <> 1
    temp1 = 1
    else
    temp1 = 0
    endif
    if A <> 5
    temp2 = 1
    else
    temp2 = 0
    endif
    if temp1 = 1
      Ы = 7
      else
      if temp2 = 1
      Ы = 7
      else
      Ы = 0
      endif
    endif
    и такой рeзультат
    1 temp1=0 or temp2=1 = Ы=7
    2 temp1=1 or temp2=1 = Ы=7
    3 temp1=1 or temp2=1 = Ы=7
    4 temp1=1 or temp2=1 = Ы=7
    5 temp1=1 or temp2=0 = Ы=7
    совершенно неожиданный
    людскими словами описывается совершенно другой процесс
    а такой вариант правильный только с точки зрения машинной логики
    и людскими словами описать его намного сложней (это будет достаточно много слов)
    к вам претензий нет
    просто это не совсем очевидный аспект
    Последний раз редактировалось NEO SPECTRUMAN; 07.01.2021 в 00:26.
  7. #417
    г. Таллин, Эстония
    223
    159 сообщений
    if A <> 1
    Ы = 7
    else
      if A <> 5
      Ы = 7
      else
      Ы = 0
      endif
    endif
    Кривой код
    else
    Ы = 0
    никогда не отработает
    Heavy on the disasm
    Eric and the disasm
    Mask 3: Venom strikes disasm
    Bard's disasm
  8. #418
    663
    513 сообщений
    пофиксил
    поэтому и нужон долбанный список условий по типу if a=1,5,6
    а не трехэтажные IF-ы
    в которых можно чего то просмотреть
    или нужны элементарные for и goto
    чтоб не городить огород из dup-ов и if-ов
    ТУПО пытаясь повторить их функционал
    додо знаю щас ТЫ начнешь мне расказывать что
    компилятор не должен это делать
    это должен делать cpp, линкер, хренкер прочая ересь
    и весь исходник должен состоят из батников
    а компилятор должен только заменять nop на $00 и ничего более
    и даже не должен делать переходы на метки вперед
    и все метки для переходов должны быть предварительно объявлены в начале исходника
    а то ж ведь компилятор еще не знает куда ему переходить когда код выглядит так
    jp l1
    l1
    Последний раз редактировалось NEO SPECTRUMAN; 07.01.2021 в 00:42.
  9. #419
    103
    77 сообщений
    не знаю как у вас
    если (if)
    A не равно 1
    или (or)
    A не равно 5
    тогда (then)
    Ы = 7
    если нет (else)
    тогда Ы = 0
    yeah, we say "if not equal to 1 and not equal to 5". I guess some people could use "or" there, but they are just using the language wrong, or not understanding the logic expressions. (mind you, while I didn't finish my university studies, I made it far enough to have all exams from math basics, like logic evaluation, so for me it's easy to use the language correctly in logic constructs ... but from my experience with people who didn't study it, it's common they don't understand the rules correctly, and say the wrong thing, while they think something else - very common by non-math people, it's not easy to formulate the rule correctly in human language, even by intelligent people, if they are missing the formal math teaching).
    But I think your example is actually correct if read in certain way, like this: "if A not equal to (1 or 5), then B = 7, else B = 0" -> now this makes some sense also from math point of view, a bit like incomplete distribution of negation, so you end with something like "IF A != (1 || 5)", but if you expand it to simpler statements, it needs the || negation, so "IF A != 1 && A != 5"
    Any way, you can in sjasmplus source always try to pick the "simpler to read", so if you are more familiar with "1 or 5", then do the positive form and negate the final result, like this:
      IF !(A == 1 || A == 5 || A == 7)
        ;; other values of A (not 1 or 5 or 7)
      ELSE
        ;; when A is 1 or 5 or 7
      ENDIF
      ;; notice the "!" at beginning of the expression
      ;; flipping the final result of the test
  10. #420
    663
    513 сообщений
    Ped7g, а можно добавить режим
    чтоб при перезаписи выдавались предупреждения?
    чтоб такой код
     org $C000
    xor a
    xor b
    xor c
    xor d
     org $C001
    xor e
    выдавал
    warning $C001 was overwriten
    ну и если не заводить отдельный массив для этого
    то хотя бы проверять на $00 перед записью
    nop-ов не так много в коде
    и лучше хоть какая то проверка чем никакой...
  1. SjASMPlus Z80 кросс ассемблер
    от Aprisobal в разделе Программирование
    Ответов: 1663
    Последнее: 19.06.2021, 01:36
  2. Исходники TR-DOS для SjASMPlus
    от Keeper в разделе Программирование
    Ответов: 20
    Последнее: 11.02.2011, 11:57
  3. Запуск STS из .sna, сгенерированного sjasmplus.
    от siril в разделе Программирование
    Последнее: 11.10.2010, 21:33
  4. Breakpoints в связке Sjasmplus+UnrealSpeccy
    от Kurles в разделе Программирование
    Ответов: 19
    Последнее: 26.01.2009, 12:36
  5. Disturbed COverMAnia ( music disk with z00m music collection)
    от kyv в разделе Музыка
    Последнее: 27.03.2008, 10:01
